Below is a section of code which we use to automatically colour code parcels based on their area.  At present it automatically creates layers based on colour (ie Hatch_25512177).  Is it possible to have it so it creates the layer based on the area as shown (ie Hatch_400 - 450) using the area1 values +.5
Sorry if I haven't explained it well 'but I hope you get what I mean.
Also apologize that I cannot supply the full lisp routine which also colours lots based on frontage and/or frontage and depth but I am not the owner.
(cond
    (( < area1 399.5)                         (setq col "255,121,77"))
    ((and( >= area1 399.5)(< area1 449.5))   (setq col "242,95,171"))
    ((and( >= area1 449.5)(< area1 549.5))   (setq col "253,134,206"))
    ((and( >= area1 549.5)(< area1 599.5))   (setq col "253,206,243"))
    ((and( >= area1 599.5)(< area1 699.5))   (setq col "242,187,166"))
    (( >= area1 699.5)                         (setq col "253,237,206"))
    (setq colx (vl-string-subst "" "," col))
    (setq colx (vl-string-subst "" "," colx))
    (setq lay (strcat "Hatch_" colx))
    (command "layer" "new" lay "")
    (command "layer" "color" "truecolor" col lay "")
    (command "LAYER" "SET" lay "")
    (command "color" "bylayer")
    (command "-bhatch" "p" "solid" "s" name "" "")
Edited by SLW210
Added Code Tags!
Please use Code Tags for your Code in the future, this will be your final warning. (just select <> in the Editor toolbar and put the code in the blank area and hit insert)
@andyb57J without your full code, I cannot say if this will work, but here is my modification to your snippet:
;;Added "lay" variable to the setq statement for each condition.
((and( >= area1 399.5)(< area1 449.5))   (setq col "242,95,171" lay "Area_400-450"))
((and( >= area1 449.5)(< area1 549.5))   (setq col "253,134,206" lay "Area_450-550"))
((and( >= area1 549.5)(< area1 599.5))   (setq col "253,206,243" lay "Area_550-600"))
((and( >= area1 599.5)(< area1 699.5))   (setq col "242,187,166" lay "Area_600-700"))
@pkenewell FWIW, all the range checks could be shortened to this. No need for AND
(<= 399.5 area1 449.5)
Expand
Sure they could. I was just answering the OP specifically for what he was asking for, with his own code. I would address your improvement to the OP as well.
Expand
thankyou - This works perfectly
Expand
Or just to -
(setq col
    (cond
        ((< area1 399.5) "255,121,77")
        ((< area1 449.5) "242,95,171")
        ((< area1 549.5) "253,134,206")
        ((< area1 599.5) "253,206,243")
        ((< area1 699.5) "242,187,166")
        ("253,237,206")
  On 3/18/2025 at 9:54 PM, Lee Mac said:
Or just to -
(setq col
    (cond
        ("253,237,206")
Expand
Very true. Glad to see you posting more Lee. :beer:
  • Like 2
Or just to -
(setq col
    (cond
        ("253,237,206")
Expand
@Lee Mac Agreed. Although personally I would have done it like RonJonP just for readability; when I'm trying to understand the code I wrote later. I don't mean it's the best way - just how I prefer 🙂
Expand
In the original portion of the lisp that I supplied could you please show me where I can add the code to add 30% transparency to each of the layers created.  Personally I do this after the case in the Layers Properties Manager and but users have asked if it could be added at the creation stage
After the layer is created add this line to set 30% transparency:
(entmod (append (entget (tblobjname "layer" lay)) '((-3("AcCmTransparency" (1071 . 33554610))))))
Expand
thankyou - is perfect
Expand
:beer:
