Accessing nested blocks objects
p7q
I'm trying to access all entities inside a selected block reference.
However, the block might contain nested blocks (blocks within blocks, and so on, potentially many levels deep).
I need a way to recursively get all the entities, including those inside nested blocks.
Could anyone help me with how to approach this or share a sample code snippet?
Thanks in advance!
Here's a simple example -
(defun getblockentities ( blk / ent enx rtn )
    (if (setq ent (tblobjname "block" blk))
        (while (setq ent (entnext ent))
            (setq enx (entget ent))
            (if (= "INSERT" (cdr (assoc 0 enx)))
                (setq rtn (append (reverse (getblockentities (cdr (assoc 2 enx)))) rtn))
                (setq rtn (cons ent rtn))
    (reverse rtn)
(getblockentities "YourBlock")
Edited by Lee Mac
    (reverse rtn)
Thanks Lee for the sample function!
I noticed that this code retrieves only the entities inside the nested blocks, but it doesn't include the nested block references (INSERT entities) themselves.
For example, if my main block contains two nested blocks, and each of those has 3 entities inside, this function returns 6 entities — but I also need the two INSERT entities representing the nested blocks themselves.
So in total, I would expect 8 entities: 2 nested blocks (as INSERTs) + 6 entities inside them.
How can I modify the function to include the INSERTs (nested blocks) themselves as well?
Thanks again!
Edited by p7q
51 minutes ago, Lee Mac said:
I'll let you work that out ;)
I made it 🥳
(defun getblockentities (blk / ent enx rtn)
	    (setq rtn (cons ent rtn))	; INSERT objesini ekle
	    (setq rtn
		   (append
		     rtn
	  (setq rtn (cons ent rtn))	; Diğer nesneleri doğrudan ekle
    (reverse rtn)
Thanks Lee for encouragement.
Well done 👍
An alternative would be to move (setq rtn (cons ent rtn)) outside of the if statement, e.g.:
                  enx (entget ent)
    (reverse rtn)
