Proctor Posted January 14, 2008 Posted January 14, 2008 Hello: I'm writing a small script in vba and need to get the length of a spline for some calculations. I see that length is not a property of AcadSpline linetype. Does anyone know how I can go about doing this? Thanks, Proctor Quote
CADken Posted January 14, 2008 Posted January 14, 2008 select the spline, type "list" > enter? sorry i'm not following your post 100% Quote
Proctor Posted January 14, 2008 Author Posted January 14, 2008 that's great...I love that trick....but, how can I get the length via my vba script (intellisense doesn't have length for spline): for my line...I entered: Dim MyLine As AcadLine MyLineLength = MyLine.Length(intellisense has length listed for line) but when I go to do this for my spline: Dim MySpline As AcadSpline MyLineLength = MySpline. (intellisense doesn't have length listed for spline) any ideas..and thanks again for your help. Quote
Bryco Posted January 15, 2008 Posted January 15, 2008 Google the Curve.cls This is a class that uses lisp through vba to access the acad math class. Quote
fixo Posted January 16, 2008 Posted January 16, 2008 Try this but dirty method with using of SenCommand this worked good for me though Take a look at 'GetCurveLength' function in the code Option Explicit Function TotLen(oSset As AcadSelectionSet) As Double Dim oEnt As AcadEntity For Each oEnt In oSset If TypeOf oEnt Is AcadPolyline Or _ TypeOf oEnt Is AcadLWPolyline Or _ TypeOf oEnt Is AcadLine Then TotLen = TotLen + oEnt.Length ElseIf TypeOf oEnt Is AcadArc Then TotLen = TotLen + oEnt.ArcLength ElseIf TypeOf oEnt Is AcadCircle Then TotLen = TotLen + oEnt.Circumference ElseIf TypeOf oEnt Is AcadSpline Then TotLen = TotLen + GetCurveLength(oEnt) ElseIf TypeOf oEnt Is AcadEllipse Then TotLen = TotLen + GetCurveLength(oEnt) End If Next oEnt End Function Function [b][color=red]GetCurveLength[/color][/b](oEnt As AcadEntity) As Double Dim sVar sVar = 0 Dim strCom As String With ThisDrawing .SetVariable "USERR1", sVar .SendCommand "(vl-load-com)" & vbCr strCom = "(setvar " & Chr(34) & "USERR1" & Chr(34) & Chr(32) & "(vlax-curve-getdistatparam (vlax-ename->vla-object (handent " & Chr(34) & oEnt.Handle & Chr(34) & ")) (vlax-curve-getendparam (vlax-ename->vla-object (handent " & Chr(34) & oEnt.Handle & Chr(34) & ")))))" & vbCr .SendCommand strCom GetCurveLength = .GetVariable("USERR1") End With End Function Sub TryIt() Dim oSset As AcadSelectionSet Dim oEnt Dim fcode(0) As Integer Dim fData(0) As Variant Dim dxfCode, dxfdata Dim i As Integer Dim SetName As String ' create filter fcode(0) = 0 ' include the following entity types: ' LINE, LWPOLYLINE, POLYLINE, SPLINE, ARC, CIRCLE, ELLIPSE: fData(0) = "*LINE,ARC,CIRCLE,ELLIPSE" ' dxfCode = fcode dxfdata = fData ' SetName = "$Total$" ' delete all selection sets to make sure that named selection does not exist With ThisDrawing.SelectionSets While .Count > 0 .Item(0).Delete Wend End With ' add empty selection into selectionsets collection Set oSset = ThisDrawing.SelectionSets.Add(SetName) ' select on screen oSset.SelectOnScreen dxfCode, dxfdata ' display result If oSset.Count > 0 Then MsgBox CStr(Round(TotLen(oSset), 3)), vbInformation, "Total Length" Else MsgBox "0 selected, try again" End If End Sub ~'J'~ Quote
Proctor Posted January 16, 2008 Author Posted January 16, 2008 thanks fatty: It looks like you are calling sub routine: GetCurveLength(oEnt As AcadEntity) As Double which in turn, passes some vars to a lisp routine. is this correct? you wouldn't happen to have the script on the lisp side - would you? thanks again, Proctor Quote
fixo Posted January 16, 2008 Posted January 16, 2008 Hi, Not at all. Here it was passed to the command line the Lisp expression only (not a sub), which calculates the length of object, this line: (vl-load-com) load Visual Lisp (ActiveX) library and then it calculates the distance at the end parameter of this object, nothing else ~'J'~ Quote
Proctor Posted January 16, 2008 Author Posted January 16, 2008 I get it now...it's working!!! Thank you so much for your help...this is great! Proctor Quote
Otavio Posted October 18, 2023 Posted October 18, 2023 On 1/16/2008 at 9:31 AM, fixo said: Beautiful! This also works very well at my application. Can you teach us how to do this(send a lisp to the command prompt) also for getting the bounding box of a SPLINE entity? With VBA resources (GetBoundingBox method) do not returns the corretly values for splines... On 1/16/2008 at 9:31 AM, fixo said: Option Explicit Function TotLen(oSset As AcadSelectionSet) As Double Dim oEnt As AcadEntity For Each oEnt In oSset If TypeOf oEnt Is AcadPolyline Or _ TypeOf oEnt Is AcadLWPolyline Or _ TypeOf oEnt Is AcadLine Then TotLen = TotLen + oEnt.Length ElseIf TypeOf oEnt Is AcadArc Then TotLen = TotLen + oEnt.ArcLength ElseIf TypeOf oEnt Is AcadCircle Then TotLen = TotLen + oEnt.Circumference ElseIf TypeOf oEnt Is AcadSpline Then TotLen = TotLen + GetCurveLength(oEnt) ElseIf TypeOf oEnt Is AcadEllipse Then TotLen = TotLen + GetCurveLength(oEnt) End If Next oEnt End Function Function [b][color=red]GetCurveLength[/color][/b](oEnt As AcadEntity) As Double Dim sVar sVar = 0 Dim strCom As String With ThisDrawing .SetVariable "USERR1", sVar .SendCommand "(vl-load-com)" & vbCr strCom = "(setvar " & Chr(34) & "USERR1" & Chr(34) & Chr(32) & "(vlax-curve-getdistatparam (vlax-ename->vla-object (handent " & Chr(34) & oEnt.Handle & Chr(34) & ")) (vlax-curve-getendparam (vlax-ename->vla-object (handent " & Chr(34) & oEnt.Handle & Chr(34) & ")))))" & vbCr .SendCommand strCom GetCurveLength = .GetVariable("USERR1") End With End Function Sub TryIt() Dim oSset As AcadSelectionSet Dim oEnt Dim fcode(0) As Integer Dim fData(0) As Variant Dim dxfCode, dxfdata Dim i As Integer Dim SetName As String ' create filter fcode(0) = 0 ' include the following entity types: ' LINE, LWPOLYLINE, POLYLINE, SPLINE, ARC, CIRCLE, ELLIPSE: fData(0) = "*LINE,ARC,CIRCLE,ELLIPSE" ' dxfCode = fcode dxfdata = fData ' SetName = "$Total$" ' delete all selection sets to make sure that named selection does not exist With ThisDrawing.SelectionSets While .Count > 0 .Item(0).Delete Wend End With ' add empty selection into selectionsets collection Set oSset = ThisDrawing.SelectionSets.Add(SetName) ' select on screen oSset.SelectOnScreen dxfCode, dxfdata ' display result If oSset.Count > 0 Then MsgBox CStr(Round(TotLen(oSset), 3)), vbInformation, "Total Length" Else MsgBox "0 selected, try again" End If End Sub ~'J'~ Quote
