Organic Posted April 18, 2009 Posted April 18, 2009 Is there any way to change the default size of mtext background mask from 1.5? Quote
Came Posted April 18, 2009 Posted April 18, 2009 Answer is no Her's evidence; http://help.autodesk.com/kb/display.do?ROW_ID=1-J15XAW Quote
Cad64 Posted April 18, 2009 Posted April 18, 2009 You can change the size anywhere from 1.0000 to 5.0000. Double click the Mtext to enter the editor Right click and choose "Background Mask" from the pop up menu Check the box that says "Use Background Mask" Set the "Border Offset Factor" anywhere from 1 to 5 Quote
Organic Posted April 18, 2009 Author Posted April 18, 2009 Yeah I know that, just wondering if I was able to change it through a style or some other variable. Quote
Cad64 Posted April 18, 2009 Posted April 18, 2009 Oh, that wasn't clear in your initial question. I thought you just wanted to know if there was a way to change it. Quote
Glenn-BoB Posted July 30, 2020 Posted July 30, 2020 (edited) On 4/18/2009 at 1:19 PM, Cad64 said: Oh, that wasn't clear in your initial question. I thought you just wanted to know if there was a way to change it. no I'm pretty sure he said change the "default" size. Anyhoo, has there been any change in this in the past 2 years? Can we change the default size yet? Edited July 30, 2020 by Glenn-BoB Quote
RobDraw Posted July 30, 2020 Posted July 30, 2020 3 hours ago, Glenn-BoB said: Anyhoo, has there been any change in this in the past 2 years? Correction, 11 years. 2 Quote
ammobake Posted July 31, 2020 Posted July 31, 2020 While it might not be possible, there are a few alternatives that work perfectly fine. One option is to use a multileader. In the default text window you would need to add something in there. Then while you are adding your default text add a background mask at the desired size. From that point forward when u insert an mleader with that specific style it would have that sized background mask. And if you just want the text, just remove the leader. You can still align and justify the text wherever u want just like an mtext. Another option would be to use a block with attribute definition. I had a thread last year where I discussed how you can add background mask to an attribute definition. But you would then be able to use that block wherever u want and have the background mask at that desired size. So I guess it's possible it's just a matter of configuring your standard template. -ChriS Quote
