NicuT Posted Wednesday at 07:51 AM Posted Wednesday at 07:51 AM (edited) Hello everyone. Can you help me to convert a .lsp file into a .scr file? Below, you will find the .lsp file (quick selection - multiple objects and set to a specific layer). I want to use the .scr file with ScriptPro for multiple .dwg files. (defun C:DOIT () (command "_.chprop" (ssget "_X" '((0 . "Mtext,Multileader") )) "" "_layer" "G-ANNO-TXNT" "") ) Edited Wednesday at 10:16 AM by SLW210 Added Code Tags!! Quote
SLW210 Posted Wednesday at 10:17 AM Posted Wednesday at 10:17 AM In the future please use Code Tags for your code. (<> in the editor toolbar) I have created a new thread for your inquiry. Convert a .lsp file into a .scr file Quote
Lee Mac Posted Wednesday at 05:18 PM Posted Wednesday at 05:18 PM There's no need to convert it, you can load & call it from a Script file, e.g. the script could be as simple as: (load "YourLISPFile.lsp" nil) (if c:doit (c:doit)) Quote
NicuT Posted Wednesday at 06:53 PM Author Posted Wednesday at 06:53 PM Thank you for reply Lee. I will try tomorrow. I'm sure it will work . Quote
BIGAL Posted Thursday at 01:33 AM Posted Thursday at 01:33 AM As the lisp is super short why not just save it as Doit.lsp but remove 1st and 3rd line, then when you load, it will just run. Or add (c:DOIT) as a last line then it will run when you do the (load "DOIT") Quote
