I am using the following macro:
^C^C._ZOOM;_E;._QSAVE;$M=$(if,$(eq,$(getvar,DWGTITLED),0),~);._CLOSE;
We are always zooming, setting scale 1 to 1, saving and then closing. Is there anyway to inject "set the scale to 1 to 1" before saving?
Is there a  way to make this happen for all open sheets in the window at one time? no as important as the first question.
Copied and pasted from my Lisp Library:
The first are useful functions to have to hand. For example
"ZA" - Zoom All I use all the time in preference to "Zoom" "All"
"Closer" closes document, no save
"VPScale" sets all viewports to 1:1 scale in that sheet
Put together in MyClose at the end. Load them all up and it should be OK
;;;;SubFunctions, Useful to have anyway;;;;
;;;;Zooms: ZE - extents, ZA - All, ZO - Object, ZP - Previous
(defun c:ze() ;;Zooms extents, then zooms out 0.95x
  (command "zoom" "e" "zoom" ".95x")(princ)
(defun c:za() ;;Zoom all, then zooms out 0.95x
  (command "zoom" "a" "zoom" ".95x")(princ)
(defun c:zo() ;;Zoom object
  (command "zoom" "o" "zoom" "0.95x")(princ)
(defun c:zp() ;;Zoom previous
  (command "zoom" "p")(princ)
;;;;asave: Save Lisp
(defun c:asave( / currentversion saveasversion old)
  (setq vars '("CMDECHO" "FILEDIA"))                           ;;Disable command promts and echo vars
  (setq old (mapcar 'getvar vars))                             ;;Record current vars
  (mapcar 'setvar vars '(0 0))                                 ;; Change vars
  (if (= 1 (getvar "dwgtitled"))(command "qsave"))             ;; EXISTING DRAWING
  (if (= 0 (getvar "dwgtitled")) (COMMAND "_.saveas" "" "~") ) ;;new drawing
  (mapcar 'setvar vars old)                                    ;;reset command prompt and echo
;;;;closer: Closes drawing, no save
(defun c:closer( / *doc* opendrawings)
  (if (= dbmod 0)(command ".close"))      ;; Close if drawing is saved
  (if (/= dbmod 0)(command ".close" "y")) ;; Close if drawing is not saved
;;;; VPScale: Sets all viewports in sheet to 1:1
(defun c:VPScale ( / MySS scale acount)
  (setq MySS (ssget "_X" '((0 . "VIEWPORT"))))  ;; Select all viewports
  (setq acount 0)                               ;; A counter
  (setq scale 1) ;;1 = 1:1                      ;; Scale to use
  (while (< acount (sslength MySS))             ;; loop through selection set
    (vla-put-customscale (vlax-ename->vla-object (ssname MySS acount)) scale)  ;; Set viewports scales
    (setq acount (+ acount 1))
  ) ; end while
;;;;; End sub routines ;;;;;
;;;;Zoom extents, all viewports to 1:1, save, close
(defun C:MyClose ( / LayList CurrentLay Lay)
  (setq LayList (layoutlist))        ;; Get layout List (ACAD 2023+)
  (setq CurrentLay (getvar "ctab"))  ;; Record current layout
  (foreach Lay LayList               ;; Loop through each layout
    (setvar "ctab" Lay)              ;; Change layout
    (c:ZE)                           ;; Run ZE: Zoom Extents (above)
    (c:vpscale)                      ;; Run VPScale, set all viewports to 1:1
  ) ; end foreach                    ;; End loop
  (setvar "ctab" CurrentLay)         ;; Return to previous sheet
  (c:asave)                          ;; Save
  (c:closer)                         ;; Close
I see the viewport scale set to 1:1. My mistake, I should have clarified that I want to set the overall sheet scale to 1:1 and not change the viewports.
Thanks for the info. I will work with what you have shown.
when on the layout page, we set the scale back to 1:1 with nothing selected so that the x-referenced drawings will show correctly, i.e. dashed lines, hatching, etc. this does not change the scale of the viewports which are sometimes set to 1/4 or 1/8 scale.  on our shortcut commands it says "setup 1:1", not sure if that helps.
How big is your printer? Sound like you have PSLTSCALE turned off.
PSLTSCALE is on, I checked. Our printer will do up to 22x34 but to save paper costs we print 11x17. Our drawings are set for a standard paper size of 22x34. Even when not printing, looking at the sheet shows lines solid when they should be dashed if the paper space isn't set to 1:1.
I don't recognise the drop down list you have there - might be a setting I don't have turned on - or is that a custom button / macro / LISP (and if so.... are you able to post the details, might be something else going on in the background apart from scale at 1:1)
Is it Annotation scale? (I think variable cannoscale does that) - you can replace:
line with whatever setting needs changing
i got it figured out, this is what it is for reference:
this used our variables we created years ago. Thank you for your help.
^C^C._ZOOM;_E;_fillet;radius;0.0625;chamfera;0.0625;_chamferb;0.0625;dimasz;0.0625;dimcen;0;dimdli;0;dimexe;0.0625;dimexo;0.0625;dimgap;0.0625;dimtxt;0.1;donutid;0;donutod;0.5;gridunit;1,1;hpscale;0.25;hpspace;0.25;ltscale;0.208;offsetdist;1;snapunit;1,1;textsize;0.1;dimclrt;7;limits;0,0;36,24;dimscale;1;_chamfera;0.0625;chamferb;0.0625;dimasz;0.0625;dimcen;0;dimdli;0;dimexe;0.0625;dimexo;0.0625;dimgap;0.0625;dimtxt;0.1;donutid;0;donutod;0.5;gridunit;1,1;hpscale;0.25;hpspace;0.25;ltscale;0.208;offsetdist;1;snapunit;1,1;textsize;0.1;dimclrt;7;limits;0,0;36,24;getvar;dimscale;1;_QSAVE;$M=$(if,$(eq,$(getvar,DWGTITLED),0),~);._CLOSE;
  • Agree 1
I was trying to make a very bad dad joke
