Danielm103 Posted April 13, 2025 Posted April 13, 2025 I think : ) Perfect for people that are more familiar with the ActiveX side of things, or don’t want to worry about open close state. One difference between PyRx and VBA is that Points and Vectors evaluate to AcGePoint3d, AcGeVector3d, AcGeMatrix3d etc. from pyrx import Rx, Ge, Gi, Db, Ap, Ed, Ax, command @command def doitx1(): axApp = Ap.Application.acadApplication() axDoc = axApp.activeDocument() axUtil = axDoc.utility() print(axUtil.getSubEntity("\nPick: ")) @command def doitx2(): axApp = Ap.Application.acadApplication() axDoc = axApp.activeDocument() for axEnt in axDoc.modelSpace(): axEnt.setLayer("0") @command def doitx3(): axApp = Ap.Application.acadApplication() axDoc = axApp.activeDocument() axModel = axDoc.modelSpace() axCircle = axModel.addCircle(Ge.Point3d(0, 0, 0), 10) axCircle.setTrueColor(Ax.AcadAcCmColor(255, 0, 0)) @command def doitx4(): try: axApp = Ap.Application.acadApplication() acDoc = axApp.activeDocument() axSets = acDoc.selectionSets() axSet = axSets.add("PYRX") axSet.selectOnScreen([(0, "INSERT")]) for axEnt in axSet: axRef = Ax.AcadBlockReference.cast(axEnt) if axRef.isDynamicBlock(): for prop in axRef.dynamicBlockProperties(): print(prop.value(), prop.propertyName(), prop.allowedValues()) finally: axSet.delete() # batch @command def doitx5(): paths = [ "M:\\Dev\\Projects\\PyRxGit\\unitTests\\testmedia\\06457.dwg", "M:\\Dev\\Projects\\PyRxGit\\unitTests\\testmedia\\dynamicBlock.dwg", ] for path in paths: databaseOper(path, doSomething) # scope def databaseOper(path, func): sideDb = Db.Database(False, True) sideDb.readDwgFile(path) sideDb.closeInput(True) func(sideDb) # sideDb.saveAs(path) def doSomething(sideDb: Db.Database): allEntNames = set() axDb = sideDb.acadDatabase() for axEnt in axDb.modelSpace(): allEntNames.add(axEnt.entityName()) print(allEntNames) Quote
Danielm103 Posted April 13, 2025 Author Posted April 13, 2025 Oh selection set filters, result buffers, xdata etc, are a collection of tuples the same as the ARX side ((0, "INSERT")) # tuple of tuples int dxf , value [(0, "INSERT")] # list of tuples int dxf , value [(Db.DxfCode.kDxfStart, "INSERT")] # list of tuples DxfCode , value Quote
