How to force running commands in the created drawing ?
Or my setup.
I can open a drawing and insert a point, Zoom>Extents and the dot shows in the middle.
Using the original Code I have to change the point type then Zoom>Extents works.
I don't really have time or need to track down the issue.
QNEW opens the Template referenced in QNEW so SysVars would be set and known.
I see no reason to go about this in the manner desired by the OP and the OP seems determined to do things the hard way.
  On 4/9/2025 at 6:57 AM, GLAVCVS said:
@pkenewell Does this really work?
Have you tried it?
Expand
Yes - I have actually used this technique in the past. I don't know if I have any code currently to show you (this was a long time ago) - but I know it works.
