darshjalal Posted Tuesday at 06:37 AM Posted Tuesday at 06:37 AM (edited) DIVCURVES-INSERTING POINTS AS SPECIFIC DISTANCE.LSP I am so sorry for not giving more details about the code. Please read the following for more details: When executed, the utility launches an interactive keyword configuration: Menu: [1-Polylines/2-Lines/3-Arcs/4-Circles/5-Splines/6-FeatureLines/7-All] --- OPTION 1: Polylines --- - Target: Native 2D LWPolylines and 3D Heavy Polylines (*POLYLINE). - Sub-Prompts: Asks for both "Curve distance" and "Line distance". - Workflow Logic: Polylines frequently alternate between straight tangents and arced bulges. The engine runs through each sub-segment parameter, applying the Curve interval on loops returning a non-zero bulge and the Line interval on zero-bulge vectors. Critical for tracking centerlines. --- OPTION 2: Lines --- - Target: Standalone native LINE entities (completely ignores curves). - Sub-Prompts: Triggers only "Line distance [Middle/Vertices]". - Workflow Logic: * Absolute Number: Measures out fixed structural intervals from start. * "Middle": Drops a single layout node at exactly Total Length / 2. * "Vertices": Flags only the absolute start and endpoints, bypassing any segment division calculations. Perfect for boundary box indexing. --- OPTION 3: Arcs --- - Target: Standalone open circular ARC elements. - Sub-Prompts: Triggers only "Curve distance [Middle]". - Workflow Logic: Uses true structural arc-length path calculations (not straight-line chord spacing). Entering "Middle" isolates the exact apex mid-curve station node. Excellent for curb returns or radius layout. --- OPTION 4: Circles --- - Target: Full, closed 360-degree CIRCLE elements. - Sub-Prompts: 1. Circle Mode [Distance/Pieces] 2. Curve Distance (if Distance Mode) 3. Number of Slices (if Pieces Mode) - Workflow Logic: * Pieces Mode: Divides the 360° rim into perfectly equal pie sections. Ideal for setting layout coordinates for manholes or foundation piles. * Distance Mode: Steps linearly around the outer circumference. --- OPTION 5: Splines --- - Target: Non-uniform smooth organic SPLINE curve strings. - Sub-Prompts: Triggers "Curve distance" and "Line distance". - Workflow Logic: Utilizes Visual LISP curve projection vectors to step smoothly through changing multi-radius landscape or contour paths, automatically trapping and marking the true start/end index boundaries. --- OPTION 6: FeatureLines --- - Target: Native Autodesk Civil 3D Feature Lines (AECC_FEATURE_LINE). - Sub-Prompts: Triggers "Curve distance" and "Line distance". - Workflow Logic: Tailored for civil infrastructure models. The engine interrogates the 3D string, locks all critical grade breaks and site vertices, and overlays intermediate interval layout points that retain design model accuracy. --- OPTION 7: All --- - Target: Simultaneous mixed selection set of all supported geometries. - Sub-Prompts: Sequential configuration parameters for all curves/lines. - Workflow Logic: Scans the entire cross-window selection. For every object trapped, it reads its DXF Group 0 type, dynamically assigns your preset rules, avoids duplicate coordinate overlaps, and populates the entire site plan layer in a single execution click. SHORT SEGMENT OVERRIDE LOGIC: If an entity length or sub-segment is shorter than the interval distance specified, the script halts and prompts: [Middle/All/SkipAll] - "Middle": Drops a layout node exactly at the center of that specific short segment. - "All": Converts the current short vector and all subsequent short vectors discovered during the current command run into midpoints automatically. - "SkipAll": Ignores short segments entirely for the rest of the execution, leaving them clean and checking only major length spans. SHORT SEGMENT OVERRIDE LOGIC: If an entity length or sub-segment is shorter than the interval distance specified, the script halts and prompts: [Middle/All/SkipAll] - "Middle": Drops a layout node exactly at the center of that specific short segment. - "All": Converts the current short vector and all subsequent short vectors discovered during the current command run into midpoints automatically. - "SkipAll": Ignores short segments entirely for the rest of the execution, leaving them clean and checking only major length spans. Edited Wednesday at 09:21 AM by darshjalal 1 Quote
BIGAL Posted Tuesday at 08:32 AM Posted Tuesday at 08:32 AM (edited) If your offering something a good idea is to provide images or a movie about what the program does, else the "Why bother" will occur. Just attaching a lisp is not really describing why you should download the program. Think of it as if I was selling the program how would I get people interested. Edited Tuesday at 08:39 AM by BIGAL 2 Quote
darshjalal Posted Tuesday at 10:12 AM Author Posted Tuesday at 10:12 AM Inside the code there is explanation of the code function. The code does many functions that image can't explain. Kindly check the code and read the description inside. Regards. Quote
pkenewell Posted Tuesday at 03:08 PM Posted Tuesday at 03:08 PM 4 hours ago, darshjalal said: Inside the code there is explanation of the code function. The code does many functions that image can't explain. Kindly check the code and read the description inside. Regards. @darshjalal Thanks for your program contribution. I don't want to take away for your obvious hard work, but I somewhat agree with @BIGAL. I have read the extensive comments that are very detailed and technical, but there is no summary of what it is used for, or how it is useful. For the casual LISP user, they would not understand the value in such a program. I think a simple paragraph would be help instead of blindly evaluating it. Your title does explain the purpose of the program, but it's too vague and some plain language on how the features are helpful would be nice - just a friendly critique 1 2 Quote
mhupp Posted Tuesday at 03:33 PM Posted Tuesday at 03:33 PM (edited) if Nothing else it would show up in peoples searches. just posting a file even tho it has great documentation will not show up in searches. if you take all the time to write things up and share here make it so people can find your lisp files. or just copy all the ;; lines. someone in 6 months to a year will post looking for a divide lisp with points and I won't be able to find this post. -Edit like you did here Edited Tuesday at 05:42 PM by mhupp 1 1 Quote
pkenewell Posted Thursday at 01:10 PM Posted Thursday at 01:10 PM @darshjalal OK - so you updated the first post - with the comments that could already be read in the file. What I asked for was: 1) what it is used for? 2) how it is useful? 3) how the features are helpful? That's all we were asking, rather than the extremely technical description. Quote
BIGAL Posted Thursday at 09:35 PM Posted Thursday at 09:35 PM If your offering something a good idea is to provide images or a movie about what the program does, else the "Why bother" will occur. "(setq oldDynPrompt (getvar "DYNPROMPT")) Fails in Bricscad V25. Here is a freebie for you I dont uses initget. Multi radio buttons.lsp (if (not AH:Butts)(load "Multi radio buttons.lsp")) (setq ans (ah:butts but "V" '("Please choose" "1-Polylines" "2-Lines" "3-Arcs" "4-Circles" "5-Splines" "6-FeatureLines" "7-All"))) You ask for a distance only so it would make sense that it ask for intervals, we did road design and in an intersection kerb the curve was nearly always based on 4 points. maybe when asked for a distance enter a -ve value say -4 means break into 4 even spacing. Have added a couple of other make dcl on the fly for you just leave my name in the code but free to use. You can make a dcl then convert it to lsp code using write-line for the dcl code so dont need the MULTI's.Multi GETVALS.lspMulti toggles.lsp 1 Quote
darshjalal Posted Friday at 08:05 AM Author Posted Friday at 08:05 AM divcurve-lisp-all-option.mp4 1 Quote
darshjalal Posted Friday at 08:08 AM Author Posted Friday at 08:08 AM 10 hours ago, BIGAL said: If your offering something a good idea is to provide images or a movie about what the program does, else the "Why bother" will occur. "(setq oldDynPrompt (getvar "DYNPROMPT")) Fails in Bricscad V25. Here is a freebie for you I dont uses initget. Multi radio buttons.lsp 2.73 kB · 104 downloads (if (not AH:Butts)(load "Multi radio buttons.lsp")) (setq ans (ah:butts but "V" '("Please choose" "1-Polylines" "2-Lines" "3-Arcs" "4-Circles" "5-Splines" "6-FeatureLines" "7-All"))) You ask for a distance only so it would make sense that it ask for intervals, we did road design and in an intersection kerb the curve was nearly always based on 4 points. maybe when asked for a distance enter a -ve value say -4 means break into 4 even spacing. Have added a couple of other make dcl on the fly for you just leave my name in the code but free to use. You can make a dcl then convert it to lsp code using write-line for the dcl code so dont need the MULTI's.Multi GETVALS.lspMulti toggles.lsp Your name of course will be there always. You too free to use any code I am posting here or modify it for the better ideas. Thank you so much. Regards. Quote
