CAD2005 Posted 6 hours ago Posted 6 hours ago Hi everybody. I found on the web lisp change dimension style. But the lisp part does not have object selection. So I hope those who understand lisp can help me fix it! Sincerely thank you (I do not understand lisp programming) (defun c:CHDM (/ sclst dms dmlst dcl_id wri) (setq dmlst '() obj (vlax-get-acad-object) doc (vla-get-activedocument obj) dms (vla-get-dimstyles doc)) (vlax-for x dms (setq dmlst (cons (vla-get-name x) dmlst))) (setq dcl_id (vl-filename-mktemp nil nil ".dcl") wri (open dcl_id "w")) (foreach x '( "dimsty : dialog" "{label = \"DimStyle List\";" ":list_box {key = \"dmstyle\";" "multiple_select = false; height=10;}" "ok_cancel;" "}" ) (write-line x wri)) (setq wri (close wri)) (< 0 (setq dcl-load (load_dialog dcl_id)) (if (not (new_dialog "dimsty" dcl-load))(exit))) (start_list "dmstyle")(mapcar 'add_list dmlst)(end_list) (action_tile "dmstyle" "(setq sclst (get_tile \"dmstyle\"))") (action_tile "accept" "(done_dialog)(setq clk t)") (action_tile "cancel" "(done_dialog)(setq clk nil)") (start_dialog) (unload_dialog dcl-load) (if clk (if sclst (progn (setq secstl (nth (atoi sclst) dmlst)) (vla-put-activedimstyle doc (vla-item (vla-get-Dimstyles doc) secstl))))) (princ)) Quote
