pefi Posted March 26, 2025 Posted March 26, 2025 I need to apologise first, the issue seems to be so trivial that I should have is solved in a few minutes. Yet, I keep fighting for the last 2 h without any good results. I need to set attribute value in an existing dynamic block. I started with "how can I read the attributes" and failed badly. After abusing an AI system I got the code: (defun c:get_dba (/ ss blkRef vlaBlock attArray att) (setq ss (ssget '((0 . "INSERT")))) (if ss (progn (setq blkRef (ssname ss 0)) (setq vlaBlock (vlax-ename->vla-object blkRef)) (setq attArray (vla-getattributes vlaBlock)) ;; Loop through the attributes and print their names and values (foreach att attArray ;looping through the array that way doesn't work (princ (strcat "\nAttribute Name: " (vla-get-TagString att))) (princ (strcat " | Value: " (vla-get-TextString att))) ) ) (princ "\nNo block selected.") ) (princ) ) I need to find i.e. TYPE and set it to AAA. The watch tree for attArray: Any hints how can I: 1. Make the code to read the attributes 2. Set the attribute to AAA I'm OK with the old school LISP, but the VL stuff beats me... Quote
Lee Mac Posted March 26, 2025 Posted March 26, 2025 I hate spending time correcting AI-generated code, but the first thing that sticks out is that the following: (setq attArray (vla-getattributes vlaBlock)) Will return a safearray variant, which cannot be iterated directly using foreach. Instead, you can use: (setq attArray (vlax-invoke vlaBlock 'getattributes)) Which will return the data using native data types, i.e. a list. You can find more examples here. 2 Quote
pefi Posted March 26, 2025 Author Posted March 26, 2025 (edited) Thank you Lee Mac!! I'm not sure if the AI is doing more good or bad stuff. I used to dig deep, learn, write code, debug, done. Now, ask AI, clean the rubbish, ask again, clean more rubbish... Sometimes it works and sometimes it's sending you straight into a ditch, but in a way that is not easily recognisable unless you're an expert. Gone testing, I'll report back. Edit: your suggestion was 10/10 Attribute Name: FUNC_DESIG | Value: XV Attribute Name: SEQ_NO | Value: XXXX Attribute Name: BMS | Value: Attribute Name: INSTR-TYP-DETAIL-NO | Value: 1 Attribute Name: FUNCTION | Value: ######## Attribute Name: TAG | Value: Attribute Name: SIZE | Value: Attribute Name: SYSTEM | Value: Attribute Name: NOTE | Value: Attribute Name: TYPE | Value: fghfh Attribute Name: VENDOR | Value: Attribute Name: DWG | Value: I hope I can handle setting them to a new value.... Edit2: Just in case someone has the same problem. This sets the attribute vale based on attribute name (if (eq (vla-get-TagString att) "TYPE")(vla-put-TextString att "AAA")) Edited March 26, 2025 by pefi report back Quote
BIGAL Posted March 26, 2025 Posted March 26, 2025 Just a comment when you get the attributes as a list you can edit any attribute by its position in the list so don't need a Tag name search. (nth 9 atts) is "TYPE" the 1st item in a list is (nth 0 .Sometimes its easier to do it this way. 1 Quote
Lee Mac Posted March 26, 2025 Posted March 26, 2025 11 minutes ago, BIGAL said: Just a comment when you get the attributes as a list you can edit any attribute by its position in the list so don't need a Tag name search. (nth 9 atts) is "TYPE" the 1st item in a list is (nth 0 .Sometimes its easier to do it this way. Personally I wouldn't rely on the attribute order unless absolutely necessary (i.e. when faced with duplicate attribute tags). 1 Quote
pefi Posted March 27, 2025 Author Posted March 27, 2025 (edited) Thank you again! I need something that will survive block definition modification and I have no control over the drawings, but I can be sure there will be no attribute duplicates. We're in the process of changing the block definitions (adding more attributes) and the drawings are a data source for some data extract software, so duplicates are not going to happen. Edited March 27, 2025 by pefi Quote
