mhy3sx Posted Friday at 02:52 PM Posted Friday at 02:52 PM This is a part of lisp code. I add two toggle in the dcl dialog ": row {" ": toggle { key = \"Block\"; label = \"Block\"; value = 1; }" ": toggle { key = \"Table\"; label = \"Table\"; value = 1; }" "}" ; end row I want the blocks insert only if the toggle is check. The toggle Block is for (action_tile "eArt67" "(done_dialog 1) (setq bk \"0\")") (action_tile "eArt68" "(done_dialog 1) (setq bk \"1\")") (action_tile "eArt69" "(done_dialog 1) (setq bk \"2\")") (action_tile "eArt67b" "(done_dialog 1) (setq bk \"3\")") (action_tile "eArt68b" "(done_dialog 1) (setq bk \"4\")") (action_tile "eArt69b" "(done_dialog 1) (setq bk \"5\")") (action_tile "eCwwd9l" "(done_dialog 1) (setq bk \"6\")") (action_tile "eCwwd8l" "(done_dialog 1) (setq bk \"7\")") (action_tile "eCwwd8d" "(done_dialog 1) (setq bk \"8\")") (action_tile "eCwwd9lb" "(done_dialog 1) (setq bk \"9\")") (action_tile "eCwwd8lb" "(done_dialog 1) (setq bk \"10\")") and the toggle Table is for ;; Insert eArt3 (setq scl 1) (setq dt1 (getpoint "\n insert")) (setvar "attdia" 1) (command "insert" "c:\\path\\eArt3.dwg" dt1 scl scl "0") (setvar "attdia" 0) ;; DCL DIALOG (if (and (setq d (vl-filename-mktemp nil nil ".dcl")) (setq f (open d "w"))) (progn (write-line (strcat "test : dialog {" "label = \"Επιλογή τύπου ανοίγματος\"; width = 30;" ": row {" ": image_button { key = \"eArt67\"; label = \"eArt67\"; height = 4; width = 4; }" ": image_button { key = \"eArt68\"; label = \"eArt68\"; height = 4; width = 4; }" ": image_button { key = \"eArt69\"; label = \"eArt69\"; height = 4; width = 4; }" "}" ; end row ": row {" ": image_button { key = \"eArt67b\"; label = \"eArt67b\"; height = 4; width = 4; }" ": image_button { key = \"eArt68b\"; label = \"eArt68b\"; height = 4; width = 4; }" ": image_button { key = \"eArt69b\"; label = \"eArt69b\"; height = 4; width = 4; }" "}" ; end row ": row {" ": image_button { key = \"eCwwd9l\"; label = \"eCwwd9l\"; height = 4; width = 4; }" ": image_button { key = \"eCwwd8l\"; label = \"eCwwd8l\"; height = 4; width = 4; }" ": image_button { key = \"eCwwd8d\"; label = \"eCwwd8d\"; height = 4; width = 4; }" "}" ; end row ": row {" ": image_button { key = \"eCwwd9lb\"; label = \"eCwwd9lb\"; height = 4; width = 4; }" ": image_button { key = \"eCwwd8lb\"; label = \"eCwwd8lb\"; height = 4; width = 4; }" ": image_button { key = \"\"; label = \"\"; height = 4; width = 4; }" "}" ; end row ": row {" ": toggle { key = \"Block\"; label = \"Block\"; value = 1; }" ": toggle { key = \"Table\"; label = \"Table\"; value = 1; }" "}" ; end row ": column { width = 17;" ": button { key = \"OK\"; label = \"OK\"; is_default = true; is_cancel = true; fixed_width = true; width = 10; }" "}" ; end column "}" ) f ) (close f) ) (alert "Can't load the temporary file <!>") ) (if (or (not d) (> 0 (setq id (load_dialog d))) (not (new_dialog "test" id))) (progn (if (> id 0) (unload_dialog id) ) (if (and d (setq d (findfile d))) (vl-file-delete d) ) ) (progn ;; Load and display the slide images (mapcar '(lambda (s k) (start_image k) (fill_image 0 0 (dimx_tile k) (dimy_tile k) 0) (slide_image 0 0 (dimx_tile k) (dimy_tile k) s) (end_image) ) (list "C:\\path\\eArt67.sld" "C:\\path\\eArt68.sld" "C:\\path\\eArt69.sld" "C:\\path\\eArt67b.sld" "C:\\path\\eArt68b.sld" "C:\\path\\eArt69b.sld" "C:\\path\\eCwwd9l.sld" "C:\\path\\eCwwd8l.sld" "C:\\path\\eCwwd8d.sld" "C:\\path\\eCwwd9lb.sld" "C:\\path\\eCwwd8lb.sld" ) (list "eArt67" "eArt68" "eArt69" "eArt67b" "eArt68b" "eArt69b" "eCwwd9l" "eCwwd8l" "eCwwd8d" "eCwwd9lb" "eCwwd8lb" "eCwwd8db") ) ;; Set up action tiles for the image buttons (action_tile "eArt67" "(done_dialog 1) (setq bk \"0\")") (action_tile "eArt68" "(done_dialog 1) (setq bk \"1\")") (action_tile "eArt69" "(done_dialog 1) (setq bk \"2\")") (action_tile "eArt67b" "(done_dialog 1) (setq bk \"3\")") (action_tile "eArt68b" "(done_dialog 1) (setq bk \"4\")") (action_tile "eArt69b" "(done_dialog 1) (setq bk \"5\")") (action_tile "eCwwd9l" "(done_dialog 1) (setq bk \"6\")") (action_tile "eCwwd8l" "(done_dialog 1) (setq bk \"7\")") (action_tile "eCwwd8d" "(done_dialog 1) (setq bk \"8\")") (action_tile "eCwwd9lb" "(done_dialog 1) (setq bk \"9\")") (action_tile "eCwwd8lb" "(done_dialog 1) (setq bk \"10\")") (action_tile "OK" "(done_dialog 1)") ;; Start the dialog (setq ret (start_dialog)) (unload_dialog id) ;; Handle the selection (if (= ret 1) (cond ((= bk "0") (_eArt67)) ((= bk "1") (_eArt68)) ((= bk "2") (_eArt69)) ((= bk "3") (_eArt67b)) ((= bk "4") (_eArt68b)) ((= bk "5") (_eArt69b)) ((= bk "6") (_eCwwd9l)) ((= bk "7") (_eCwwd8l)) ((= bk "8") (_eCwwd8d)) ((= bk "9") (_eCwwd9lb)) ((= bk "10") (_eCwwd8lb)) ) ) ) ) ) ) ;; Insert eArt3 (setq scl 1) (setq dt1 (getpoint "\n insert")) (setvar "attdia" 1) (command "insert" "c:\\path\\eArt3.dwg" dt1 scl scl "0") (setvar "attdia" 0) ;; Επαναφορά OSMODE και LAYER 0 (setvar "OSMODE" 13) ; NODE,END,CENTER (command "setvar" "clayer" "0") ) ;--- end defun Can any one help? Thanks Quote
GLAVCVS Posted Friday at 05:13 PM Posted Friday at 05:13 PM Do you mean you want to prevent the command from finishing by forcing you to insert the block even if you haven't selected one? Quote
GLAVCVS Posted Friday at 05:23 PM Posted Friday at 05:23 PM If so, you would just need to condition the execution of '(command "_insert"...)' on 'bk' having some value. That is: (if bk (command "_insert" nameofblock dt1 scl scl "0") Quote
GLAVCVS Posted Friday at 05:30 PM Posted Friday at 05:30 PM Of course, for there to be a possibility of 'bk' being nil at the beginning of the command, it must be a local variable. Quote
mhy3sx Posted Friday at 05:33 PM Author Posted Friday at 05:33 PM Hi GLAVCVS . This is a part of a bigger code. The code at the end insert 2 blocks. I want to have the option to insert both of them , or one of them or no block. So the toggles is a solution. Can you help? Thanks Quote
GLAVCVS Posted Friday at 06:01 PM Posted Friday at 06:01 PM If it is then a matter of inserting 2 blocks when Block and Table are activated, 1 when only Block or Table is activated, or none if neither of the 2 is activated, you could do: replace the current '(action_tile "ok"... ) with... (action_tile "OK" "(setq blk (get_tile \"Block\") tab (get_tile \"Table\")) (done_dialog 1)") And below, replace the call to '(command "insert"...)' with... (cond ((and (= blk "1") (= tab "1")) (insert2blocks) ) ((= blk "1") (insertblock_1) ) ((= tab "1") (insertblock_2) ) ) Quote
GLAVCVS Posted Friday at 06:15 PM Posted Friday at 06:15 PM 12 minutes ago, GLAVCVS said: If it is then a matter of inserting 2 blocks when Block and Table are activated, 1 when only Block or Table is activated, or none if neither of the 2 is activated, you could do: replace the current '(action_tile "ok"... ) with... (action_tile "OK" "(setq blk (get_tile \"Block\") tab (get_tile \"Table\")) (done_dialog 1)") And below, replace the call to '(command "insert"...)' with... (cond ((and (= blk "1") (= tab "1")) (insert2blocks) ) ((= blk "1") (insertblock_1) ) ((= tab "1") (insertblock_2) ) ) Well: the execution of this 'cond' would also have to be conditioned to whether a block has been selected, of course That is: (if bk (cond ... ... ... Quote
BIGAL Posted Friday at 09:53 PM Posted Friday at 09:53 PM (edited) A not sure comment I normally do this as get value 1st then close dialog. Did not test. (action_tile "eArt67" "(done_dialog 1) (setq bk \"0\")") (action_tile "eArt67" "(setq bk \"0\")(done_dialog 1)") If you set your c:\path to be a support path then you can just call the slide name, no directory path needed. Just me I would have c:\path\slides & say c:\path\lisps. You may want to look into Slidelibrary this allows you to have one SLB file with all your slide files in it. We had a few slb as group of slides. An old trick was set support path to c:\path.. note the double full stop means include sub directories, I am pretty sure does not work in my Bricscad but it used to work in Autocad. Edited Friday at 09:53 PM by BIGAL Quote
