The AutoCAD Blog Posted March 11 Posted March 11 Looking for an AutoCAD tutorial for beginners? We’ve got you covered. The AutoCAD Foundations learning series takes you step-by-step through AutoCAD basics. In our first article, we shared a video tour of the AutoCAD UI video and additional details on Autodesk Learning videos, AutoCAD online help, and the Autodesk Assistant. Now, let’s see how you can take your first steps in AutoCAD. Getting Started with AutoCAD Workflows and Skills Architectural Design: House Deck In this exercise, you will create a plan view of a deck, starting with a sample drawing that contains some reference geometry and a set of predefined layers and dimension styles. After you complete all the exercises, you should have a drawing that looks similar to the following image. Mechanical Design: Square Flange Plate In this exercise, you will create a top and side section view of a square flange plate. You’ll create a new drawing from a template, adding the necessary layers, linetypes, and dimension styles to complete the design. After you complete all the exercises, you should have a drawing that looks similar to the following image. More AutoCAD Tutorials for Beginners Stay tuned for more articles in our blog series or go to the AutoCAD Foundations learning series directly to keep going! The post AutoCAD Tutorial for Beginners: AutoCAD Foundations appeared first on AutoCAD Blog. View the full article Quote
