GPK Posted February 4 Posted February 4 Hello CAD Gurus, I've got a real head scratcher for you.... I have 3 drawings (.dwg), a master and a utility drawing, and a site drawing. The master has the utility and site attached as an x-ref overlay (assume all references are attached at 0,0,0, with scale factor 1, we've had multiple very experienced CAD users checking all this). The issue just started recently where the utility dwg is not lining up with the site dwg while both are attached in the master dwg. It all used to line up fine but now suddenly the utility dwg needs to be moved about 500 units east and 800 units north to line up. You can tell its not scaled wrong because the size of structures and length of pipes is still correct. Here is the really freaky part, if you copy by base point (ctrl+shift+c > 0,0,) a line from the utility dwg then paste it in either the master or site (ctrl+v > 0,0) it pastes in exactly where it should, lining up with the site. EVEN while the utility xref is sitting there with its base point at 0,0,0 and scale at 1 and yet some how a few hundred units away from lining up to the site. So copying an object from the utility and pasting it in the master lines it up but, xref-ing the utility and it doesn't line up. Additional info. about the strangeness of this. If you attach the site dwg to the utility drawing everything lines up, HOWEVER, if you attach the utility dwg to the site its off by the same amount that it is in the master. Before offering advice please see our troubleshooting list below. (each of these settings has been double checked by 3 different people in my office, none of us are cad newbies) There is no GEO location on any of them and no transformation (from that one tab in drawing settings) The units (DDUNITS) and the units in the drawing setting tab of the toolspace panel are the same in each drawing. The UCS is set to world in all 3 drawings. The insertion point of each and every XREF is 0,0,0 All XREFs have 1.0 scaling (no scaling) All drawings were made from the same version of CAD (2021 I think) Its been audited, purged (regapps purged too), saved, closed and reopened by another guy on another workstation yet the problem persists. We tried detaching and re-attaching everything. Is the drawing just broken or am I missing something obvious? Heck maybe I'm missing something not obvious! Whatever the case any help would be much appreciated. Quote
CyberAngel Posted February 15 Posted February 15 Have you checked the INSBASE variable in the utility drawing? If it's not (0,0), you could get this kind of behavior. Quote
Drafting Teacher Posted Monday at 10:27 PM Posted Monday at 10:27 PM Could it be XREF Clipping? Check if there are any clipping boundaries set for the XREFs that might be causing the shift. And just for kicks and giggles. have you taken a blank dwg and loaded all three in it? If so, did the problem persist? Quote
GPK Posted Wednesday at 04:53 PM Author Posted Wednesday at 04:53 PM On 2/15/2025 at 10:33 AM, CyberAngel said: Have you checked the INSBASE variable in the utility drawing? If it's not (0,0), you could get this kind of behavior. We just re-opened the main drawing to check this (thank you for the suggestion, I didn't know about this) and this misbehaving utility drawing was attached but not showing at all, layers thawed and unfrozen and zoomed extents an everything... After checking INSBASE in the main and util drawing we reattached it and it came in fine. I suspect its just a buggy drawing. Thank you again, I will be checking this variable from now on. Quote
GPK Posted Wednesday at 04:57 PM Author Posted Wednesday at 04:57 PM On 2/17/2025 at 4:27 PM, Drafting Teacher said: Could it be XREF Clipping? Check if there are any clipping boundaries set for the XREFs that might be causing the shift. And just for kicks and giggles. have you taken a blank dwg and loaded all three in it? If so, did the problem persist? I had not thought of that and will keep it in mind if the problem persists however, it seems to have resolved itself after re-attaching it today. I suspect its a buggy drawing. Thank you for the lead, I'll be checking this in the future as well! Quote
