Lee Mac Posted April 22, 2009 Share Posted April 22, 2009 Sorry dude - as usual I forgot to load the Visual LISP functions (vl-load-com). I normally include it in my ACADDOC.lsp to automatically load the VL functions on start-up, but this means that when I test the lisps I post, I never notice that I have missed it My sincere apologies. (defun c:elab (/ *error* ovar vlst doc spc ePt tPt tStr) [color=Red][b](vl-load-com)[/b][/color] (defun *error* (msg) (if ovar (mapcar 'setvar vlst ovar)) (if (not (member msg '("Function cancelled" "quit / exit abort"))) (princ (strcat "\nError: " msg)) (princ "\n<<-- cancelled -->>")) (princ)) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)) spc (if (zerop (vla-get-activespace doc)) (if (= (vla-get-mspace doc) :vlax-true) (vla-get-modelspace doc) (vla-get-paperspace doc)) (vla-get-modelspace doc))) (setq vlst '("CLAYER" "DIMZIN") ovar (mapcar 'getvar vlst)) (setvar "DIMZIN" 1) (if (not (tblsearch "LAYER" "ELEVTEXT")) (vla-put-color (vla-add (vla-get-Layers doc) "ELEVTEXT") acYellow) (setvar "CLAYER" "ELEVTEXT")) (if (not (tblsearch "BLOCK" "eMark")) (Make_Block "eMark" (getvar 'TEXTSIZE))) (while (setq ePt (getpoint "\nSelect Elevation Point: ")) (Put_Block (trans ePt 1 0) "eMark" "ELEVTEXT") (setq tPt (polar (trans ePt 1 0) 0 (* 2.5 (getvar "TEXTSIZE")))) (Make_Text tPt "T.O. STEEL" 0.0 1) (setq tStr (strcat "ELEV: " (rtos (cadr (trans ePt 1 0)) 4 4))) (Make_Text tPt tStr 0.0 3)) (mapcar 'setvar vlst ovar) (princ)) (defun Make_Text (pt val rot flag) (entmake (list (cons 0 "TEXT") (cons 8 "ELEVTEXT") (cons 10 pt) (cons 40 (getvar "TEXTSIZE")) (cons 1 val) (cons 50 rot) (cons 7 (getvar "TEXTSTYLE")) (cons 71 0) (cons 72 0) (cons 73 flag) (cons 11 pt)))) (defun Make_Block (Nme Rad) (entmake (list (cons 0 "BLOCK") (cons 2 Nme) (cons 10 (list 0 0 0)) (cons 70 0))) (entmake (list (cons 0 "CIRCLE") (cons 8 "0") (cons 10 (list 0 0 0)) (cons 40 Rad))) (entmake (list (cons 0 "LINE") (cons 8 "0") (cons 10 (list 0 (* 2 Rad) 0)) (cons 11 (list 0 (* -2 Rad) 0)))) (entmake (list (cons 0 "LINE") (cons 8 "0") (cons 10 (list (* -2 Rad) 0 0)) (cons 11 (list (* 2 Rad) 0 0)))) (entmake (list '(0 . "HATCH") '(100 . "AcDbEntity") '(8 . "0") '(62 . 2) '(100 . "AcDbHatch") '(10 0 0 0) '(210 0 0 1) '(2 . "SOLID") '(70 . 1) '(71 . 0) '(91 . 1) '(92 . 7) '(72 . 1) '(73 . 1) '(93 . 3) '(10 0 0 0) '(42 . 0) (cons 10 (list 0 (* -1 Rad) 0)) '(42 . 0.414214) (cons 10 (list Rad 0 0)) '(42 . 0) '(97 . 0) '(75 . 0) '(76 . 1) '(47 . 0.0334902) '(98 . 1) '(10 4.67389 5.69586 0.0))) (entmake (list '(0 . "HATCH") '(100 . "AcDbEntity") '(8 . "0") '(62 . 2) '(100 . "AcDbHatch") '(10 0 0 0) '(210 0 0 1) '(2 . "SOLID") '(70 . 1) '(71 . 0) '(91 . 1) '(92 . 7) '(72 . 1) '(73 . 1) '(93 . 3) (cons 10 (list 0 Rad 0)) '(42 . 0.414214) (cons 10 (list (* -1 Rad) 0 0)) '(42 . 0) '(10 0 0 0) '(42 . 0) '(97 . 0) '(75 . 0) '(76 . 1) '(47 . 0.0334902) '(98 . 1) '(10 4.67389 5.69586 0.0))) (entmake (list (cons 0 "ENDBLK") (cons 8 "0")))) (defun Put_Block (pt Nme lay) (entmake (list (cons 0 "INSERT") (cons 8 lay) (cons 2 Nme) (cons 10 pt)))) Quote Link to comment Share on other sites More sharing options...
Bill Tillman Posted April 23, 2009 Author Share Posted April 23, 2009 The UCS change feature was not quite right. I think I resolved it by changing the line (setq tStr (strcat "ELEV: " (rtos (cadr (trans ePt 1 0)) 4 4))) to read (setq tStr (strcat "ELEV: " (rtos (cadr (trans ePt 0 2)) 4 4))) This seems to make it work the way I want it to now. And thanks, I haven't had the time to look over your code for drawing and hatching the elevation symbol on the fly but I will examine that in detail as it will be very helpfull for other tasks as well. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 23, 2009 Share Posted April 23, 2009 Glad you got it working Bill - I think the (trans 0 2) is needed for working in paperspace.. but I might be wrong. If you do have any further questions on how the code is put together, just shout. Lee Quote Link to comment Share on other sites More sharing options...
