Hi, I’m trying to automate exporting a surface to an .xml file by creating a LISP function for it. But so far, no success... Can you tell me if this is even possible?
(defun ExportSurfaceToLandXML ( surfaceName saveFolder / C3D verstring prodstring datastr acadApp C3D civilDoc surfs landXMLTools surface filePath )
(vl-load-com)
; Example (ExportSurfaceToLandXML "TIN_example" "C:\\Users\\surfl\\Desktop\\New_folder")
(setq C3D (strcat "HKEY_LOCAL_MACHINE\\"
                    (if vlax-user-product-key
                      (vlax-user-product-key)
                      (vlax-product-key)
        C3D (vl-registry-read C3D "Release")
        verstring (substr C3D
                          1
                          (vl-string-search
                            C3D
                            (+ (vl-string-search "." C3D) 1)
        prodstring (strcat "AeccXUiLand.AeccApplication." verstring)
(setq datastr (strcat "AeccXLand.AeccTinCreationData." verstring))
(if (and (setq acadApp (vlax-get-acad-object))
           (setq C3D (vla-getinterfaceobject acadApp prodstring))
           (setq civilDoc (vla-get-activedocument C3D))
           (setq surfs (vlax-get civilDoc 'surfaces)))
    (if (not (vlax-property-available-p civilDoc "LandXMLTools"))
            (alert "This is not a Civil 3D document or LandXMLTools are not available!")
            (exit)
    ; Get LandXML tools
    (setq landXMLTools (vla-get-LandXMLTools civilDoc))
    ; Trying to find a surface by name
    (setq surface (vl-catch-all-apply
        '(lambda ()
            (vla-Item (vla-get-Surfaces landXMLTools) surfaceName)
    ; Checking if the surface is found
    (if (vl-catch-all-error-p surface)
            (alert (strcat "Surface with name '" surfaceName "' not found!"))
            (exit)
    ; Create a full path to the file
    (setq filePath (strcat saveFolder "\\" surfaceName ".xml"))
    ; Exporting the surface to LandXML
    (vl-catch-all-apply
        '(lambda ()
            (vla-ExportSurface surface filePath)
    ; Checking the success of export
    (if (vl-catch-all-error-p (vl-catch-all-apply '(lambda () (findfile filePath))))
        (alert (strcat "Error exporting surface to file: " filePath))
        (alert (strcat "The surface has been successfully exported to file: " filePath))
    ; Returning the path to the file
    filePath
); end of progn
); end of if
); end of defun
Most likely, I'm using the wrong Visual LISP functions.
This is similar but allows you to pick a surface and return its name, the vercheck does same as your get registry just a different variable name.
(ah:vercheck)  ; version check see vercheck.lsp
(if (not AT:ListSelect)(load "Listseelct"))
(vlax-for j (vlax-get *AeccDoc* 'SurfaceS)
(setq lst (cons (cons (vla-get-name j) j) lst))
;if length of surfaces more than 1 else skip pick  if  0 then msg and exit
(setq lenlst (length lst))
(if (= lenlst 0)
    (Getstring "\nYou have no surfaces press any key to exit")
    (exit)
(if (= lenlst 1)
  (setq surfacepick (car (nth 0 lst)))  ; pull surface out of dotted pair
(if (> lenlst 1)
  (setq surfacepick (car (AT:ListSelect
    "Set new surface "
    "Select surface name"
    10
    10
    "false"
    (vl-sort (mapcar (function car) lst) '<)
  ) ; end progn
) ;end if
(setq lst2 lst)     ; make answer returned list2
listselect.lspFetching info...
