Hi. I am searchin for a lisp code to dimension second ground on cross section.
I start a code to move the second ground to GROUND2 layer.  The problem is that the cross section in not drawing in 0,H  (H is the datum elevetion). I have some instractions in the dwg file
(defun c:Test ()
  ;; Check if the layer exists, if not, create it
  (if (not (tblsearch "layer" "GROUND2"))
    (command "_layer" "_m" "GROUND2" "_c" "11" "" "") ; Create the layer with color index 11
  (and (setq ss (ssget '((0 . "*POLYLINE"))))
       ((lambda (int / sn lst)
          (while (setq int (1+ int)
                       sn  (ssname ss int)
            (setq lst (entget sn))
            (entmod (subst '(8 . "GROUND2") (assoc 8 lst) lst))
         -1
Thanks
test.dwgFetching info...
