itacad Posted March 14 Posted March 14 Hi, I'm writing in this section of the forum because I assume there is no solution with the normal use of the program. I'm struggling with a building export from Revit, the generated file is a block that contains many nested blocks, even if I change the colors of the layers (I want to make them all the same color), until I go inside each single block and change the color from there I don't get the desired effect. I would like to create a layer with a certain color and associate the color fromLayer (DaLayer) to the block and all its nested subblocks in a single operation. Is it possible? Thanks in advance Quote
Steven P Posted March 14 Posted March 14 I am thinking you might use this from Lee Mac to get a list of nested blocks and work from there: https://lee-mac.com/extractnestedblock.html I think this is the related part of the code ;;https://lee-mac.com/extractnestedblock.html ;;USe this line to select a block (enb:getreferences (cdr (assoc 2 (entget (car(entsel)))))) ; Use this to loop through the blocks, in this case it is making a list, in your case (ssget "_X") and modify assoc codes to by block / layer colouras and layer codes. (defun enb:getreferences ( blk / ent enx lst ) (if (setq ent (tblobjname "block" blk)) (foreach dxf (entget (cdr (assoc 330 (entget ent)))) (if (and (= 331 (car dxf)) (setq ent (cdr dxf)) (setq enx (entget ent)) (setq enx (entget (cdr (assoc 330 (reverse enx))))) ) (if (wcmatch (strcase (setq blk (cdr (assoc 2 enx)))) "`**_SPACE") (setq lst (cons (list ent) lst)) (setq lst (append (mapcar '(lambda ( l ) (cons ent l)) (enb:getreferences blk)) lst)) ;; Change this line to set colours / layers ) ) ) ) lst ) That might give you a start if you want to do some thinking 1 Quote
ronjonp Posted March 17 Posted March 17 (edited) You could try this too: (defun c:foo (/ a d) (vlax-for l (vla-get-layers (setq d (vla-get-activedocument (vlax-get-acad-object)))) (cond ((= -1 (vlax-get l 'lock)) (vlax-put l 'lock 0) (setq a (cons l a)))) ) (vlax-for b (vla-get-blocks d) (if (= 0 (vlax-get b 'isxref) (vlax-get b 'islayout)) (vlax-for o b (vl-catch-all-apply 'vla-put-layer (list o "0")) (vl-catch-all-apply 'vla-put-color (list o 256)) ) ) ) (foreach l a (vlax-put l 'lock -1)) (vla-purgeall d) (vla-regen d acactiveviewport) (princ) ) Edited March 18 by ronjonp 2 Quote
itacad Posted March 19 Author Posted March 19 Wow! This is just what I needed, thanks! I tried it and at first glance it works perfectly! do you want to give a name to your lisp? I'm archiving it as "acnb" but I will use your name if any Now that I've used it, it's fine for me, but if I wanted to improve it, I think it could be useful to ask for the block to be modified because in this version the lisp works on all the nested blocks of the drawing... I repeat that it's fine for me too and so I thank you again! Greetings Quote
ronjonp Posted March 19 Posted March 19 On 3/19/2025 at 1:58 PM, itacad said: Wow! This is just what I needed, thanks! I tried it and at first glance it works perfectly! do you want to give a name to your lisp? I'm archiving it as "acnb" but I will use your name if any Now that I've used it, it's fine for me, but if I wanted to improve it, I think it could be useful to ask for the block to be modified because in this version the lisp works on all the nested blocks of the drawing... I repeat that it's fine for me too and so I thank you again! Greetings Expand Glad to help Quote
