GLAVCVS Posted February 23 Posted February 23 In any case, it could still be simplified a bit further. But leaving aside Maahee's choice of doing it with 'foreach'.... (defun c:myDimAlign (/ x e p f) (if (and (setq e (car (entsel "\nSelect any LWpolyline..."))) (= (cdr (assoc 0 (setq x (entget e)))) "LWPOLYLINE") ) (while (setq f (cdr (assoc 10 (setq x (cdr (member (setq p (assoc 10 x)) x)))))) (command "DIMALIGNED" (cdr p) f "@5<180") ) ) ) 1 Quote
Tharwat Posted February 23 Posted February 23 Here is my attempt with foreach function based on the request of the OP. (defun c:DimPly ( / sel 1st ) ;;--------------------------------------------;; ;; Author : Tharwat Al Choufi ;; ;; ;; ;; www.AutolispPrograms.WordPress.com ;; ;;--------------------------------------------;; (and (princ "\nSelect LWpolyline to dimension : ") (or (setq sel (ssget "_+.:S:E" '((0 . "LWPOLYLINE")))) (alert "Invalid object.! Try again") ) (foreach itm (entget (ssname sel 0)) (and (= (car itm) 10) (or (and 1st (or (command "_.DIMALIGNED" "_non" 1st "_non" (setq 1st (trans (cdr itm) 0 1)) "@0.35<180") t)) (setq 1st (trans (cdr itm) 0 1)) ) ) ) ) (princ) ) 1 Quote
GLAVCVS Posted February 24 Posted February 24 (edited) On 2/23/2025 at 5:28 PM, Lee Mac said: Only one DIMALIGNED call is required, e.g.: (defun c:mydimalign ( / e p x ) (if (and (setq e (car (entsel))) (= "LWPOLYLINE" (cdr (assoc 0 (setq x (entget e))))) ) (foreach g x (cond ( (/= 10 (car g))) ( p (command "_.dimaligned" p (setq p (cdr g)) "@5<180")) ( (setq p (cdr g))) ) ) ) (princ) ) Expand @Lee Mac Or another variation of your idea (defun c:myDimAlign (/ x e g p) (if (and (setq e (car (entsel "\nSelect any LWpolyline..."))) (= (cdr (assoc 0 (setq x (entget e)))) "LWPOLYLINE") ) (foreach g x (if (= (car g) 10) (if p (command "DIMALIGNED" p (setq p (cdr g)) "@5<180") (setq p (cdr g)) ) ) ) ) ) Edited February 24 by GLAVCVS 1 Quote
GLAVCVS Posted February 24 Posted February 24 But... Better thought, it's basically the same thing. 1 Quote
maahee Posted February 25 Author Posted February 25 (edited) Thank you to all. I have tried all the codes that work uniquely and are simple, clean, and easy to understand. It's a great and nice alternative, However, one common drawback is that the codes cannot give the last polyline dimension if it has a closed polyline, which I think does not provide sufficient information from my side. I am trying to fix it. Edited February 25 by maahee Quote
Lee Mac Posted February 25 Posted February 25 On 2/25/2025 at 8:38 AM, maahee said: one common drawback is that the codes cannot give the last polyline dimension if it has a closed polyline Expand To account for such a case, you can append the first vertex to the DXF data list, e.g.: (defun c:mydimalign ( / e p x ) (if (and (setq e (car (entsel))) (= "LWPOLYLINE" (cdr (assoc 0 (setq x (entget e))))) ) (foreach g (if (= 1 (logand 1 (cdr (assoc 70 x)))) (append x (list (assoc 10 x))) x) (cond ( (/= 10 (car g))) ( p (command "_.dimaligned" p (setq p (cdr g)) "@5<180")) ( (setq p (cdr g))) ) ) ) (princ) ) 1 Quote
BIGAL Posted February 25 Posted February 25 Just a comment like @Lee Mac when doing ssget with filters "F" "CP" "WP" it is always a good idea to add the last point to the list again this has the effect of a closed group of points. (setq plent (entsel "\nPick rectang")) (if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent)))))) (setq co-ord (cons (last co-ord) co-ord)) 1 Quote
maahee Posted February 28 Author Posted February 28 (edited) (if (= (cdr (assoc 0 bm)) "LWPOLYLINE") ; Check if the entity type is LWPOLYLINE (progn (setq pline (cdr (assoc -1 bm))) (setq pdb (entget pline)) ; Get the entity list for the selected polyline. (setq p1 nil) (foreach sublist pdb (if (= (car sublist) 10) ; Look for vertex points (coded as 10). (progn (if (null p1) (setq p1 (cdr sublist)) ;; First vertex (progn (setq p2 (cdr sublist)) ;; Next vertex (command "DIMALIGNED" p1 p2 "@1<180") (setq p1 p2) ;; Update p1 for the next iteration ) ; end progn ) ; end if ) ; end progn ) ; end if ) ; end foreach ) ; end progn ) ; if another alternative code, which handles closed polyline vertex, thanks to all for help Edited February 28 by maahee Quote
GLAVCVS Posted February 28 Posted February 28 I think a necessary improvement to all the codes proposed so far could be to get it to draw the dimensions on the side of the polyline desired by the user. 1 Quote
Nikon Posted February 28 Posted February 28 On 2/28/2025 at 9:09 AM, GLAVCVS said: I think a necessary improvement to all the codes proposed so far could be to get it to draw the dimensions on the side of the polyline desired by the user. Expand There is something similar. AutoDimPL.lspFetching info... 1 1 Quote
GLAVCVS Posted March 2 Posted March 2 (edited) So that no one says that I throw stones and hide my hand, here is my proposal for improvement. (defun c:myDimAlign (/ x e p s d o pS os xD asr dt pr ar osmant) ;; A D * I N F I N I T V M A D * I N F I N I T V M A D * I N F I N I T V M ;; A D * I N F I N I T V M A D * I N F I N I T V M A D * I N F I N I T V M ;; ;;; ;; GGGG LL A VV VV CCCC VV VV SSSS ;;; ;; GG GG LL AA AA VV VV CC CC VV VV SS SS ;;; ;; GG LL AA AA VV VV CC VV VV SS ;;; ;; GG GGGG LL AA AA VV VV CC VV VV SSSS ;;; ;; GG GG LL AA AAA AA VV VV CC VV VV SS ;;; ;; GG GG LL LL AA AA V V CC CC V V SS SS ;;; ;; GGG LLLLLLLL AA AA VV CCCC VV SSSS ;;; ;; ;;; ;; A D * I N F I N I T V M A D * I N F I N I T V M A D * I N F I N I T V M ;; A D * I N F I N I T V M A D * I N F I N I T V M A D * I N F I N I T V M (defun os (/ d p i) (while (and (setq f (cdr (assoc 10 (setq x (cdr (member (setq p (assoc 10 x)) x)))))) (/= (max (distance (cdr p) pS) (distance f pS) (setq d (distance (setq i (cdr p)) f))) d) ) ) i ) (defun xD (c1 c2 / ed pt r of) (if (not dt) (setq dt (distance o (cadr s)) ar (asr (os) pS o)) ) (polar c2 (ar (angle c1 c2) (/ pi 2)) dt) ) (defun asr (p1 p2 p3 / a b) (if (> (abs (- (setq a (angle p1 p2)) (setq b (angle p2 p3)))) PI) (if (< a b) (if (> (+ a PI PI) b) - +) (if (> (- a PI PI) b) - +) ) (if (> a b) - +) ) ) (setq osmant (getvar 'OSMODE)) (setvar 'OSMODE 0) (if (and (setq e (car (setq s (entsel "\nSelect any LWpolyline...")))) (= (cdr (assoc 0 (setq x (entget e)))) "LWPOLYLINE") (setq o (getpoint (setq pS (cadr s)) "\nSide to act on...")) ) (foreach g (if (= (rem (cdr (assoc 70 x)) 2) 0) x (setq x (append x (list (assoc 10 x))))) (if (= (car g) 10) (if p (command "_DIMALIGNED" p (cdr g) (xD p (setq p (cdr g)))) (setq p (cdr g)) ) ) ) ) (if osmant (setvar 'OSMODE osmant)) (princ) ) Edited March 2 by GLAVCVS 1 1 Quote
GLAVCVS Posted March 2 Posted March 2 If you need to modify parameters such as text size or inclination, arrow size, etc... you may need to add some code modifying a system variable. That's up to you. Do your testing. Quote
Nikon Posted March 2 Posted March 2 On 3/2/2025 at 4:22 PM, GLAVCVS said: So that no one says that I throw stones and hide my hand, here is my proposal for improvement. Expand Good improvement! And one more thing... dmp.lspFetching info... 1 1 Quote
maahee Posted March 3 Author Posted March 3 (edited) On 3/2/2025 at 4:32 PM, GLAVCVS said: If you need to modify parameters such as text size or inclination, arrow size, etc... you may need to add some code modifying a system variable. That's up to you. Do your testing. Expand Deciding the direction (inside/outside) by cursor movement is interesting and funny. can add arc dimension in a closed polyline. Edited March 3 by maahee Quote
