Cadkiller Posted April 5 Posted April 5 Hello Group, It's been a long time since I posted anything on this forum. I searched for this topic but didn't find anything to help me create it. I'm trying to create a bevel symbol which will give the sloped/pitch info for a selected line. Based off of 12" run and give the angle as well. Any help would be greatly appreciated. Sincerely, Edward Borg www.precisiondraftingllc.com https://www.facebook.com/MiscIronDetailer/ 40 Plus Years of Steel Construction Experience Quote
BIGAL Posted April 5 Posted April 5 (edited) A good task to start learning lisp. Select a line (entsel Get X & Y of start and end points, work out X & Y, work out X rescaled to Y = 12 (entget (car (entsel Ask for a point or hard code a distance away use (polar pt ang dist)& (getpoint Draw the 3 lines (command "line" Draw the text. (command "text" Its not very hard so I would ask others to not post code, at some point learning how to do a simple lisp task is well worth while. So have a go plenty here can help when you get stuck. Edited April 5 by BIGAL Quote
Tsuky Posted April 5 Posted April 5 I have this for a metric system, I don't know if it would be suitable for a foot system...! But it can be a start for you. (defun C:SLOPE ( / blp pt_o pt_f frac_prec sv_osmd e_last dxf_o slope slope_h slope_v nx sv_ortho pt_start pt_x t2_slope t1_slope pt_mid pt_text pt_int ed_1) (setvar "cmdecho" 0) (setq blp (getvar "blipmode")) (setvar "blipmode" 0) (initget 9) (setq pt_o (getpoint "\nSpecify the starting point: ")) (cond (pt_o (initget 41) (setq pt_f (getpoint pt_o "\nChoosing the end point: ")) (cond (pt_f (command "_.undo" "_group") (cond ((and (not (eq (getvar "USERI1") 1)) (not (eq (getvar "USERI1") 10)) (not (eq (getvar "USERI1") 100))) (initget "Unit Dozen Hundred") (setq frac_prec (getkword "\nFraction accuracy [Unit/Dozen/Hundred]<Dozen>: ")) (if (not frac_prec) (setq frac_prec "Dozen")) (cond ((eq frac_prec "Unit") (setq slope_v 1)) ((eq frac_prec "Dozen") (setq slope_v 10)) ((eq frac_prec "Hundred") (setq slope_v 100)) ) (setvar "USERI1" slope_v) ) (T (setq slope_v (getvar "USERI1"))) ) (setq sv_osmd (getvar "osmode")) (setvar "osmode" 0) (command "_.ray" pt_o pt_f "") (setq e_last (entlast) dxf_o (trans (cdr (assoc 11 (entget e_last))) 0 1 T) ) (entdel e_last) (setq slope (abs (if (zerop (cadr dxf_o)) 0.0 (/ (car dxf_o) (cadr dxf_o)))) slope_h (fix (* slope_v slope)) nx (if (zerop slope_h) 0 (gcd slope_h slope_v)) sv_ortho (getvar "orthomode") ) (while (> nx 1) (setq slope_h (/ slope_h nx) slope_v (/ slope_v nx) nx (gcd slope_h slope_v)) ) (setvar "orthomode" 1) (setq pt_start (mapcar '/ (mapcar '+ pt_o pt_f) '(2.0 2.0 2.0)) pt_start (list (car pt_start) (cadr pt_start) 0.0)) (initget 9) (setq pt_x (getpoint pt_start "\nSpecify the size of the symbol: ") pt_x (list (car pt_x) (cadr pt_x))) (if (equal (car pt_x) (car pt_start) 1E-12) (setq t2_slope (rtos slope_h 2 0) t1_slope (rtos slope_v 2 0)) (setq t2_slope (rtos slope_v 2 0) t1_slope (rtos slope_h 2 0)) ) (repeat 2 (command "_.dimordinate" pt_start "_text" t1_slope pt_x) (setq pt_mid (mapcar '/ (mapcar '+ pt_start pt_x) '(2.0 2.0 2.0))) (if (equal (car pt_x) (car pt_start) 1E-12) (setq pt_int (polar pt_x 0.0 (distance pt_start pt_x))) (setq pt_int (polar pt_x (/ pi 2.0) (distance pt_start pt_x))) ) (setq pt_start (inters pt_o pt_f pt_x pt_int nil) t1_slope t2_slope ) (if (null pt_start) (setq pt_start pt_x)) (setq pt_text (polar pt_mid (angle pt_start pt_x) (getvar "dimtxt")) ) (command "_aidimtextmove" "_2" (entlast) "" pt_text) (if (not ed_1) (setq ed_1 (entlast))) ) (command "_.-group" "_create" "*" "" (entlast) ed_1 "") (setvar "orthomode" sv_ortho) (setvar "osmode" sv_osmd) (command "_.undo" "_end") ) ) ) ) (setvar "blipmode" blp) (setvar "cmdecho" 1) (prin1) ) 1 Quote
Tsuky Posted April 5 Posted April 5 On 4/5/2025 at 11:19 PM, BIGAL said: I would ask others to not post code, at some point learning how to do a simple lisp task is well worth while. Expand Oops sorry, I was writing my post... Quote
Cadkiller Posted April 6 Author Posted April 6 On 4/5/2025 at 11:24 PM, Tsuky said: I have this for a metric system, I don't know if it would be suitable for a foot system...! But it can be a start for you. (defun C:SLOPE ( / blp pt_o pt_f frac_prec sv_osmd e_last dxf_o slope slope_h slope_v nx sv_ortho pt_start pt_x t2_slope t1_slope pt_mid pt_text pt_int ed_1) (setvar "cmdecho" 0) (setq blp (getvar "blipmode")) (setvar "blipmode" 0) (initget 9) (setq pt_o (getpoint "\nSpecify the starting point: ")) (cond (pt_o (initget 41) (setq pt_f (getpoint pt_o "\nChoosing the end point: ")) (cond (pt_f (command "_.undo" "_group") (cond ((and (not (eq (getvar "USERI1") 1)) (not (eq (getvar "USERI1") 10)) (not (eq (getvar "USERI1") 100))) (initget "Unit Dozen Hundred") (setq frac_prec (getkword "\nFraction accuracy [Unit/Dozen/Hundred]<Dozen>: ")) (if (not frac_prec) (setq frac_prec "Dozen")) (cond ((eq frac_prec "Unit") (setq slope_v 1)) ((eq frac_prec "Dozen") (setq slope_v 10)) ((eq frac_prec "Hundred") (setq slope_v 100)) ) (setvar "USERI1" slope_v) ) (T (setq slope_v (getvar "USERI1"))) ) (setq sv_osmd (getvar "osmode")) (setvar "osmode" 0) (command "_.ray" pt_o pt_f "") (setq e_last (entlast) dxf_o (trans (cdr (assoc 11 (entget e_last))) 0 1 T) ) (entdel e_last) (setq slope (abs (if (zerop (cadr dxf_o)) 0.0 (/ (car dxf_o) (cadr dxf_o)))) slope_h (fix (* slope_v slope)) nx (if (zerop slope_h) 0 (gcd slope_h slope_v)) sv_ortho (getvar "orthomode") ) (while (> nx 1) (setq slope_h (/ slope_h nx) slope_v (/ slope_v nx) nx (gcd slope_h slope_v)) ) (setvar "orthomode" 1) (setq pt_start (mapcar '/ (mapcar '+ pt_o pt_f) '(2.0 2.0 2.0)) pt_start (list (car pt_start) (cadr pt_start) 0.0)) (initget 9) (setq pt_x (getpoint pt_start "\nSpecify the size of the symbol: ") pt_x (list (car pt_x) (cadr pt_x))) (if (equal (car pt_x) (car pt_start) 1E-12) (setq t2_slope (rtos slope_h 2 0) t1_slope (rtos slope_v 2 0)) (setq t2_slope (rtos slope_v 2 0) t1_slope (rtos slope_h 2 0)) ) (repeat 2 (command "_.dimordinate" pt_start "_text" t1_slope pt_x) (setq pt_mid (mapcar '/ (mapcar '+ pt_start pt_x) '(2.0 2.0 2.0))) (if (equal (car pt_x) (car pt_start) 1E-12) (setq pt_int (polar pt_x 0.0 (distance pt_start pt_x))) (setq pt_int (polar pt_x (/ pi 2.0) (distance pt_start pt_x))) ) (setq pt_start (inters pt_o pt_f pt_x pt_int nil) t1_slope t2_slope ) (if (null pt_start) (setq pt_start pt_x)) (setq pt_text (polar pt_mid (angle pt_start pt_x) (getvar "dimtxt")) ) (command "_aidimtextmove" "_2" (entlast) "" pt_text) (if (not ed_1) (setq ed_1 (entlast))) ) (command "_.-group" "_create" "*" "" (entlast) ed_1 "") (setvar "orthomode" sv_ortho) (setvar "osmode" sv_osmd) (command "_.undo" "_end") ) ) ) ) (setvar "blipmode" blp) (setvar "cmdecho" 1) (prin1) ) Expand Hi Tsuky, I tried AI to see if it can modify the code and this is what came back. I see yours doesn't include the angle, which i would like to have as well. How could the angle be added? This AutoLISP code appears to be for drawing a slope symbol and labeling it with a ratio (like 1:10). It prompts the user for a start and end point, calculates the slope, and then draws and labels it. To modify this code to work with imperial units, we need to consider what units are being used and how they are being represented. Based on the code, it seems the slope is calculated as a ratio without explicit unit measurements (like rise over run). The "Fraction accuracy" options (Unit, Dozen, Hundred) further suggest it's working with a unitless ratio. Therefore, directly converting units like meters to feet isn't applicable here. The code calculates a ratio, and that ratio remains the same regardless of the underlying units used to determine the start and end points. However, if you intend to interpret the drawn slope and its label as representing imperial units (e.g., a rise of 1 unit for every 10 units of run, where these units are now understood to be feet or inches), then the code itself doesn't need modification. The label will still be a ratio. Here's a breakdown of why direct unit conversion isn't needed and what you should consider: Slope as a Ratio: The core of the code calculates slope as the absolute ratio of the change in the Y-coordinate to the change in the X-coordinate ((/ (car dxf_o) (cadr dxf_o))). This ratio is unitless. slope_h and slope_v: These variables become the numerator and denominator of the slope ratio after being multiplied by slope_v (which is based on the "Fraction accuracy") and simplified by their greatest common divisor (GCD). These are also unitless numbers in the ratio. Labeling: The code uses rtos (real to string) to convert slope_h and slope_v into strings for the label. These strings represent the parts of the ratio. What you might need to adjust if your intention involves specific imperial units: User Interpretation: When you use this command after this point, you need to understand that the units you pick the start and end points in (e.g., feet or inches in your AutoCAD drawing) will be the basis for the slope ratio. If you pick points that are 1 foot apart horizontally and 0.1 feet apart vertically, the slope will be represented as a ratio (potentially simplified). Drawing Scale: Your AutoCAD drawing scale will determine the real-world distances represented by the units you are working in. The slope ratio will be accurate regardless of the scale, but the visual representation of the slope will be affected by it. If you did have code that explicitly dealt with measured lengths: If the original code had variables that stored lengths in metric units (e.g., length_m = 10.0), then you would need to convert those values to imperial units (e.g., length_ft = (* length_m 3.28084)). However, this specific C:SLOPE function doesn't appear to do this. In summary, to use this C:SLOPE command in an imperial drawing: Set your AutoCAD units to imperial (e.g., feet or inches). Use the SLOPE command and pick your start and end points based on your desired imperial units. The label generated will be a ratio based on the difference in the coordinates you picked, expressed as a simplified fraction (depending on the "Fraction accuracy" you choose). No direct modification of the AutoLISP code is necessary for it to be used in an imperial drawing context, as it deals with ratios, not explicit unit measurements. If you have other parts of your workflow or other code that do involve explicit metric measurements that you need to convert, please provide that code, and I can help you modify it. Sincerely, Edward Borg www.precisiondraftingllc.com https://www.facebook.com/MiscIronDetailer/ 40 Plus Years of Steel Construction Experience Quote
Cadkiller Posted April 6 Author Posted April 6 Plus, I would like the label to be dragged afterwards for placement with the line extension being adjustable. So, the label will be placed outside the line (like my image) and not centered like yours does. Quote
Cadkiller Posted April 6 Author Posted April 6 (edited) On 4/5/2025 at 11:24 PM, Tsuky said: Expand Okay I tried to modify the code with AI to base the ratio on 12 and got the following results. This line happened to be greater than 45 degrees, so the result is greater than 12 versus swapping the base of 12 from horizontal to vertical. Plus, it just gave me the results instead of providing a label to place. Here is the code it gave me. (defun C:SLOPE ( / blp pt_o pt_f frac_prec sv_osmd e_last dxf_o slope slope_h slope_v nx sv_ortho pt_start pt_x t2_slope t1_slope pt_mid pt_text pt_int ed_1 angle) ;; Turn off command echo and blip mode (setvar "cmdecho" 0) (setq blp (getvar "blipmode")) (setvar "blipmode" 0) ;; Get start point (setq pt_o (getpoint "\nSpecify the starting point: ")) (cond (pt_o ;; Get end point (setq pt_f (getpoint pt_o "\nSpecify the ending point: ")) (cond (pt_f (command "_.undo" "_group") ;; Set fraction precision (setq slope_v 12) ;; Fixed as 12-inch run for imperial standard ;; Get slope ratio (setq slope (abs (if (zerop (cadr pt_f)) 0.0 (/ (- (cadr pt_f) (cadr pt_o)) (- (car pt_f) (car pt_o))))) slope_h (fix (* slope_v slope)) nx (if (zerop slope_h) 0 (gcd slope_h slope_v)) ) ;; Simplify the ratio using GCD (while (> nx 1) (setq slope_h (/ slope_h nx) slope_v (/ slope_v nx) nx (gcd slope_h slope_v)) ) ;; Calculate angle in degrees (setq angle (atan slope)) (setq angle (* angle (/ 180.0 pi))) ;; Convert radians to degrees ;; Display slope ratio and angle (alert (strcat "Slope Ratio: " (rtos slope_h 2 0) ":" (rtos slope_v 2 0) "\nAngle: " (rtos angle 2 2) " degrees")) ;; Add other functionalities, like symbol creation and text placement, here. ) ) ) ) ;; Restore blip mode and command echo (setvar "blipmode" blp) (setvar "cmdecho" 1) (prin1) ) Edited April 7 by SLW210 Added Code Tags!! Quote
BIGAL Posted April 7 Posted April 7 Glad to see your having a go, some more hints you don't need to pick two points you can just pick a line, you can get the start and end properties. (setq ent (entsel "\npick a line ")) (setq entg (entget (car ent))) (setq startpt (cdr (assoc 10 entg))) (setq endpt (cdr (assoc 11 entg))) (setq ang (angle startpt endpt)) Ok now you have the 2 points but they are based on the drawn direction so your points may be in a reverse direction so you can do a check and this is what I use. You pick a line near an end so this sets a direction of the 2 points. (setq pt cadr ent)) (setq d1 (distance pt startpt)) (setq d2 (distance pt endpt)) (if (> d1 d2) (setq tmp startpt startpt endpt endpt tmp ) ) (setq ang (angle startpt endpt)) Pick a point form the endpt to get a distance away form the endpt to draw the angled line, get its end point, and work backwards from that for the other line work again using polar. Quote
SLW210 Posted April 7 Posted April 7 Please use Code Tags for your code in the future. (<> in the editor toolbar) Quote
Cadkiller Posted April 8 Author Posted April 8 Hi Bigal, Thanks for that information. How do I apply these codes you provided? Where should they be put in and what should be replaced? Sincerely, Edward Borg www.precisiondraftingllc.com https://www.facebook.com/MiscIronDetailer/ 40 Plus Years of Steel Construction Experience Quote
BIGAL Posted April 11 Posted April 11 I have done something and it looks at the 4 quadrants, the problem I have before I go any further is I need a real dwg as I need to match text styles etc. Can you please post one with before and after. Will fix dim on outside and offset from line work. Quote
Cadkiller Posted April 11 Author Posted April 11 Hi Bigal, Thanks for taking the time to help me with this. I greatly appreciate it! Not sure what you mean about before and after. I have attached a rail detail with and without these bevel labels. I see yours has the hypotenuse instead of the angle and the scale and text size seems to be off. Can the triangle be smaller and the text be bigger and the placement of the text be slightly off the line? Similar to how my initial image showed. Would it be based on the current scale and text style? Sincerely, Edward Borg www.precisiondraftingllc.com https://www.facebook.com/MiscIronDetailer/ 40 Plus Years of Steel Construction Experience R_4(R1).dwgFetching info... R_4.dwgFetching info... Quote
BIGAL Posted April 12 Posted April 12 Ok can see need to be 4" line with correct 12 as label understand, can do. the 3rd value is internal angle. Watch this space. Just a comment something wrong with label here are you manually drawing rather than say strcat two texts together ? Can do a lisp etc enter prefix enter suffix. 1-hss4 is result. Just have a custom text command. The prefix is remembered change at any time. Quote
Cadkiller Posted April 12 Author Posted April 12 Big Al, I’m not sure I understand. These drawings were created with SDS2 and the material is hyperlinked which is probably why the part mark is coming out of the selected linework. I probably should just sent you an AutoCAD drawing instead. Quote
BIGAL Posted Wednesday at 03:14 AM Posted Wednesday at 03:14 AM Almost there, have to fix up the text a bit. Will post soon. Quote
Cadkiller Posted Wednesday at 11:35 AM Author Posted Wednesday at 11:35 AM Thanks a bunch, Big Al It's looking very nice! Quote
BIGAL Posted Thursday at 04:20 AM Posted Thursday at 04:20 AM (edited) Give this a try pick end of line etc near where label is to appear, when asked. ; https://www.cadtutor.net/forum/topic/97227-bevel-slope-label/ ; draw bevl label ; By AlanH April 2025 (defun c:bevel ( / h0180 ah090 ah2700 ang d1 d2 dist dofracs dofracs endpt ht oldangdir oldcol oldsnap pt2 pt2a startpt tanang) ; thanks to lee-mac for this defun (defun csv->lst (str ans / pos ) (if (setq pos (vl-string-position ans str)) (cons (substr str 1 pos) (csv->lst (substr str (+ pos 2)) ans)) (list str) ) ) (defun dofracs ( / a ht1 ht2 ht3 ht4 frac) (setq frac (- ht (fix ht))) (setq frac (atof(rtos frac 2 3))) (if (> frac 0.0) (progn (setq txt (rtos ht 4 4)) (setq a (csv->lst txt 32)) (setq ht1 (car a)) (setq ht2 (csv->lst (cadr a) 47)) (setq ht3 (car ht2)) (setq ht4 (cadr ht2)) (setq httxt (strcat ht1 "{\\H0.70x;\\S" ht3 "#" ht4 ";}")) ) (setq httxt (rtos ht 2 0)) ) (princ) ) (DEFUN AH090 ( / angt ht mp pt3 pt4) (setq pt3 (polar pt2a (* pi (- 0.5)) dist)) (setq pt4 (polar pt3 pi 4.)) (command "line" startpt pt2 "") (command "line" pt2a pt3 "") (command "line" pt3 pt4 "") (setq ht (* 3. dist)) (setq angt (/ (* ang 180.0) pi)) (setq mp (mapcar '* (mapcar '+ pt2a pt3) '(0.5 0.5))) (setq mp (mapcar '+ mp '(0.25 0.0 0.0))) (dofracs) (command "mtext" mp "J" "ML" mp httxt "") (setq mp (polar pt3 pi 2.0)) (setq mp (mapcar '+ mp '(0.0 -0.25 0.0))) (command "text" "J" "TC" mp 1 0.0 "12") (setq mp (mapcar '* (mapcar '+ pt2a pt4) '(0.5 0.5))) (setq mp (mapcar '+ mp '(0.0 0.25 0.0))) (setvar 'angdir 0) (command "text" "J" "BC" mp 1 angt (rtos angt 2 2)) (princ) ) (DEFUN AH90180 ( / angt ht mp pt3 pt4) (setq pt3 (polar pt2a (* pi 1.5) dist)) (setq pt4 (polar pt3 0.0 4.)) (command "line" startpt pt2 "") (command "line" pt2a pt3 "") (command "line" pt3 pt4 "") (setq ht (* 3. dist)) (setq angt (/ (* (- pi ang) 180.0) pi)) (dofracs) (setq mp (mapcar '* (mapcar '+ pt2a pt3) '(0.5 0.5))) (setq mp (mapcar '+ mp '(-0.25 0.0 0.0))) (command "mtext" mp "J" "MR" mp httxt "") (setq mp (polar pt3 0.0 2.0)) (setq mp (mapcar '+ mp '(0.0 -0.25 0.0))) (command "text" "J" "TC" mp 1 0.0 "12") (setvar 'angdir 1) (setq mp (mapcar '* (mapcar '+ pt2a pt4) '(0.5 0.5))) (command "text" "J" "BC" mp 1 angt (rtos angt 2 2)) (princ) ) (DEFUN AH180270 ( / angt ht mp pt3 pt4 ) (setq pt3 (polar pt2a (* pi 0.5) dist)) (setq pt4 (polar pt3 0.0 4.)) (command "line" startpt pt2 "") (command "line" pt2a pt3 "") (command "line" pt3 pt4 "") (setq ht (* 3. dist)) (setq angt (/ (* (- ang pi) 180.0) pi)) (dofracs) (setq mp (mapcar '* (mapcar '+ pt2a pt3) '(0.5 0.5))) (setq mp (mapcar '+ mp '(-0.25 0.0 0.0))) (command "mtext" mp "J" "MR" mp httxt "") (setq mp (polar pt3 0.0 2.0)) (setq mp (mapcar '+ mp '(0.0 0.25 0.0 ))) (command "text" "J" "BC" mp 1 0.0 "12") (setvar 'angdir 0) (setq mp (mapcar '* (mapcar '+ pt2a pt4) '(0.5 0.5))) (setq mp (mapcar '+ mp '(0.0 -0.25 0.0 ))) (command "text" "J" "TC" mp 1 angt (rtos angt 2 2)) (princ) ) (DEFUN AH2700 ( / angt ht mp pt3 pt4 ) (setq pt3 (polar pt2a (* pi 0.5) dist)) (setq pt4 (polar pt3 pi 4.)) (command "line" startpt pt2 "") (command "line" pt2a pt3 "") (command "line" pt3 pt4 "") (setq ht (* 3. dist)) (setq angt (/ (* (- (* 2.0 pi) ang) 180.0) pi)) (dofracs) (setq mp (mapcar '* (mapcar '+ pt2a pt3) '(0.5 0.5))) (setq mp (mapcar '+ mp '(0.25 0.0 0.0 ))) (command "mtext" mp "J" "ML" mp httxt "") (setq mp (polar pt3 pi 2.0)) (setq mp (mapcar '+ mp '(0.0 0.25 0.0 ))) (command "text" "J" "BC" mp 1 0.0 "12") (setvar 'angdir 1) (setq mp (mapcar '* (mapcar '+ pt2a pt4) '(0.5 0.5))) (setq mp (mapcar '+ mp '(0.0 -0.25 0.0 ))) (command "text" "J" "TC" mp 1 angt (rtos angt 2 2)) (princ) ) ;; starts here (setq oldsnap (getvar 'osmode)) (setvar 'osmode 0) (setq oldcol (getvar 'cecolor)) (setvar 'cecolor "1") (setq oldangdir (getvar 'angdir)) (setvar 'textstyle "standard") (setvar 'textsize 1) (setvar 'clayer "User_annotation") (setq ent (entsel "\npick a line near end ")) (setq obj (vlax-ename->vla-object (car ent))) (setq startpt (vlax-curve-getstartPoint obj)) (setq endpt (vlax-curve-getEndPoint obj)) (setq pt1 (cadr ent)) (setq d1 (distance pt1 startpt)) (setq d2 (distance pt1 endpt)) (if (> d1 d2) (setq tmp startpt startpt endpt endpt tmp) ) (setq ang (angle endpt startpt)) (setq pt2 (polar startpt ang 6.5)) (setq pt2a (polar startpt ang 6.25)) (setq tanang (abs (/ (sin ang) (cos ang)))) (setq dist (abs (* 4. tanang))) (cond ((and (>= ang 0.0)(< ang (* pi 0.5)))(AH090)) ((and (> ang 1.5707964267949)(< ang pi ))(AH90180)) ((and (> ang 3.14160265358979)(< ang (* 1.5 pi )))(AH180270)) ((and (> ang 4.71239898038469)(< ang (* 2.0 pi )))(AH2700)) ) (setvar 'osmode oldsnap) (setvar 'cecolor oldcol) (setvar 'angdir oldangdir) (princ) ) (c:bevel) Edited yesterday at 04:05 AM by BIGAL Quote
Cadkiller Posted yesterday at 01:04 AM Author Posted yesterday at 01:04 AM Hi Big Al, I just tried your lisp and got the following error. Command: _appload Bevel-Label.lsp successfully loaded. Command: AutoCAD variable setting rejected: CLAYER "User_annotation" Command: Command: bevel AutoCAD variable setting rejected: CLAYER "User_annotation" Any idea why I'm getting this and how to fix it? Quote
BIGAL Posted yesterday at 03:34 AM Posted yesterday at 03:34 AM Remove this line (setvar 'clayer "User_annotation") set to what layer you want answer drawn on before running, the error may be that the layer does not exist. If you nominate a layer to be used can be added. I have updated the code above, so copy again, found a little bug to do with heights that were whole numbers and no fractions. Quote
Cadkiller Posted yesterday at 10:59 AM Author Posted yesterday at 10:59 AM Hey Big Al, I tried creating that layer and also try changing it and neither one worked. I get the same error message. Quote
