CADtech101 Posted February 12 Posted February 12 I have tried to "drag & drop / re-arrange" the layout tabs at the bottom. It only shows a red stop sign icon. My "LOCKUI" is set to zero. I dont know anywhere else that may be locking these tabs and not letting me re-arrange them. Would anyone have another suggestion. Quote
SLW210 Posted February 13 Posted February 13 Has it ever worked? Any recent updates to AutoCAD and/or the OS? You might try creating a new profile. You may need to try a reset to defaults, repair or reinstall. Quote
BIGAL Posted February 13 Posted February 13 (edited) You can via lisp rearrange the layouts order, the only issue I see is if you have say like I did 88 layouts how you work out the order. This is one example. Moves current tab. (defun C:Mtab ( / lay num) (setq num (getint "\nEnter tab number")) (setq curtab (getvar "ctab")) (vlax-for lay (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object))) (if (= curtab (vla-get-name lay)) (vla-put-taborder lay num) ) ; if ) ; for (princ) ) ; defun (c:mtab) If there alphabetical etc you can reorder using a lisp. You could build a dcl list and some how rearrange the order, then update. I know if you have less than 20 can make a dcl with a number that you set. Edited February 13 by BIGAL Quote
