Nikon Posted March 21 Posted March 21 Help me fix the errors. The division operation is not highlighted When selecting MTEXT, the code returns an error: invalid argument type: stringp nil. ;************************ (defun getNumericValue (ent / edata val str1 str3) (setq edata (entget ent)) (cond ;; TEXT ((equal (cdr (assoc 0 edata)) "TEXT") (setq val (cdr (assoc 1 edata)))) ;; MTEXT ((equal (cdr (assoc 0 edata)) "MTEXT") (setq str1 (cdr (assoc 1 edata))) (setq str3 (cdr (assoc 3 edata))) (setq val (strcat str1 str3)) ) (T (setq val "0") ) ) (atof val) ) ;***************** (defun c:CalcTwoTxt ( / lastOp prompt op ent1 ent2 v1 v2 result inspt validOps) (setq validOps '("*" "+" "-" "/")) (setq lastOp (getenv "CALC_TXT_LAST_OP")) (setq prompt (strcat "\nSelect an operation [*/+/-//] <" (if lastOp lastOp "") ">: ")) (setq op (getstring "\nSelect an operation [*/+/-//]: ")) (if (= op "") (setq op lastOp)) (if (not (member op validOps)) (progn (alert "An invalid operation. The operation is used \"+\".") (setq op "+") ) ) (setenv "CALC_TXT_LAST_OP" op) (setq ent1 (car (entsel "\nSelect the first text or MTEXT: "))) (if (null ent1) (exit)) (setq ent2 (car (entsel "\nSelect the second text or MTEXT: "))) (if (null ent2) (exit)) (setq v1 (getNumericValue ent1)) (setq v2 (getNumericValue ent2)) (cond ((= op "*") (setq result (* v1 v2))) ((= op "+") (setq result (+ v1 v2))) ((= op "-") (setq result (- v1 v2))) ((= op "/") (if (zerop v2) (setq result 0.0) (setq result (/ v1 v2)) ) ) (T (setq result 0.0)) ) (setq inspt (getpoint "\nSpecify the insertion point of the result: ")) (if (null inspt) (exit)) (command "_.TEXT" inspt "2.5" "0" (rtos result 2 2) "") (princ) ) Quote
GLAVCVS Posted March 21 Posted March 21 Since it's not a text string and you want to concatenate it with '(cdr (assoc 1 edata))', it gets 'indigestible' and 'erupts': stringp nil' 1 Quote
Nikon Posted March 21 Author Posted March 21 2 minutes ago, GLAVCVS said: Since it's not a text string and you want to concatenate it with '(cdr (assoc 1 edata))', it gets 'indigestible' and 'erupts': stringp nil' And how to write it correctly in the code? Quote
marko_ribar Posted March 21 Posted March 21 Whereever in the code occurs v1 or v2, change them to (atof v1) and (atof v2)... 1 1 Quote
GLAVCVS Posted March 21 Posted March 21 I see Marko probably already knows the problem and the solution. But if not, what do you hope to achieve with '(cdr (assoc 3 edata))'? Quote
Nikon Posted March 21 Author Posted March 21 12 minutes ago, GLAVCVS said: But if not, what do you hope to achieve with '(cdr (assoc 3 edata))'? Most of the texts are stored in code group 1, but if they are longer than 250 characters, the additional text goes to code group 3. (setq str1 (cdr (assoc 1 edata))) (setq str3 (cdr (assoc 3 edata))) ; it can be nil if there are no additional lines. But I'm not sure if this is correct. Quote
GLAVCVS Posted March 21 Posted March 21 I think the quickest way to clarify this is to attach a drawing. Quote
Nikon Posted March 21 Author Posted March 21 (edited) 4 hours ago, marko_ribar said: Whereever in the code occurs v1 or v2, change them to ( atof v1) and (atof v2)... error: syntax error ;************************ (defun getNumericValue (ent / edata val str1 str3) (setq edata (entget ent)) (cond ;; TEXT ((equal (cdr (assoc 0 edata)) "TEXT") (setq val (cdr (assoc 1 edata)))) ;; MTEXT ((equal (cdr (assoc 0 edata)) "MTEXT") (setq str1 (cdr (assoc 1 edata))) (setq str3 (cdr (assoc 3 edata))) (setq val (strcat str1 str3)) ) (T (setq val "0") ) ) (atof val) ) ;***************** (defun c:CalcTwoTxt ( / lastOp prompt op ent1 ent2 atof v1 atof v2 result inspt validOps) (setq validOps '("*" "+" "-" "/")) (setq lastOp (getenv "CALC_TXT_LAST_OP")) (setq prompt (strcat "\nSelect an operation [*/+/-//] <" (if lastOp lastOp "") ">: ")) (setq op (getstring "\nSelect an operation [*/+/-//]: ")) (if (= op "") (setq op lastOp)) (if (not (member op validOps)) (progn (alert "An invalid operation. The operation is used \"+\".") (setq op "+") ) ) (setenv "CALC_TXT_LAST_OP" op) (setq ent1 (car (entsel "\nSelect the first text or MTEXT: "))) (if (null ent1) (exit)) (setq ent2 (car (entsel "\nSelect the second text or MTEXT: "))) (if (null ent2) (exit)) (setq (atof v1) (getNumericValue ent1)) (setq (atof v2) (getNumericValue ent2)) (cond ((= op "*") (setq result (* (atof v1) (atof v2)))) ((= op "+") (setq result (+ (atof v1) (atof v2)))) ((= op "-") (setq result (- (atof v1) (atof v2)))) ((= op "/") (if (zerop (atof v2)) (setq result 0.0) (setq result (/ (atof v1) (atof v2))) ) ) (T (setq result 0.0)) ) (setq inspt (getpoint "\nSpecify the insertion point of the result: ")) (if (null inspt) (exit)) (command "_.TEXT" inspt "2.5" "0" (rtos result 2 2) "") (princ) ) Edited March 21 by Nikon (atof v1) (atof v2) Quote
Nikon Posted March 21 Author Posted March 21 5 minutes ago, GLAVCVS said: I think the quickest way to clarify this is to attach a drawing. I have simple operations with numbers, the drawing will not clarify anything. Quote
GLAVCVS Posted March 21 Posted March 21 19 minutes ago, Nikon said: Tengo operaciones sencillas con números, el dibujo no me aclara nada. Quote
marko_ribar Posted March 21 Posted March 21 Nikon, you forgot to add open and closing brackets for v1 and v2... Like I said it should be : (atof v1) and (atof v2)... 1 1 Quote
Nikon Posted March 21 Author Posted March 21 (edited) 47 minutes ago, marko_ribar said: Nikon, you forgot to add open and closing brackets for v1 and v2... Like I said it should be : (atof v1) and (atof v2)... Unfortunately, error: syntax error Edited March 21 by Nikon Quote
Steven P Posted March 21 Posted March 21 In numerical functions, this: ;; TEXT ((equal (cdr (assoc 0 edata)) "TEXT") (setq val (cdr (assoc 1 edata)))) ;; MTEXT ((equal (cdr (assoc 0 edata)) "MTEXT") (setq str1 (cdr (assoc 1 edata))) (setq str3 (cdr (assoc 3 edata))) (setq val (strcat str1 str3)) ) could probably be just ;; TEXT ((equal (cdr (assoc 0 edata)) "*TEXT") (setq val (cdr (assoc 1 edata))) ) reason being in text. assoc 3 comes into things if the text string is over 256 characters long... which is a very very big number. 1 Quote
Steven P Posted March 21 Posted March 21 (edited) Cold try this as a modification, keeping your method: Putting getNumericValue as a subroutine (I find that better for these forum LISPs, copy and paste 1 routine rather than several), getNumericValue altered. I didn't test for mtexts numbers over 256 characters - it should work if you really really want to. Changed the order in the main routine a bit, calculates and reports the value of the 'v's just after selection - handy to have a confirmation of the selected value just after selection Works in my quick tests (defun c:CalcTwoTxt ( / lastOp prompt op ent1 ent2 v1 v2 result inspt validOps) (defun getNumericValue (ent / edata val str1 str3) (setq edata (entget ent)) (setq val 0) (if (or (equal (cdr (assoc 0 edata)) "TEXT")(equal (cdr (assoc 0 edata)) "MTEXT")) (progn (setq val (cdr (assoc 1 edata))) (if (assoc 3 edata) (setq val (strcat str1 str3))) ) ; end progn ) (princ val) (atof val) ) (setq validOps '("*" "+" "-" "/")) (setq lastOp (getenv "CALC_TXT_LAST_OP")) (setq prompt (strcat "\nSelect an operation [*/+/-/\/] <" (if lastOp lastOp "") ">: ")) (setq op (getstring "\nSelect an operation [*/+/-/]: ")) (if (= op "") (setq op lastOp)) (if (not (member op validOps)) (progn (alert "An invalid operation. The operation is used \"+\".") (setq op "+") ) ) (setenv "CALC_TXT_LAST_OP" op) (setq ent1 (car (entsel "\nSelect the first text or MTEXT: "))) (if (null ent1) (exit)) (setq v1 (getNumericValue ent1)) (setq ent2 (car (entsel "\nSelect the second text or MTEXT: "))) (if (null ent2) (exit)) (setq v2 (getNumericValue ent2)) (cond ((= op "*") (setq result (* v1 v2))) ((= op "+") (setq result (+ v1 v2))) ((= op "-") (setq result (- v1 v2))) ((= op "/") (if (zerop v2) (setq result 0.0) (setq result (/ v1 v2)) ) ) (T (setq result 0.0)) ) (setq inspt (getpoint "\nSpecify the insertion point of the result: ")) (if (null inspt) (exit)) (command "_.TEXT" inspt "2.5" "0" (rtos result 2 2) "") (princ) ) Edited March 22 by Steven P 1 Quote
Tsuky Posted March 22 Posted March 22 (edited) My way, if can be a pleasure... (defun ExtractNumber (str / l rslt) (setq l (mapcar '(lambda (x) (if (and (> x 44) (< x 58) (/= x 47)) x 32) ) (vl-string->list str) ) l (mapcar '(lambda (x y) (if (not (= x y 32)) x) ) l (append (cdr l) '(32)) ) l (vl-remove-if-not '(lambda (x) (eq (type x) 'INT) x) l) l (mapcar '(lambda (x) (if (not (eq x 32)) x (list nil))) l) ) (eval (read (strcat "(setq rslt (list " (apply 'strcat (mapcar '(lambda (x) (if (not (listp x)) (chr x) " ")) l)) "))"))) ) (defun c:CalcTwoTxt ( / ss1 ss2 val1 val2 op rslt inspt) (princ "\nSelect first text") (while (not (setq ss1 (ssget "_+.:E:S" '((0 . "*TEXT")))))) (princ "\nSelect second text") (while (not (setq ss2 (ssget "_+.:E:S" '((0 . "*TEXT")))))) (setq val1 (extractnumber (cdr (assoc 1 (entget (ssname ss1 0)))))) (setq val2 (extractnumber (cdr (assoc 1 (entget (ssname ss2 0)))))) (cond ((and val1 val2) (initget "* + - /") (setq op (getkword "\nSelect an operation [*/+/-/\/]? <+>: ")) (if (not op) (setq op "+")) (if (and (eq op "/") (member 0 val2)) (setq rslt 0.0) (setq rslt (apply (read op) (append val1 val2))) ) (initget 1) (setq inspt (getpoint "\nSpecify the insertion point of the result: ")) (command "_.TEXT" inspt "2.5" "0" (rtos rslt 2 2)) ) (T (princ "\No value found in text")) ) (prin1) ) NB:The extractnumber function recovers all the digital values contained in a text in the form of a list exemple: (extractnumber "area floor = 45.60m², length 12.56m heigth = 2.12m") -> (45.6 12.56 2.12) Edited March 22 by Tsuky 1 Quote
Nikon Posted March 22 Author Posted March 22 (edited) 6 hours ago, Tsuky said: My way, if can be a pleasure... @Tsuky HUGE thank. The division operation is active, but there is one drawback. Dividing a smaller number by a larger one gives 0. For example, 5/10=0 or 5/550=0... decimal division works fine 05./50.5=0.9. ??? Is it possible to remember the last choice of operation? Edited March 22 by Nikon Quote
Nikon Posted March 22 Author Posted March 22 17 hours ago, Steven P said: Cold try this as a modification, keeping your method: Putting getNumericValue as a subroutine (I find that better for these forum LISPs, copy and paste 1 routine rather than several), getNumericValue altered. I didn't test for mtexts numbers over 256 characters - it should work if you really really want to. Changed the order in the main routine a bit, calculates and reports the value of the 'v's just after selection - handy to have a confirmation of the selected value just after selection Works in my quick tests For some reason, the code gives an error... ; error: incorrectly generated list at the entrance Quote
Nikon Posted March 23 Author Posted March 23 8 hours ago, Steven P said: think I left in something I was trying - edited now Unfortunately, I can't check the code, the same error. ; error: incorrectly generated list at the entrance Quote
