Best place to purchase AutoCAD LT
I had to build a new PC and when I tried to transfer over my AutoCAD LT 2012 I quickly found out that Autodesk no longer supports it and there is no way to use it moving forward.  Thus I am forced to now go to the subscription route.  Anyway, where is the best place to buy the license?
- Direct from AutoCAD its $515/year
- YourCADStore has it for $399.95 (assuming that is for 12 months also)
Those seem to be the only legit option (assuming YourCADStore is a legit store front and the Groupon option for $83.44 is some sort of scam).  Thanks for any advice.
Have a look at Bricscad you can buy a perpetual or a yearly, has more features than Lt2026, no missing lisp functions, using lisps you will never look back at how much time savings you will get.
No I haven't looked at Briscad.  I just do a little work on the side from time to time for someone I formally worked with.  They use AutoCAD.  Does it cause any issues working in DWG files and translating back and forth?  Is there a learning curve between it and AutoCAD?
Bricscad and Autocad are virtually identical, so there's no learning curve. If you know Autocad you can use Bricscad. They have a trial version. You should download and check it out. https://www.bricsys.com/
