Hello,
maybe someone can help me with my project.
I have created the following Lisp that creates a polyline object offset within an Xline boundary.
But I can only create one object. Then I have to run the command again.
Can someone help me to set up a loop so that several objects can be created with one command?
Thank you very much
Best wishes, Martin
versum.lspFetching info...
u might add this to beginning:
  (setq osm_old(getvar 'OSMODE))
  (setvar 'OSMODE 0)
and this on the end of lisp:
  (setvar 'OSMODE osm_old)
Hello Tomislav,
Thank you very much for your help!
Now it works exactly as I imagined.
Thank you!
Martin 👍
