Thomas Schlüssi Posted February 4 Posted February 4 Hello everyone! I'm relatively new to Revit and am now looking for a way to change a parameter using a shortcut. In detail, I want to achieve the following: 1.) Select an object where a certain parameter is to be adjusted. 2.) Use the shortcut V+'NUMPAD+' to increase the value by 1, and use the shortcut V+'NUMPAD-' to decrease the value by 1. Basically, I want to use this help to adjust the offset in the 2D view of sockets that are on top of each other. How can I do this? Would a macro help here? Maybe someone can help me. Thanks! Quote
nod684 Posted February 12 Posted February 12 IF you can provide a sample model we might be able to help you... Quote
