Selecting Dynamic Blocks and Activating Action Parameters.
Is it possible to select dynamic blocks and activate action parameters...  similar to Shift+left click on block grips?
(defun c:foo ()
  (vl-load-com)
  (setq ssTestSet (ssadd))
  (princ "\nSelect Test block(s): ")
  (setq ss (ssget '((0 . "INSERT")(2 . "`*U*"))))
  (if ss
      (setq ssTestBlocks '())
      (setq i 0)
      (repeat (sslength ss)
        (setq blkRef (ssname ss i)
              effname (vla-get-EffectiveName (vlax-ename->vla-object blkRef))
              i  (+ i 1))
        (if (= (strcase effname) "TEST")
            (ssadd blkRef ssTestSet)
      (if ssTestSet
          (sssetfirst nil ssTestSet)
          ;Add Activate Position1 action parameter Code Here
          ;Similar to Shift+left click on grips
        (princ "\nNo blocks named 'Test' were found.")
    (princ "\nNo blocks found with names starting with '*U*'.")
foo_ActionParameter.dwg
The scenario on the right is what I'm looking for.
I don't understand what you're trying to achieve
I want to grab Postion1 for all the blocks selected and then allow the user to relocate all Positions1 in one go.
Ok 1st step is get a copy of this program by Lee Mac, https://lee-mac.com/dynamicblockfunctions.html
You want to change the values of Position1_X & _Y, this can be done using Lee's code.
;; Set Dynamic Block Property Value  -  Lee Mac
;; Modifies the value of a Dynamic Block property (if present)
;; blk - [vla] VLA Dynamic Block Reference object
;; prp - [str] Dynamic Block property name (case-insensitive)
;; val - [any] New value for property
;; Returns: [any] New value if successful, else nil
(defun LM:setdynpropvalue ( blk prp val )
Also look at LM:getdynpropvalue so get the current value and +- to that value.
Have a go if you get stuck we are here.
Edited by BIGAL
I selected both dumb blocks and dynamic blocks at all of the clickable points. I still don't understand what you speak of by saying
"similar to Shift+left click on block grips?".
I was curious that I missed out on something, but didn't see anything...
Do you have a loaded tool that lets you Shift + left click on a grip that does something that the rest of us don't have?
If those were circles and lines then you could use the stretch command like so:
I got it.
This is what you want, I  think.
;;  GET
;; Get Dynamic Block Property Value  -  Lee Mac
;; Returns the value of a Dynamic Block property (if present)
(defun LM:getdynpropvalue ( blk prp )
    (setq prp (strcase prp))
    (vl-some '(lambda ( x ) (if (= prp (strcase (vla-get-propertyname x))) (vlax-get x 'value)))
        (vlax-invoke blk 'getdynamicblockproperties)
;; Get Dynamic Block Property Allowed Values  -  Lee Mac
;; Returns the allowed values for a specific Dynamic Block property.
;; Returns: [lst] List of allowed values for property, else nil if no restrictions
(defun LM:getdynpropallowedvalues ( blk prp )
    (vl-some '(lambda ( x ) (if (= prp (strcase (vla-get-propertyname x))) (vlax-get x 'allowedvalues)))
;;  SET
    (vl-some
       '(lambda ( x )
                    (vla-put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x))))
                    (cond (val) (t))
(defun c:foo ( / ssTestSet ss i ssTestBlocks blkRef effname src_ props ps pe)  ;; you need to declare the local variables like this.
  (vl-load-com)
  (if ss
      (setq i 0)
              i  (+ i 1))
      (if ssTestSet
		;; USER selects 2 points
		   (princ "\nMove the dynamic points, pick start point and end point: ")
		   (while (setq ps (getpoint "\nStart point (or press Enter): "))
			   (setq pe (getpoint ps "\nEnd point: "))
				(setq i 0)
					(setq src_ (vlax-ename->vla-object (ssname ss i)))
					(setq props (list
						(LM:getdynpropvalue src_ "Position1 X" )
						(LM:getdynpropvalue src_ "Position1 Y" )
					(setq pol_x (nth 0 (polar props (angle ps pe) (distance ps pe) )))
					(setq pol_y (nth 1 (polar props (angle ps pe) (distance ps pe) )))
					(LM:setdynpropvalue src_ "Position1 X" pol_x)
					(LM:setdynpropvalue src_ "Position1 Y" pol_y)
					(setq i (+ i 1))
What's a little different from what you expect:
You don't actually get to move one of the dynamic positions.  Instead you give 2 points.
You can pick a point startting from one of the blocks, but you don't have to.
I put it in a WHILE loop
EDIT:
Thinking about it... I can use this code myself.
I just need to remove the part where it only works on blockname "TEST" and parameter "Position1"
Edited by Emmanuel Delay
I'm made a change so we are using the filtered selection set instead of the original selection, and check the length of filtered set is greater than zero.
;;  GET
;;  https://www.lee-mac.com/
;;  SET
    (vl-some
       '(lambda ( x )
                    (cond (val) (t))
  (vl-load-com)
  (if ss
      (setq i 0)
              i  (+ i 1))
      (if (> (sslength ssTestSet) 0)
            (setq i 0)
            (repeat (sslength ssTestSet)
              (setq src_ (vlax-ename->vla-object (ssname ssTestSet i)))
              (setq props (list
              (setq i (+ i 1))
Yes, I don't know how to detect changes of dynamic props.
Anyone, feel free to help me/us here.
I can see insert the block multiple times, but how do you determine where the end points will end up ? In your sample you have 3 left 1 right. You could insert the block one at a time and imply the X & Y offset from the insert point. For me a dcl would pop up with input X & Y so say X for each insert remains the same. As I suggested to change the block you can select one or more and change the position_X or Y, another option would be to say match X or match Y for multiple blocks.
