When copying layouts from one drawing to another the viewport layers change
Hi Could someone assist I am copying layouts from one drawing to another using from template ( to create a renamed template on a drawing). However when I do this the viewport layers which have been switched off on the original drawing all appear open on the copied drawing I know that I could go through the layers and individually switch them off to match the original drawing however this would be a long process as I have approx 400 drawing to do this with. So just after a quicker way if anyone knows.
Thank you
Steve Daley
