I'm trying to write an Autolisp code to underlay images. It's built around the "-attach" command. When attaching a PDF you're asked for a page number (even if there's only one). I want my code to skip this step if there's only one page, default to 1 if there's more than one page & then default to 2, 3 etc. for multiple pages until there are no more (when it will go back to the select file dialogue). Problem is I cannot find how to check how many pages there are on the PDF. If, within AutoCAD, you type ? for page number then *, it lists all the pages, so AutoCAD can definitely check this before inserting the PDF, but I can't find any way of accessing this info. Any ideas?
Getting the pages is the tricky part. Give this a try:
EDIT - Oh - this might not work since you have AutoCAD LT - no com access - sorry! I don't know if someone else has another method of getting the number of pages without accessing the windows shell?
(defun c:pdfQatt (/ f pg)
   (if (setq f (getfiled "Select a PDF file to Attach" "" "pdf" 4))
         (if (/= (setq pg (cdr (assoc "Pages" (GetFileInfo f)))) "1")
            (setq pg (getint (strcat "Enter Page # (Total Pages: " pg ")")))
            (setq pg 1)
         (command "._-attach" f pg pause 1.0 0.0)
;;      Get a file's extended properties (Title, Subject, Category ...)
;;      returning the result as a list of cons pairs:
;;      Example:
;;         (   ("Name" . "Drawing.dwg")
;;             ("Size" . "42 KB")
;;             ("Type" . "DWG File")
;;             ("Date Modified" . "2011/03/21 10:57 AM")
;;    Original Author: Michael Pucket
;;    https://www.theswamp.org/index.php?topic=38072.0
(defun GetFileInfo ( file / result shell name_space items item )
    (vl-load-com)
    (vl-catch-all-apply
        (function
            (lambda ( / folder_name file_name i count )
                (setq
                    folder_name (vl-filename-directory file)
                    file_name   (strcat (vl-filename-base file) (vl-filename-extension file))
                    shell       (vlax-create-object "Shell.Application")
                    name_space  (vlax-invoke shell 'NameSpace folder_name)
                    items       (vlax-invoke name_space 'Items)
                    item        (vlax-invoke name_space 'ParseName file_name)
                    i           (setq count 300)
                (if item
                    (repeat count
                        (setq result
                            (cons
                                (cons
                                    (vlax-invoke name_space 'GetDetailsOf items (setq i (1- i)))
                                    (vlax-invoke name_space 'GetDetailsOf item i)
                                result
    (vl-catch-all-apply 'vlax-release-object (list item))
    (vl-catch-all-apply 'vlax-release-object (list items))
    (vl-catch-all-apply 'vlax-release-object (list name_space))
    (vl-catch-all-apply 'vlax-release-object (list shell))
    (vl-remove-if
        (function (lambda (item) (eq "" (car item))))
        result
Edited by pkenewell
    (vl-load-com)
    (vl-catch-all-apply
        (function
                (setq
                    i           (setq count 300)
                (if item
                    (repeat count
                        (setq result
                            (cons
                                (cons
                                result
    (vl-remove-if
        result
Expand
This function was originally written by the late great Michael Puckett -
  • Like 2
  On 3/25/2025 at 10:44 PM, Lee Mac said:
Here's an old function to determine the number of pages in a PDF file -
https://www.theswamp.org/index.php?topic=39001.msg441632#msg441632
Expand
Unfortunately. The OP is using AutoCAD LT 2025; I don't think this would work for him either since it makes a call to (vlax-create-object). I realized the same problem with the code I provided, as I stated in my original post.
  On 3/26/2025 at 8:43 PM, ronjonp said:
I really miss that guy. ;/ He was such a witty kind person and one of the most talented lisp programmers I knew.
Expand
Ditto. I never knew it was possible to genuinely grieve the loss of someone you'd never met in person, but when I see an old post of his I'm reminded of just how much he contributed to the community and how much I miss our conversations.
  • Agree 1
