flopo Posted November 27, 2009 Posted November 27, 2009 Hello everybody, I'm working with 3d polylines and I need a lisp to do this: to draw lines from some points perpendiculat to a 3d polyline. There are a lot of points, 3d points - I mean points in space, with Z different from 0. From each point to draw a perpendicular on 3d polyline, but on that part of poly that is closer to my point. Is it possible? Thanks! Quote
flopo Posted November 27, 2009 Author Posted November 27, 2009 This is an example, but unfortunately I don't have a drawing with 3d polyline, only with 2d polyline.The original 3d ply has been flatten Is a pipe, and anyhow, differences on Z axis are small... polyline.dwg Quote
SEANT Posted November 27, 2009 Posted November 27, 2009 This thread explored the same general theme. There are some excellent lisp examples (starting at Post # 26) that would not require much modification to accomplish the requested task. http://www.cadtutor.net/forum/showthread.php?t=30556 Quote
Lee Mac Posted November 27, 2009 Posted November 27, 2009 Try this: (defun c:perp (/ i ss ent pt p1 p2) (vl-load-com) (princ "\n>> Select Points >>") (if (setq i -1 ss (ssget '((0 . "POINT")))) (if (and (setq ent (car (entsel "\nSelect Curve: "))) (wcmatch (cdr (assoc 0 (entget ent))) "*LINE,CIRCLE,ELLIPSE,ARC")) (while (setq pt (ssname ss (setq i (1+ i)))) (setq p2 (vlax-curve-getClosestPointto ent (setq p1 (cdr (assoc 10 (entget pt)))))) (entmake (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2)))))) (princ)) Quote
alanjt Posted November 27, 2009 Posted November 27, 2009 Try this: (defun c:perp (/ i ss ent pt p1 p2) (vl-load-com) (princ "\n>> Select Points >>") (if (setq i -1 ss (ssget '((0 . "POINT")))) (if (and (setq ent (car (entsel "\nSelect Curve: "))) (wcmatch (cdr (assoc 0 (entget ent))) "*LINE,CIRCLE,ELLIPSE,ARC")) (while (setq pt (ssname ss (setq i (1+ i)))) (setq p2 (vlax-curve-getClosestPointto ent (setq p1 (cdr (assoc 10 (entget pt)))))) (entmake (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2)))))) (princ)) Hey, I use something quite similar to that. ;;; Draw line perpendicular from selected curve ;;; Required Subroutines: AT:Entsel ;;; Alan J. Thompson, 09.29.09 (defun c:LPer (/ *error* #Ent #Obj #Point) (setq *error* (lambda (x) (and #Obj (vl-catch-all-apply 'vla-highlight (list #Obj :vlax-false))))) (and (setq #Ent (AT:Entsel nil "\nSelect curve: " '((0 . "*POLYLINE,ARC,LINE,CIRCLE,ELLIPSE")) nil)) (setq #Obj (vlax-ename->vla-object (car #Ent))) (not (vla-highlight #Obj :vlax-true)) (while (setq #Point (getpoint "\nSpecify point for line: ")) (entmake (list '(0 . "LINE") (cons 10 (vlax-curve-getclosestpointto (car #Ent) (trans #Point 1 0) T)) (cons 11 (trans #Point 1 0)) ) ;_ list ) ;_ entmake ) ;_ while ) ;_ and (*error* nil) (princ) ) ;_ defun The only problem is, with 3DPolylines, the vertex elevation will screw up deriving the closest point. It will often snap to the end point or something. It's really quite annoying. That's why, when trying to get a point on a 3DPolyline, you have to use (osnap (cadr ent) "_near") instead of (vlax-curve-getclosestpointto (car ent) (cadr ent)). Quote
Lee Mac Posted November 27, 2009 Posted November 27, 2009 A quick test seemed to work OK, but I'm not disagreeing with you as I have limited experience indeed in the world of 3D... :wink: Quote
alanjt Posted November 27, 2009 Posted November 27, 2009 A quick test seemed to work OK, but I'm not disagreeing with you as I have limited experience indeed in the world of 3D... :wink: It draws them to the line, they just aren't perpendicular in a top view (which, in my experience, is what you want). However, the requesting party may be asking for just what you did. It's tricky when dealing with the 3D world. I'm civil and things are 3D, but not in the fashion that some people work in 3D. I still live in a TOP view world. Quote
Lee Mac Posted November 27, 2009 Posted November 27, 2009 Point taken, how about this then? (defun c:perp (/ i ss ent pt p1 p2) (vl-load-com) (princ "\n>> Select Points >>") (if (setq i -1 ss (ssget '((0 . "POINT")))) (if (and (setq ent (car (entsel "\nSelect Curve: "))) (wcmatch (cdr (assoc 0 (entget ent))) "*LINE,CIRCLE,ELLIPSE,ARC")) (while (setq pt (ssname ss (setq i (1+ i)))) (setq p2 (vlax-curve-getClosestPointtoprojection ent (setq p1 (cdr (assoc 10 (entget pt)))) '(0 0 1))) (entmake (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2)))))) (princ)) Quote
alanjt Posted November 27, 2009 Posted November 27, 2009 Point taken, how about this then? (defun c:perp (/ i ss ent pt p1 p2) (vl-load-com) (princ "\n>> Select Points >>") (if (setq i -1 ss (ssget '((0 . "POINT")))) (if (and (setq ent (car (entsel "\nSelect Curve: "))) (wcmatch (cdr (assoc 0 (entget ent))) "*LINE,CIRCLE,ELLIPSE,ARC")) (while (setq pt (ssname ss (setq i (1+ i)))) (setq p2 (vlax-curve-getClosestPointtoprojection ent (setq p1 (cdr (assoc 10 (entget pt)))) '(0 0 1))) (entmake (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2)))))) (princ)) Nicely done Lee! I've updated mine as well. ;;; Draw line perpendicular from selected curve ;;; Required Subroutines: AT:Entsel ;;; Alan J. Thompson, 09.29.09 (defun c:LPer (/ *error* #Ent #Obj #Point) (setq *error* (lambda (x) (and #Obj (vl-catch-all-apply 'vla-highlight (list #Obj :vlax-false))))) (and (setq #Ent (AT:Entsel nil "\nSelect curve: " '((0 . "*POLYLINE,ARC,LINE,CIRCLE,ELLIPSE")) nil)) (setq #Obj (vlax-ename->vla-object (car #Ent))) (not (vla-highlight #Obj :vlax-true)) (while (setq #Point (getpoint "\nSpecify point for line: ")) (entmake (list '(0 . "LINE") (cons 10 (vlax-curve-getclosestpointtoprojection (car #Ent) (trans #Point 1 0) '(0 0 1))) (cons 11 (trans #Point 1 0)) ) ;_ list ) ;_ entmake ) ;_ while ) ;_ and (*error* nil) (princ) ) ;_ defun Quote
alanjt Posted November 27, 2009 Posted November 27, 2009 Thanks Alan Well deserved, I never even looked into closestpointtoprojection. Quote
flopo Posted November 30, 2009 Author Posted November 30, 2009 Hello everybody, after drawing perpendicular lines from points to a 3dpoly, I have to measure the distance between consecutive intersection 3dpoly - perpendicular line. A lisp to do this will help me a lot... See the attachment - drawing. Thanks! 3dpoly-dist.dwg Quote
CAB Posted November 30, 2009 Posted November 30, 2009 Try this: (Lee's Routine Modified) (defun c:perp (/ i ss ent pt p1 p2) (vl-load-com) (command "_undo" "_begin") (princ "\n>> Select Points >>") (if (setq i -1 ss (ssget '((0 . "POINT"))) ) (if (and (setq ent (car (entsel "\nSelect Curve: "))) (wcmatch (cdr (assoc 0 (entget ent))) "*LINE,CIRCLE,ELLIPSE,ARC")) (while (setq pt (ssname ss (setq i (1+ i)))) (setq p2 (vlax-curve-getClosestPointto ent (setq p1 (cdr (assoc 10 (entget pt))))) ) (if (entmake (list '(0 . "LINE") '(8 . "perp") (cons 10 p1) (cons 11 p2))) (entmake (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText") '(8 . "point") (cons 10 p1) '(40 . 0.6) '(41 . 6.03584) '(71 . 1) '(72 . 5) (cons 1 (vl-princ-to-string (distance p1 p2))) '(7 . "Standard") ;'(210 0.0 0.0 1.0) '(42 . 1.6) '(43 . 0.6) '(50 . 0.0) '(73 . 1) '(44 . 1.0) ) ) ) ) ) ) (command "_undo" "_end") (princ) ) Quote
CAB Posted November 30, 2009 Posted November 30, 2009 To keep up with this thread you shoud view the following: http://cadtutor.net/forum/showthread.php?t=42442 Here is your fix: http://cadtutor.net/forum/showpost.php?p=286596&postcount=13 http://cadtutor.net/forum/showthread.php?t=42505 http://www.theswamp.org/index.php?topic=31120.0 http://www.theswamp.org/index.php?topic=31110.0 http://discussion.autodesk.com/forums/thread.jspa?messageID=6296446 http://discussion.autodesk.com/forums/thread.jspa?threadID=753908&tstart=0 Quote
wizman Posted November 30, 2009 Posted November 30, 2009 Good code Cab, but i think he is after the distances along the the 3dpoly. Quote
CAB Posted November 30, 2009 Posted November 30, 2009 Oops, Thanks Wizman. (defun c:perp (/ i ss ent pt p1 p2 ptList LASTPT) (vl-load-com) (command "_undo" "_begin") (princ "\n>> Select Points >>") (if (setq i -1 ss (ssget '((0 . "POINT"))) ) (if (and (setq ent (car (entsel "\nSelect Curve: "))) (wcmatch (cdr (assoc 0 (entget ent))) "*LINE,CIRCLE,ELLIPSE,ARC")) (while (setq pt (ssname ss (setq i (1+ i)))) (setq p2 (vlax-curve-getClosestPointto ent (setq p1 (cdr (assoc 10 (entget pt)))))) (setq ptList (cons p2 ptList)) (entmake (list '(0 . "LINE") '(8 . "perp") (cons 10 p1) (cons 11 p2))) ) ) ) (if ptList (progn (setq Startpt (vlax-curve-getstartpoint ent) Lastpt Startpt) ;; sort by distance (setq ptList (vl-sort ptList '(lambda (e1 e2) (< (vlax-curve-getdistatpoint ent e1) (vlax-curve-getdistatpoint ent e2))))) (foreach pt ptList (if (> (distance pt Startpt) 0.001) (entmake (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText") '(8 . "point") (cons 10 (polar pt (angle pt Lastpt)(/ (distance pt Lastpt) 2.))) '(40 . 0.6) '(41 . 0.0) '(71 . '(72 . 5) (cons 1 (rtos (distance pt Lastpt) 2 2)) '(7 . "Standard") ;'(210 0.0 0.0 1.0) '(50 . 0.0) '(73 . 1) '(44 . 1.0) ) ) ) (setq LastPt pt) ) ) ) (command "_undo" "_end") (princ) ) Quote
Lee Mac Posted November 30, 2009 Posted November 30, 2009 No doubt Mr Flopo will return with yet another request... Quote
flopo Posted December 2, 2009 Author Posted December 2, 2009 No doubt Mr Flopo will return with yet another request... No more requests.... on this subject Thanks, guys! Quote
