See also, AutoCAD to Photoshop
AutoCAD does allow you to export your drawings to the PostScript format, see the Exporting to EPS section of the AutoCAD to Photoshop tutorial for details. However, as you may have discovered if you have tried, this option often gives less than satisfactory results. By far the best way to create Encapsulated PostScript files from AutoCAD via the Plot dialogue box. However, before you can plot to EPS, you must first set up and configure a PostScript plotter on your computer.
In most cases, when you plot a drawing in AutoCAD, you are sending the plot to a physical plotter and the result is a sheet of paper with your drawing printed on it. However, it is also possible to plot to what is usually known as a "logical" or "dummy" plotter. The plotter does not actually exist but you can use the plotter configuration settings to create a file in a format specific to that plotter. To create EPS files, all you need to do is to add a plotter that uses the EPS format and then configure it to plot to a file rather than to a physical plotter.
Although AutoCAD does not automatically create a PostScript plotter for you when the software is installed, all the necessary files are copied to your hard disk during a standard installation. In fact, all you need to do is to follow a simple wizard.
To add a plotter to AutoCAD so that it appears as an option in the Plot dialogue box, you must use the Add Plotter wizard.
Your new EPS plotter should now be correctly set up and available for use. First of all, check that it appears in the Plotter configuration list on the Plot Device tab of the Plot dialogue box. Select from the standard toolbar. When the Plot dialogue box appears, click the Plot Device tab and then check that your new plotter appears in the drop-down list in the Plotter configuration section. You should see something similar to that shown in the illustration below.
To give your EPS plotter a proper test, use the Plot dialogue box to plot a file and then open that file in Adobe Photoshop. See the Plotting to EPS section of the AutoCAD to Photoshop tutorial for details.
Saturday
5th April 2025
