Discus84 Posted March 28 Posted March 28 HI, I have an object in modelspace and a corresponding paperspace layout. I'd like to copy model space object along with the paperspace layout . The result would be two paperspaces, two modelspace objects , but I'd keep all the dimensions, anno etc. Thanks, Lu Quote
BIGAL Posted March 28 Posted March 28 I would just have the 2 dwgs open, select objects in MS then Ctrl+c go to other dwg use Edit Paste to orginal coordinates, repeat for the layouts. In the time it took me to type this I am slow the task was done. 1 Quote
Discus84 Posted March 29 Author Posted March 29 (edited) Hi, Almost good except: there, in the original coordinates is the same MS object , projected to the same PS layouts. If there was a way to move MS items with their corresponding PS layouts then a copy paste would work. Thanks for reply. Edited March 29 by Discus84 Quote
BIGAL Posted March 29 Posted March 29 (edited) "Edit, Paste to original coordinates" Copy & paste Model Copy & Paste layout Copy & Paste layout Edited March 29 by BIGAL 1 Quote
