Oasis Posted January 8, 2008 Share Posted January 8, 2008 I'm using Autocad Architecture 2008. Initially, when I used the data extraction wizard and inserted a data extraction table in the drawing, the table would automatically update changes to the counts of blocks (with attributes) in the drawing when I saved. For some reason, it is no longer performing automatic updates. I tried the command DXEVAL with a setting of 2 and then saving, but even if I select Update All, the count doesn't update. I also had no luck right clicking the count cells in the data extraction table and doing a data extraction\update data extraction. Can anyone tell me what I'm doing wrong or what setting I changed by mistake? Quote Link to comment Share on other sites More sharing options...
CADken Posted January 8, 2008 Share Posted January 8, 2008 have you tried exploring "LISP" functions? sorry, i'm not an Arch guy... Quote Link to comment Share on other sites More sharing options...
Oasis Posted January 8, 2008 Author Share Posted January 8, 2008 Haven't tried writing a LISP for this--are you suggesting this would be a better way than the data extraction? Quote Link to comment Share on other sites More sharing options...
stpandi Posted November 6, 2008 Share Posted November 6, 2008 Use block& reference menu and extract data command.Also select the current drawing for block extraction wizard br stp Quote Link to comment Share on other sites More sharing options...
