mhy3sx Posted February 7, 2025 Posted February 7, 2025 Hi I write this code to export data from attribute blocks to txt the block have this tags DIAT, KM, EO, EE (defun c:foo ( / *error* del des ent idx lst obj ord out sel ) (defun *error* (msg) (if (= 'file (type des)) (close des)) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg))) (princ)) (setq ord '("DIAT" "KM" "EO" "EE") del ",") ;; Prompt the user to choose the file path for exporting (if (setq out (getfiled "Choose where to save the file" (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname))) "txt" 1)) (if (setq sel (ssget '((0 . "INSERT") (66 . 1)))) (if (setq des (open out "w")) (progn (repeat (setq idx (sslength sel)) (setq ent (ssname sel (setq idx (1- idx))) obj (vlax-ename->vla-object ent)) (setq lst (mapcar '(lambda (x) (cons (strcase (vla-get-tagstring x)) (vla-get-textstring x))) (vlax-invoke obj 'getattributes))) (if (setq lst (vl-remove 'nil (mapcar '(lambda (x) (cdr (assoc x lst))) ord))) (write-line (LM:lst->str lst del) des))) (setq des (close des))) (princ (strcat "\nUnable to open file: \"" out "\" for writing.")))) (princ "No file path provided.")) (princ)) (defun LM:lst->str (lst del) (if (cdr lst) (strcat (car lst) del (LM:lst->str (cdr lst) del)) (car lst))) (defun LM:uniquefilename (pth ext / fnm tmp) (if (findfile (setq fnm (strcat pth ext))) (progn (setq tmp 1) (while (findfile (setq fnm (strcat pth "(" (itoa (setq tmp (1+ tmp))) ")" ext)))))) fnm) (vl-load-com) (princ) The code export the data from the attribiutes like k1,135.25,4.25,2.54 y2,0.00,1.05,2.00 s2,20.00,1.25,2.35 I want to change the order of the export lines from smaller KM to bigger , like y2,0.00,1.05,2.00 s2,20.00,1.25,2.35 k1,135.25,4.25,2.54 Can any one help? Thanks Quote
rlx Posted February 7, 2025 Posted February 7, 2025 (edited) nada testing... (defun c:foo ( / *error* ord fn del des ent idx lst obj out sel ) (defun *error* (msg) (if (= 'file (type des)) (close des)) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))(princ (strcat "\nError: " msg)))(princ)) (setq ord '("DIAT" "KM" "EO" "EE") del ",") (setq fn (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)))) (cond ((not (setq out (getfiled "Choose where to save the file" fn "txt" 1))) (princ "\nNo file path provided.")) ((not (setq sel (ssget '((0 . "INSERT") (66 . 1))))) (princ "\nNo blocks with attributes were found")) ((not (setq des (open out "w"))) (princ (strcat "\nUnable to open file: \"" out "\" for writing."))) (t (repeat (setq idx (sslength sel)) (setq ent (ssname sel (setq idx (1- idx))) obj (vlax-ename->vla-object ent)) (setq lst (mapcar '(lambda (x) (cons (strcase (vla-get-tagstring x)) (vla-get-textstring x))) (vlax-invoke obj 'getattributes) ) ) ) (setq lst (vl-remove 'nil (mapcar '(lambda (x) (cdr (assoc x lst))) ord))) ;;; (setq lst '(("k1" "135.25" "4.25" "2.54") ("y2" "0.00" "1.05" "2.00") ("s2" "20.00" "1.25" "2.35"))) (setq lst (vl-sort lst (function (lambda (a b) (< (atof (cadr a)) (atof (cadr b))))))) ;;; (("y2" "0.00" "1.05" "2.00") ("s2" "20.00" "1.25" "2.35") ("k1" "135.25" "4.25" "2.54")) (if (not (vl-consp lst)) (princ "\nNo items to write") (foreach item lst (write-line (LM:lst->str item del) des)) ) ) ) (if (= 'file (type des)) (close des))(gc) (princ) ) Edited February 7, 2025 by rlx 1 Quote
