Civil3d exporting unbounded hatch to either dwg or dfx
  On 3/26/2025 at 8:20 AM, GLAVCVS said:
I don't have Civil3D at the moment, so I can't verify this.
But it seems that the "AECC_PARCEL" object must be a container object for other objects, the main one of which should be a hatch.
Perhaps someone with Civil3D can confirm this.
Expand
You are exactly right
  • Replies 36
  • andyb57J
    17
  • BIGAL
    6
  • SLW210
    6
  • GLAVCVS
    6
Posted Images
Have you found any solution?
What properties exactly do you need to export?
The acad...10 dwg says its a hatch so what about generating a hatch boundary can then get the area.
(load "hatchb")
(c:hb)
(setq area (vlax-get (vlax-ename->vla-object (entlast)) 'area))
(command "erase" (entlast) "")
HatchB.lspFetching info...
  On 3/28/2025 at 10:58 PM, andyb57J said:
It is the hatch that I require to show the area geometry, not the polyline.
Expand
Did you even bother to click the link I posted that explains the issue?
Expand
Thankyou and I did but unfortunately that site just continually refreshes.  Doesn't give me a chance to read it'.  Will keep trying
Edited by andyb57J
(load "hatchb")
(c:hb)
Expand
 Thankyou
Edited by andyb57J
Expand
image.png.82a604c181be3159544993185eeecd9c.png    image.png.e563cb6eb76c2b500042a37b0c00f1db.png
The left is the hatched area as exported from Civil3d using using the EXPORTC3DDRAWING command.  As you can see although AutoCAD shows the hatch as "HATCH" there is no geometry (ie. Area or Accumulated Area).
The right is the hatched area after I use the GENERATEHATCHBOUNDRY command and rehatch the area.  It gives the two geometry fields I require.  Purpose is to allow the user without Civil3d to select the hatched areas, (given there could be hundreds of them) and obtain the accumulated area from the drawing without having to manually calculate or use excel spreadsheets.
(load "hatchb")
(c:hb)
Expand
Thankyou.  This gives what I needed even though area is shown in the command line.
Edited by andyb57J
  On 3/29/2025 at 11:58 PM, andyb57J said:
 Thankyou
Expand
Thankyou so much.  This is generally what I wanted although it still doesnt show the area etc in the properties manager after it recreates the hatch.  but I get the information I need from the command line.  Again thankyou
The link works fine for me.
Basically it states the reason the information is missing is due to errors in the creation of the geometry.
  Quote
your hatch was created using a polyline that had overlapping nodes and segments
Expand
You should have stated you were having trouble accessing the Autodesk Forums.
The solution is to recreate the hatch boundary has has been suggested several times.
You might can fix them using MAPCLEAN.
As I stated the polylines are there, you just need to join and close.
  On 3/30/2025 at 12:44 PM, SLW210 said:
I moved your thread to the Civil 3D & LDD Forum since this is a Civil 3D issue, specifically.
Expand
Expand
 I fully understand what you were saying but joining the polylines for each piece of hatch (where there maybe over 1000 individual hatch areas is just not practical.  As I said previously my current process was to use the HATCHGENERATEBOUNDRY command to regenerate the boundaries and then re-hatch them globally.  This provided me with the two missing fields in the property manager being the area and accumulated area of all selected hatch which was the information I was try to obtain.  What I was hoping to achieve was being able to use the hatch already within the drawing once it has been exported from Civil3d to AutoCAD without having to regenerate the boundaries and hatches which would be on multiple layers.
The post by BIGAL yesterday and the lisp he provided supplies the missing data within the command line which is suitable as this data is only required to complete spreadsheets within the drawing o convey information to the user etc.
Again I thank you for your input.
It may be your lucky day, like others I have write to Excel direct, so if we convert 1000 hatches we can get area and write to excel. Can you post a sample dwg with say a few hatches not a 1000, and an Excel showing header details, what is required to go where in Excel.
Edited by BIGAL
Expand
Thankyou but you have already given what I need.  If I need to output to excel I have tools that allow that but it is not necessary in this instance.
Thankyou.
Why wouldn't you just run MAPCLEAN on them and fix them?
