Help me fix the errors.
The division operation is not highlighted
When selecting MTEXT, the code returns an error: invalid argument type: stringp nil.
(defun getNumericValue (ent / edata val str1 str3)
  (setq edata (entget ent))
  (cond
    ;; TEXT
    ((equal (cdr (assoc 0 edata)) "TEXT")
     (setq val (cdr (assoc 1 edata))))
    ;; MTEXT
    ((equal (cdr (assoc 0 edata)) "MTEXT")
     (setq str1 (cdr (assoc 1 edata)))
     (setq str3 (cdr (assoc 3 edata)))
     (setq val (strcat str1 str3))
    (T
     (setq val "0")
  (atof val)
(defun c:CalcTwoTxt ( / lastOp prompt op ent1 ent2 v1 v2 result inspt validOps)
  (setq validOps '("*" "+" "-" "/"))
  (setq lastOp (getenv "CALC_TXT_LAST_OP"))
  (setq prompt (strcat "\nSelect an operation [*/+/-//] <" (if lastOp lastOp "") ">: "))
  (setq op (getstring "\nSelect an operation [*/+/-//]: "))
  (if (= op "") (setq op lastOp))
  (if (not (member op validOps))
(alert "An invalid operation. The operation is used \"+\".")
           (setq op "+")
  (setenv "CALC_TXT_LAST_OP" op)
  (setq ent1 (car (entsel "\nSelect the first text or MTEXT: ")))
  (if (null ent1) (exit))
  (setq ent2 (car (entsel "\nSelect the second text or MTEXT: ")))
  (if (null ent2) (exit))
  (setq v1 (getNumericValue ent1))
  (setq v2 (getNumericValue ent2))
  (cond
    ((= op "*") (setq result (* v1 v2)))
    ((= op "+") (setq result (+ v1 v2)))
    ((= op "-") (setq result (- v1 v2)))
    ((= op "/")
      (if (zerop v2)
        (setq result 0.0)
        (setq result (/ v1 v2))
    (T (setq result 0.0))
  (setq inspt (getpoint "\nSpecify the insertion point of the result: "))
  (if (null inspt) (exit))
  (command "_.TEXT" inspt "2.5" "0" (rtos result 2 2) "")
Hi Nikon
Probably: '(cdr (assoc 3 edata))' is nil
Since it's not a text string and you want to concatenate it with '(cdr (assoc 1 edata))', it gets 'indigestible' and 'erupts': stringp nil'
  • Thanks 1
Expand
And how to write it correctly in the code?
Whereever in the code occurs v1 or v2, change them to (atof v1) and (atof v2)...
  • Thanks 1
I see Marko probably already knows the problem and the solution.
But if not, what do you hope to achieve with '(cdr (assoc 3 edata))'?
Expand
Most of the texts are stored in code group 1,
     but if they are longer than 250 characters, the additional text goes to code group 3.
     (setq str3 (cdr (assoc 3 edata)))  ; it can be nil if there are no additional lines.
But I'm not sure if this is correct.
I think the quickest way to clarify this is to attach a drawing.
Expand
error: syntax error
 (cond
 ;; TEXT
 ;; MTEXT
 (T
 (setq val "0")
 (atof val)
(defun c:CalcTwoTxt ( / lastOp prompt op ent1 ent2 atof v1 atof v2 result inspt validOps)
 (setq op "+")
 (setq (atof v1) (getNumericValue ent1))
 (setq (atof v2) (getNumericValue ent2))
 (cond
 ((= op "*") (setq result (* (atof v1) (atof v2))))
 ((= op "+") (setq result (+ (atof v1) (atof v2))))
 ((= op "-") (setq result (- (atof v1) (atof v2))))
 ((= op "/")
 (if (zerop (atof v2))
 (setq result 0.0)
 (setq result (/ (atof v1) (atof v2)))
Edited by Nikon
(atof v1) (atof v2)
Expand
I have simple operations with numbers, the drawing will not clarify anything.😉
  On 3/21/2025 at 12:54 PM, Nikon said:
Tengo operaciones sencillas con números, el dibujo no me aclara nada.😉
Expand
Nikon, you forgot to add open and closing brackets for v1 and v2... Like I said it should be : (atof v1) and (atof v2)...
  • Thanks 1
Expand
Unfortunately, error: syntax error
Edited by Nikon
In numerical functions,
this:
    ;; TEXT
    ;; MTEXT
could probably be just
    ;; TEXT
    ((equal (cdr (assoc 0 edata)) "*TEXT")
reason being in text. assoc 3 comes into things if the text string is over 256 characters long... which is a very very big number.
  • Thanks 1
Cold try this as a modification, keeping your method:
Putting getNumericValue as a subroutine (I find that better for these forum LISPs, copy and paste 1 routine rather than several), getNumericValue altered. I didn't test for mtexts numbers over 256 characters - it should work if you really really want to.
Changed the order in the main routine a bit, calculates and reports the value of the 'v's just after selection - handy to have a confirmation of the selected value just after selection
Works in my quick tests
    (setq val 0)
    (if (or (equal (cdr (assoc 0 edata)) "TEXT")(equal (cdr (assoc 0 edata)) "MTEXT"))
        (if (assoc 3 edata) (setq val (strcat str1 str3)))
      ) ; end progn
    (princ val)
    (atof val)
  (setq prompt (strcat "\nSelect an operation [*/+/-/\/] <" (if lastOp lastOp "") ">: "))
  (setq op (getstring "\nSelect an operation [*/+/-/]: "))
      (setq op "+")
  (cond
    ((= op "/")
      (if (zerop v2)
        (setq result 0.0)
Edited by Steven P
  • Thanks 1
My way, if can be a pleasure...
(defun ExtractNumber (str / l rslt)
  (setq
    l
    (mapcar
      '(lambda (x)
        (if (and (> x 44) (< x 58) (/= x 47)) x 32)
      (vl-string->list str)
    l
    (mapcar
      '(lambda (x y)
        (if (not (= x y 32)) x)
      l
      (append (cdr l) '(32))
    l (vl-remove-if-not '(lambda (x) (eq (type x) 'INT) x) l)
    l (mapcar '(lambda (x) (if (not (eq x 32)) x (list nil))) l)
  (eval (read (strcat "(setq rslt (list " (apply 'strcat (mapcar '(lambda (x) (if (not (listp x)) (chr x) " ")) l)) "))")))
(defun c:CalcTwoTxt ( / ss1 ss2 val1 val2 op rslt inspt)
  (princ "\nSelect first text")
  (while (not (setq ss1 (ssget "_+.:E:S" '((0 . "*TEXT"))))))
  (princ "\nSelect second text")
  (while (not (setq ss2 (ssget "_+.:E:S" '((0 . "*TEXT"))))))
  (setq val1 (extractnumber (cdr (assoc 1 (entget (ssname ss1 0))))))
  (setq val2 (extractnumber (cdr (assoc 1 (entget (ssname ss2 0))))))
  (cond
    ((and val1 val2)
      (initget "* + - /")
      (setq op (getkword "\nSelect an operation [*/+/-/\/]? <+>: "))
      (if (not op) (setq op "+"))
      (if (and (eq op "/") (member 0 val2))
        (setq rslt 0.0)
        (setq rslt (apply (read op) (append val1 val2)))
      (initget 1)
      (command "_.TEXT" inspt "2.5" "0" (rtos rslt 2 2))
    (T (princ "\No value found in text"))
  (prin1)
NB:The extractnumber function recovers all the digital values contained in a text in the form of a list
exemple:
(extractnumber "area floor = 45.60m², length 12.56m heigth = 2.12m") -> (45.6 12.56 2.12)
Edited by Tsuky
Expand
@Tsuky HUGE thank. The division operation is  active, but there is one drawback.
Dividing a smaller number by a larger one gives 0.
For example, 5/10=0 or 5/550=0... decimal division works fine 05./50.5=0.9.
Is it possible to remember the last choice of operation?
Edited by Nikon
Expand
For some reason, the code gives an error...
; error: incorrectly generated list at the entrance
think I left in something I was trying - edited now
  • Thanks 1
Expand
Unfortunately, I can't check the code,  the same error.
