(defun c:test (/ a)
(setq a 1)
(mapcar (function (lambda (x)(+ x a))) '(1 2 3))
Hi Everyone, upon debugging the code above in VLIDE, why does the local variable 'a became global variable? Is there any way to prevent this? This happens to all that has lambda functions with local variable in it.
That's not a global variable. Lambda is defined inside test. But lambda doesn't redefine the variable a, so it can access a from its environment, meaning from the function test. After the execution of test terminates, the value of a is destroyed.
thats because the lambda function is inside your test function and as fuccaro said not redefining it.
You could also localize a within lambda (lambda (x / a)..)
[CHECKING TEXT <Untitled-0> loading...]
; === Top statistic:
; Global variables: (A)
; Function definition (with number of arguments): ((C:TEST . 0))
; Check done.
Hi fuccaro, my concern is when you have a lot of lambda functions it is hard to pin point which is which are now the local variables when checking text in editor becomes global variable.
Hi EnM4st3r, in some cases this would be fine, but usually I set the variable first on the main function rather than on the lambda function.
18 hours ago, LanloyLisp said:
(defun c:test (/ a)
(setq a 1)
For some reason the VLIDE reports it as a global but if you type in !a in the command line after running your test lisp, it should return:
Command: !a
nil
Edited by ronjonp
