Hi. I have this set scale lisp. I realized that the option to set "other" Scale not working now. Can any one knows why?
(defun c:SETSC (/ *error* dch dcl des sng sngReturn cursc newsc)
  (defun *error* (msg)
    (if (and (= 'int (type dch)) (< 0 dch))
      (unload_dialog dch)
    (if (= 'file (type des))
      (close des)
    (if (and (= 'str (type dcl)) (findfile dcl))
      (vl-file-delete dcl)
    (if (and msg
             (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
  (setvar "OSMODE" 13)
  (setq cursc (getvar "useri1"))
  (cond
    ((not
       (setq dcl (vl-filename-mktemp nil nil ".dcl")
             des (open dcl "w")
     (princ "\nUnable to open DCL for writing.")
    ((progn
       (foreach str
                  "ed : edit_box { alignment = left; width = 25; edit_width = 10; fixed_width = true;}"
                  "setscale : dialog { spacer; key = \"dcl\";"
                  " : boxed_radio_column { key=\042key\042; label = \"S c a l e\"; height = 1.0;"
                  "      : radio_button { height = 1.0; width = 25; is_tab_stop = true;"
                  "        key = \"radio_button01\"; label = \"1 : 50\";"
                  "        key = \"radio_button02\"; label = \"1 : 100\";"
                  "        key = \"radio_button03\"; label = \"1 : 200\";"
                  "        key = \"radio_button04\"; label = \"1 : 250\";"
                  "        key = \"radio_button05\"; label = \"1 : 500\";"
                  "        key = \"radio_button06\"; label = \"1 : 2000\";"
                  "        key = \"radio_button07\"; label = \"1 : 2500\";"
                  "        key = \"radio_button08\"; label = \"1 : 5000\";"
                  "        key = \"radio_button09\"; label = \"1 : 10000\";"
                  "        key = \"radio_button10\"; label = \"1 : 20000\";"
                  "      : ed {height = 1.0; width = 25; is_tab_stop = true;"
                  "        key = \"other\"; label = \"Other Scale 1 :\";"
                  "      : ed {height = 1.0; width = 25; is_enabled = false;"
                  "        key = \"oldscale\"; label = \"ΟThe set scale is 1 :\";"
                  "    ok_only;"
         (write-line str des)
       (setq des (close des)
             dch (load_dialog dcl)
       (<= dch 0)
     (princ "\nUnable to load DCL file.")
    ((not (new_dialog "setscale" dch))
     (princ "\nUnable to display 'setscale' dialog.")
    (t
     (set_tile "dcl" "Set the drawing Scale")
     (set_tile "oldscale" (itoa cursc)) ; set the old scale in the dialog box
	   (action_tile "other" "(progn (setq sng \"other\") (setq sngReturn (atoi $value)))")
    	(action_tile "key" "(setq sng $value)")
     (action_tile "OK" "(done_dialog 1)")
     (start_dialog)
     (if
       (setq sngReturn
         (cond
           ( (eq sng "radio_button01") 50 )
           ( (eq sng "radio_button02") 100 )
           ( (eq sng "radio_button03") 200 )
           ( (eq sng "radio_button04") 250 )
           ( (eq sng "radio_button05") 500 )
           ( (eq sng "radio_button06") 2000 )
           ( (eq sng "radio_button07") 2500 )
           ( (eq sng "radio_button08") 5000 )
           ( (eq sng "radio_button09") 10000 )
           ( (eq sng "radio_button10") 20000 )
           ( (eq sng "other") sngReturn)
           ( (eq sng "oldscale") cursc)
         (princ "\nThe drawing scale set  1 : ")(princ sngReturn)
         (setvar "useri1" sngReturn)
  (*error* nil)
Thanks
Can anyone tell me if is any error in this lines of the code?
and
(setq sngReturn
         (cond
        ....code.....
           ((eq sng "other") sngReturn)
       ......code.........
Because when I try to set scale in "other" nothing happens, no scale set.
Thanks
Hi GLAVCVS. The DCL load perfect and the scales in radio buttons work perfect too. Only the "other" not working.
Any ideas
Thanks
OK. I update the code to
                  "      : edit_box { height = 1.0; width = 25; is_tab_stop = true;"
                  "      : edit_box { height = 1.0; width = 25; is_enabled = false;"
                  "        key = \"oldscale\"; label = \"The set scale is 1 :\";"
But nothing  change.
Thanks
Edited by mhy3sx
The 'edit_box' does not generate an event when editing in AutoCAD. To get the content of the edit_box you must do it when leaving the box, after pressing the accept button.
You could do that like this:
(action_tile "accept" "(if (wcmatch (setq custSc (get_tile \"other\")) \"#,##,###,####,#####\") (progn (setq sng \"other\") (setq sngReturn (atoi custSc))))")
I have posted this many times you can make the dcl code and get an answer with like 4 lines of code. Have a look at examples in top of code.
Something like this is displayed.
Anyway I dont think this line is correct.
I would use :boxed_column
Hello mhy3sx,
I am looking to write a similar lisp file but with Imperial scales.
I tried your coding and the dialog box worked great except when I pick from the list of scales and press "ok".
Received the message that the scale was changed but actually did not change.
Am I missing something, like adding a command line to zoom 1/200xp ?
Thanks !
The lisp is just a program for choosing it would replace your dcl code.
I use something like this and the "Yes" or "No" would be returned in variable ans. Note the 1 is 1st button as defualt, the 'H"or "h" is horizontal dcl, for your scaes use "v"
(setq ans (ah:butts 1 "h"  '("Yes or No" "Yes" "No")))
Then use a cond comparing ans to then set your sclaeXP.
Metric or imperial is ok as you set the scXP correct.
Added the command line to zoom scXP and it worked !
Was not able to use a variable for the zoom command so used if-statements to enter the text needed for each scale.
Attached is the latest working file.
One improvement would be to have the scales read with the proper feet and inch symbols.
Had trouble with the syntax.
For example, for scale 6 ... would  be better to read as 6" = 1'-0".
Keep in mind I am still a newbie to lisp, but usually can figure things out enough to get results.
Any suggestions are welcome.
SETSC.lsp
As I work metric not a problem. 1:100 etc I have tried to add the " but the dcl very much rejects the double quote. Ok I remembered what I did you use dbl single quotes  ' '. Ok a hidden hint you can use the full string "6'' = 1'-0''" in your cond or the variable BUT contains the button number selected makes the cond ((= but 1)(dosomething)) a simpler way of setting in this case the scale.
(ah:butts but "V" (list "Choose a number" "6'' = 1'-0''" "3'' = 1'-0''" ..........))
Edited by BIGAL
