ok, what are they, and any links for them.
i figure if i am going to jump in, i might as well go to the deep end.
:P
Well as you might imagine what is must have for one person is different for another.
That said, here is my current "can't live without" list:
Nearly everyday use:
Weld
Mirror
Purge
Pipe along path
$ Podium
$ Subdivide & Smooth
Sketchy Free Form Deformation
Tools On Surface
Joint Push Pull
Sphere
STP Copy
These are what I use every now and then:
Projections
Bezier Spline
Windowizer
Round Edge
Make Faces
Soap Skin Bubble
Free Scale
Round edges by Bezier
Draw Helix
View based face reverser
Section Cut Face
3D grid
Just for fun:
Homer
And what I intend to purchase once I find a need:
$ Bool Tools
$ Profile Builder
Check these threads out on the SCF.
Ruby Script visual reference:
http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16909
Discussion on "Must Have" scripts:
http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12149&st=0&sk=t&sd=a
Most of those listed are free and can be found on the SCF. If there are any of the scripts I listed above you
have trouble finding, just ask and I will try to locate them.
thanks for that, i will get started.
i have been playing around the last few days, and i think it will end up being a good little "tool" to know, as 3d is very handy for clients who have issues reading 2d line drawings.
G
  • 2 months later...
Its interesting, and great that only two of your plugins were bought! My most used plugin by far is PurgeAll.. must have saved hours in the last few years. 'Make faces' is also a blessing when you are doing architecture site plans...
