ronjonp Posted April 27, 2009 Posted April 27, 2009 Ahh, didn't know that Ron, thanks mate You're welcome Quote
KLKSMILE Posted April 27, 2009 Author Posted April 27, 2009 Sorry, I didn't realize you had replied Ok - yes, all the borders are the same Below is a link to a jpg shot of a sample sheet with the TAG stamp I can email you the CAD file if you want edhttp://docs.google.com/Doc?id=dgxjkf3j_11f6khkhhg Thanks! Quote
Lee Mac Posted April 27, 2009 Posted April 27, 2009 Ok, this was a bit harder, but give this a shot: ;; Drawing Cutter V4, by Lee McDonnell 27.04.2009 (defun c:DwgCut (/ *error* vlst ovar doc file path ss miPt maPt winLst iSs i Nme fname wBss wLst) (vl-load-com) (defun *error* (msg) (if ovar (mapcar 'setvar vlst ovar)) (if (not (member msg '("Function cancelled" "quit / exit abort"))) (princ (strcat "\nError: " msg)) (princ "\n<<-- Function Cancelled -->>")) (princ)) (setq vlst '("CLAYER" "OSMODE") ovar (mapcar 'getvar vlst)) (setvar "OSMODE" 0) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (or (tblsearch "LAYER" "DATESTAMP") (vla-put-color (vla-add (vla-get-Layers doc) "DATESTAMP") acYellow)) (setq file (getfiled "Select Location for New Files" (if $def $def "") "dwg" 1)) (if (not (setq $def file)) (exit)) (setq path (vl-filename-directory file)) (if (setq ss (ssget "X" '((0 . "INSERT") (2 . "BORDER")))) (foreach Obj (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss))) (vla-getBoundingBox Obj 'miPt 'maPt) (setq winLst (mapcar (function (lambda (x) (vlax-safearray->list x))) (list miPt maPt))) (vla-ZoomExtents (vlax-get-acad-object)) (setq iSs (ssget "_C" (car winLst) (cadr winLst)) i 2) (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex iSs))) (if (and (eq "TitleText" (cdr (assoc 8 (entget ent)))) (member (cdr (assoc 0 (entget ent))) '("TEXT" "MTEXT"))) (setq Nme (cdr (assoc 1 (entget ent)))))) (if (member (strcat Nme ".dwg") (vl-directory-files path "*.dwg" 1)) (progn (setq Nme (strcat Nme (chr 40) (itoa i) (chr 41)) i (1+ i)) (while (member (strcat Nme ".dwg") (vl-directory-files path "*.dwg" 1)) (setq Nme (strcat (substr Nme 1 (- (strlen Nme) 3)) (chr 40) (itoa i) (chr 41)) i (1+ i))))) (setq fname (strcat path "\\" Nme ".dwg")) (ssadd (Make_Text (car winLst) (DStamp Nme) (/ pi 2)) iSs) (setq wBss (vla-add (vla-get-SelectionSets doc) "wBss") wLst (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex iSs))))) (vla-additems wBss (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbobject (cons 0 (1- (length wLst)))) wLst))) (vla-wBlock doc fname wBss) (vla-delete (vla-item (vla-get-SelectionSets doc) "wBss"))) (princ "\n<!> No Borders Found <!>")) (mapcar 'setvar vlst ovar) (princ)) (defun Make_Text (pt val rot) (entmakex (list '(0 . "TEXT") (cons 8 "DATESTAMP") (cons 10 pt) (cons 40 (getvar "TEXTSIZE")) (cons 1 val) (cons 50 rot) (cons 7 (getvar "TEXTSTYLE")) '(71 . 0) '(72 . 0) '(73 . 1) (cons 11 pt)))) (defun DStamp (DNme / cAP cDate cMon cHrs cMin tStr) (setq cAP "AM" cDate (rtos (getvar "CDATE") 2 4) cMon (nth (1- (atoi (substr cDate 5 2))) '("JAN" "FEB" "MAR" "APR" "MAY" "JUN" "JUL" "AUG" "SEP" "OCT" "NOV" "DEC")) cHrs (atoi (substr cDate 10 2)) cMin (substr cDate 12 2)) (cond ((<= 13 cHrs) (setq cAP "PM" cHrs (itoa (- cHrs 12)))) ((= 12 cHrs) (setq cAP "PM" cHrs (itoa cHrs)))) (setq tStr (strcat "DRFT: KLK FILE:" DNme " DATE: " cMon (chr 32) (substr cDate 7 2) ", " (substr cDate 1 4) " TIME: " cHrs (chr 58) cMin (chr 32) cAP)) tStr) Quote
KLKSMILE Posted April 27, 2009 Author Posted April 27, 2009 It won't load in AutoCAD - I've double checked everything in terms of loading it properly. It says it's not a known command. Quote
KLKSMILE Posted April 27, 2009 Author Posted April 27, 2009 ok - it does now I don't know why is wasn't at first. Sorry Is there any way to double the space between the title block and the TAG? It's supposed to be aroung .16 and it's about.08 THANK YOU SO SO SO much!!! Quote
Lee Mac Posted April 27, 2009 Posted April 27, 2009 Have you copied EVERYTHING from the code frame, and what command are you typing to invoke it? Quote
Lee Mac Posted April 27, 2009 Posted April 27, 2009 ok - it does now I don't know why is wasn't at first. Sorry Ok, no worries Is there any way to double the space between the title block and the TAG? It's supposed to be aroung .16 and it's about.08 Will give you an adjustment option at the top of the LISP THANK YOU SO SO SO much!!! No probs Quote
Lee Mac Posted April 27, 2009 Posted April 27, 2009 Ok, alter the variable at the very top of the LISP if necessary ;; Drawing Cutter V4, by Lee McDonnell 27.04.2009 (defun c:DwgCut (/ *error* vlst ovar tOff doc file path ss miPt maPt winLst iSs i Nme fname wBss wLst) [color=Red][b](setq tOff 1.6) ; <<-- Adjust this if necessary[/b][/color] (vl-load-com) (defun *error* (msg) (if ovar (mapcar 'setvar vlst ovar)) (if (not (member msg '("Function cancelled" "quit / exit abort"))) (princ (strcat "\nError: " msg)) (princ "\n<<-- Function Cancelled -->>")) (princ)) (setq vlst '("CLAYER" "OSMODE") ovar (mapcar 'getvar vlst)) (setvar "OSMODE" 0) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (or (tblsearch "LAYER" "DATESTAMP") (vla-put-color (vla-add (vla-get-Layers doc) "DATESTAMP") acYellow)) (setq file (getfiled "Select Location for New Files" (if $def $def "") "dwg" 1)) (if (not (setq $def file)) (exit)) (setq path (vl-filename-directory file)) (if (setq ss (ssget "X" '((0 . "INSERT") (2 . "BORDER")))) (foreach Obj (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss))) (vla-getBoundingBox Obj 'miPt 'maPt) (setq winLst (mapcar (function (lambda (x) (vlax-safearray->list x))) (list miPt maPt))) (vla-ZoomExtents (vlax-get-acad-object)) (setq iSs (ssget "_C" (car winLst) (cadr winLst)) i 2) (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex iSs))) (if (and (eq "TitleText" (cdr (assoc 8 (entget ent)))) (member (cdr (assoc 0 (entget ent))) '("TEXT" "MTEXT"))) (setq Nme (cdr (assoc 1 (entget ent)))))) (if (member (strcat Nme ".dwg") (vl-directory-files path "*.dwg" 1)) (progn (setq Nme (strcat Nme (chr 40) (itoa i) (chr 41)) i (1+ i)) (while (member (strcat Nme ".dwg") (vl-directory-files path "*.dwg" 1)) (setq Nme (strcat (substr Nme 1 (- (strlen Nme) 3)) (chr 40) (itoa i) (chr 41)) i (1+ i))))) (setq fname (strcat path "\\" Nme ".dwg")) (ssadd (Make_Text (polar (car winLst) pi (- tOff 0.86)) (DStamp Nme) (/ pi 2)) iSs) (setq wBss (vla-add (vla-get-SelectionSets doc) "wBss") wLst (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex iSs))))) (vla-additems wBss (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbobject (cons 0 (1- (length wLst)))) wLst))) (vla-wBlock doc fname wBss) (vla-delete (vla-item (vla-get-SelectionSets doc) "wBss"))) (princ "\n<!> No Borders Found <!>")) (mapcar 'setvar vlst ovar) (princ)) (defun Make_Text (pt val rot) (entmakex (list '(0 . "TEXT") (cons 8 "DATESTAMP") (cons 10 pt) (cons 40 (getvar "TEXTSIZE")) (cons 1 val) (cons 50 rot) (cons 7 (getvar "TEXTSTYLE")) '(71 . 0) '(72 . 0) '(73 . 1) (cons 11 pt)))) (defun DStamp (DNme / cAP cDate cMon cHrs cMin tStr) (setq cAP "AM" cDate (rtos (getvar "CDATE") 2 4) cMon (nth (1- (atoi (substr cDate 5 2))) '("JAN" "FEB" "MAR" "APR" "MAY" "JUN" "JUL" "AUG" "SEP" "OCT" "NOV" "DEC")) cHrs (atoi (substr cDate 10 2)) cMin (substr cDate 12 2)) (cond ((<= 13 cHrs) (setq cAP "PM" cHrs (itoa (- cHrs 12)))) ((= 12 cHrs) (setq cAP "PM" cHrs (itoa cHrs)))) (setq tStr (strcat "DRFT: KLK FILE:" DNme " DATE: " cMon (chr 32) (substr cDate 7 2) ", " (substr cDate 1 4) " TIME: " cHrs (chr 58) cMin (chr 32) cAP)) tStr) Quote
KLKSMILE Posted April 27, 2009 Author Posted April 27, 2009 It works perfect now - thank you so much again! Quote
Lee Mac Posted April 27, 2009 Posted April 27, 2009 I'm glad it will save you some time If you need anything else, just ask Quote
KLKSMILE Posted April 27, 2009 Author Posted April 27, 2009 So it seems that every time I run the LISP pgm on the multiple sheet file, it TAGs it properly, but if I've already ran it once, it doesn't replace the 1st TAG, it adds another TAG on top of the 1st one. Also, the original TAG lisp used the line: (command "zoom" "e") is there any way I can put this back into the code so it zooms in on the split file before it saves it? That way you can see the whole drawing in the preview window. Quote
Lee Mac Posted April 27, 2009 Posted April 27, 2009 When I'm WBlocking, I can't access the WBlock'ed drawing file to make changes on it - which is why I had to add the Date-Tag in the main drawing and not the WBlock'ed one. But as for replacing the datestamp - this can be done Quote
Lee Mac Posted April 27, 2009 Posted April 27, 2009 Try this: ;; Drawing Cutter V4, by Lee McDonnell 27.04.2009 (defun c:DwgCut (/ *error* vlst ovar tOff doc file path ss dSs miPt maPt winLst iSs i Nme fname wBss wLst) (setq tOff 1.6) ; <<-- Adjust this if necessary (vl-load-com) (defun *error* (msg) (if ovar (mapcar 'setvar vlst ovar)) (if (not (member msg '("Function cancelled" "quit / exit abort"))) (princ (strcat "\nError: " msg)) (princ "\n<<-- Function Cancelled -->>")) (princ)) (setq vlst '("CLAYER" "OSMODE") ovar (mapcar 'getvar vlst)) (setvar "OSMODE" 0) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (or (tblsearch "LAYER" "DATESTAMP") (vla-put-color (vla-add (vla-get-Layers doc) "DATESTAMP") acYellow)) (setq file (getfiled "Select Location for New Files" (if $def $def "") "dwg" 1)) (if (not (setq $def file)) (exit)) (setq path (vl-filename-directory file)) (if (setq ss (ssget "X" '((0 . "INSERT") (2 . "BORDER")))) (foreach Obj (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss))) (vla-getBoundingBox Obj 'miPt 'maPt) (setq winLst (mapcar (function (lambda (x) (vlax-safearray->list x))) (list miPt maPt))) (vla-ZoomExtents (vlax-get-acad-object)) (setq iSs (ssget "_C" (car winLst) (cadr winLst)) i 2) (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex iSs))) (if (and (eq "TitleText" (cdr (assoc 8 (entget ent)))) (member (cdr (assoc 0 (entget ent))) '("TEXT" "MTEXT"))) (setq Nme (cdr (assoc 1 (entget ent)))))) (if (member (strcat Nme ".dwg") (vl-directory-files path "*.dwg" 1)) (progn (setq Nme (strcat Nme (chr 40) (itoa i) (chr 41)) i (1+ i)) (while (member (strcat Nme ".dwg") (vl-directory-files path "*.dwg" 1)) (setq Nme (strcat (substr Nme 1 (- (strlen Nme) 3)) (chr 40) (itoa i) (chr 41)) i (1+ i))))) (setq fname (strcat path "\\" Nme ".dwg")) (if (setq dSs (ssget "X" '((0 . "*TEXT") (8 . "DATESTAMP")))) (mapcar 'entdel (mapcar 'cadr (ssnamex dSs)))) (ssadd (Make_Text (polar (car winLst) pi (- tOff 0.86)) (DStamp Nme) (/ pi 2)) iSs) (setq wBss (vla-add (vla-get-SelectionSets doc) "wBss") wLst (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex iSs))))) (vla-additems wBss (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbobject (cons 0 (1- (length wLst)))) wLst))) (vla-wBlock doc fname wBss) (vla-delete (vla-item (vla-get-SelectionSets doc) "wBss"))) (princ "\n<!> No Borders Found <!>")) (mapcar 'setvar vlst ovar) (princ)) (defun Make_Text (pt val rot) (entmakex (list '(0 . "TEXT") (cons 8 "DATESTAMP") (cons 10 pt) (cons 40 (getvar "TEXTSIZE")) (cons 1 val) (cons 50 rot) (cons 7 (getvar "TEXTSTYLE")) '(71 . 0) '(72 . 0) '(73 . 1) (cons 11 pt)))) (defun DStamp (DNme / cAP cDate cMon cHrs cMin tStr) (setq cAP "AM" cDate (rtos (getvar "CDATE") 2 4) cMon (nth (1- (atoi (substr cDate 5 2))) '("JAN" "FEB" "MAR" "APR" "MAY" "JUN" "JUL" "AUG" "SEP" "OCT" "NOV" "DEC")) cHrs (atoi (substr cDate 10 2)) cMin (substr cDate 12 2)) (cond ((<= 13 cHrs) (setq cAP "PM" cHrs (itoa (- cHrs 12)))) ((= 12 cHrs) (setq cAP "PM" cHrs (itoa cHrs)))) (setq tStr (strcat "DRFT: KLK FILE:" DNme " DATE: " cMon (chr 32) (substr cDate 7 2) ", " (substr cDate 1 4) " TIME: " cHrs (chr 58) cMin (chr 32) cAP)) tStr) Quote
KLKSMILE Posted April 27, 2009 Author Posted April 27, 2009 SWEET - that works ... only other thing is the zoom extents command Quote
Lee Mac Posted April 27, 2009 Posted April 27, 2009 SWEET - that works ... only other thing is the zoom extents command Yes, but see my ealier post ^^ Quote
Lee Mac Posted April 27, 2009 Posted April 27, 2009 When I'm WBlocking, I can't access the WBlock'ed drawing file to make changes on it - which is why I had to add the Date-Tag in the main drawing and not the WBlock'ed one. See this post ^^ Quote
