DCL with the options to select what commands to string together
Would it be possible to have a dcl list with a check boxes like the below. String the commands together?
( ) Command 1
( ) Command 2
( ) Command 3
( ) Command 4
( ) Command 5
If i were to select Command 1 and Command 4. It would run those commands in order?
If i were to select Command 3, Command 4, and Command 5. It would run those commands?
My initial thought is in the back end to have several iterations of each possible options.
Just not sure what would be the best approach for this.
Thank you for the ideas.
Of course it is possible
Have you already written the dcl and commands?
I think i have it almost working. It seems to be doing what I want it too.
(defun c:checkbox (/ dcl_id result cmd1 cmd2 cmd3 cmd4 cmd5)
  (setq dcl_id (load_dialog "checkbox.dcl"))
  (if (not dcl_id)
      (alert "Failed to load DCL file!")
      (exit)
  (if (not (new_dialog "checkbox_dialog" dcl_id))
      (alert "Error loading dialog.")
      (exit)
  (setq cmd1 "0" cmd2 "0" cmd3 "0" cmd4 "0" cmd5 "0")
  (set_tile "cmd1" cmd1)
  (set_tile "cmd2" cmd2)
  (set_tile "cmd3" cmd3)
  (set_tile "cmd4" cmd4)
  (set_tile "cmd5" cmd5)
  (action_tile "accept"
    "(setq cmd1 (get_tile \"cmd1\")
           cmd2 (get_tile \"cmd2\")
           cmd3 (get_tile \"cmd3\")
           cmd4 (get_tile \"cmd4\")
           cmd5 (get_tile \"cmd5\")
           result T)
     (done_dialog 1)"
  (action_tile "cancel" "(setq result nil) (done_dialog 0)")
  (start_dialog)
  (unload_dialog dcl_id)
  (if result
      (if (= cmd1 "1") (C:Command1))
      (if (= cmd2 "1") (C:Command2))
      (if (= cmd3 "1") (C:Command3))
      (if (= cmd4 "1") (C:Command4))
      (if (= cmd5 "1") (C:Command5))
(defun c:command1 ()
(alert "Command 1 Selected")
(defun c:command2 ()
(alert "Command 2 Selected")
(defun c:command3 ()
(alert "Command 3 Selected")
(defun c:command4 ()
(alert "Command 4 Selected")
(defun c:command5 ()
(alert "Command 5 Selected")
checkbox_dialog : dialog {
    label = "Select Commands";
    : toggle { key = "cmd1"; label = "Command 1"; }
    : toggle { key = "cmd2"; label = "Command 2"; }
    : toggle { key = "cmd3"; label = "Command 3"; }
    : toggle { key = "cmd4"; label = "Command 4"; }
    : toggle { key = "cmd5"; label = "Command 5"; }
    : row {
        : button { key = "accept"; label = "OK"; is_default = true; }
        : button { key = "cancel"; label = "Cancel"; is_cancel = true; }
Yes
It seems like it should work
  (if (not dcl_id)
      (exit)
      (exit)
           result T)
     (done_dialog 1)"
  (start_dialog)
  (if result
    : row {
Expand
This would be my front end can have up to about 20 choices, see multi toggles. Just having a think how make a command from a string etc maybe a Eval or read.
This worked.
(setq str (list "circle" "0,0" "10"))
(foreach val str (command val))
You do a foreach of the ans and look is it a "1" meaning you have selected that item. So run that command.
Multi toggles.lspFetching info...
