MiGo Posted April 20, 2009 Posted April 20, 2009 I use selection sets to get all of objects like dimensions, circles, images, inserts... How does one get a selection set of all AECObjects in a drawing? Objects like windows walls doors that are drawn with AutoCAD architectural. Quote
borgunit Posted April 22, 2009 Posted April 22, 2009 Try to list one and see what it returns. Post back here. Quote
alanjt Posted April 22, 2009 Posted April 22, 2009 if they all start with "AECC", you could do this: (ssget "X" '((0 . "AECC*"))) Quote
Lee Mac Posted April 22, 2009 Posted April 22, 2009 What return do you get when you click on it with this? (defun c:en (/ Obj eNxt) (if (setq Obj (car (entsel "\nSelect Object: "))) (progn (textscr) (foreach x (entget Obj) (print x)) (if (setq eNxt (entnext Obj)) (while (not (eq "SEQEND" (cdadr (entget eNxt)))) (princ "\n\nSub:\n") (foreach x (entget eNxt) (print x)) (setq eNxt (entnext eNxt)))))) (princ)) Quote
-KarL- Posted April 22, 2009 Posted April 22, 2009 I use (entget (car (entsel))) to get all the data for an AEC object to help set up selection set filters. Just paste it into the command line and select the object. Quote
MiGo Posted April 22, 2009 Author Posted April 22, 2009 As part of my ever growing script to the client, they don't want any AECObjects in the drawing because they have problems using their older version. As of now we just use an E-transmit with the first drawing in the package open, and add all drawings in the project to that list. In the E-transmit settings we have it Bind the External References, and explode AECObjects. The problem is this is another step that the user has to go through and wait for it to finish, so I'm trying to have my script bind the external references, then after bursting the block representing the external reference I will get all of the AECObjects and explode them to simulate what an E-transmit would do. I have tried actually running E-transmit on the drawing via the script, but it creates another drawing in another directory then I have to find it then it wasn't bound... and that was just too annoying for me. The (setq ss (ssget "X" '((0 . "AEC*")))) works great to select all of the AECObjects because they all start with AEC then it's _NAME (like wall door window...). Quote
MiGo Posted April 22, 2009 Author Posted April 22, 2009 Well the exploding of the AECObjects worked on the drawing that I have open, but I haven't put together the binding section with the AECObject section as a whole into the script yet. I will let you know tho. Quote
MiGo Posted April 22, 2009 Author Posted April 22, 2009 Is there a way when in modelspace to have a selection set get all of external references like (setq ss (ssget "x" '((0 . "xref"))))? Quote
alanjt Posted April 22, 2009 Posted April 22, 2009 Is there a way when in modelspace to have a selection set get all of external references like (setq ss (ssget "x" '((0 . "xref"))))? needed this a while back for a routine. ;;; List of Xref Names ;;; xref retreival credit: Tim Willey ;;; written by: Alan J. Thompson, 3.16.09 (defun XrefNameList (/ #list) (vlax-for i (vla-get-filedependencies (vla-get-activedocument (vlax-get-acad-object)) ) ;_ vla-get-filedependencies (if (= (vla-get-feature i) "Acad:XRef") (setq #list (cons (vl-filename-base (vla-get-filename i)) #list) ) ;_ setq ) ;_ if ) ;_ vlax-for (vl-sort #list '<) ) ;_ defun Quote
MiGo Posted April 22, 2009 Author Posted April 22, 2009 I have made a lisp out of your text and loaded it, but when i type xrefnamelist I get an error Quote
alanjt Posted April 22, 2009 Posted April 22, 2009 actually, i guess you'd want something more like this: ;;; String of Xref Names ;;; xref retreival credit: Tim Willey ;;; written by: Alan J. Thompson, 04.22.09 (defun XrefNameString (/ #list #String) (setq #String "") (vlax-for i (vla-get-filedependencies (vla-get-activedocument (vlax-get-acad-object)) ) ;_ vla-get-filedependencies (if (= (vla-get-feature i) "Acad:XRef") (setq #String (strcat (vl-filename-base (vla-get-filename i)) "," #String ) ;_ strcat ) ;_ setq ) ;_ if ) ;_ vlax-for (substr #String 1 (1- (strlen #String))) ) ;_ defun (setq ss (ssget "_X" '((cons 2 (XrefNameString))))) Quote
alanjt Posted April 22, 2009 Posted April 22, 2009 I have made a lisp out of your text and loaded it, but when i type xrefnamelist I get an error add (vl-load-com) to it i never add this because it's in my startup. Quote
Lee Mac Posted April 22, 2009 Posted April 22, 2009 Another method, if you prefer the DXF way: [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] selx [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] blk xrefs[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] blk [b][color=RED]([/color][/b][b][color=BLUE]tblnext[/color][/b] [b][color=MAGENTA]"BLOCK"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]>[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]logand[/color][/b] 4 [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] 70 blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] 0[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] name [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] 2 blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b] xrefs [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] xrefs [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] xrefs [b][color=MAGENTA]","[/color][/b] name[b][color=RED])[/color][/b] name[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=MAGENTA]"X"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b]0 . [b][color=MAGENTA]"INSERT"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][color=Blue]cons[/color][/b] 2 xrefs[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Quote
