Hello,
I have thousands of alignments that are of centerline type but I would like them to be miscellaneous. Is there a lisp routine I can use that would be faster than changing the alignment properties of all the alignments?
What type of alignment are you referring to?
Sounds like a Civil 3D question, if you wanted a LISP, you should ask in the LISP forum and a Civil 3D question belongs in the Civil 3D forum.
You show AutoCAD 2024 in your profile, is that what you are using?
