lisp for changing all objects in a block to layer "0"
chulse
Hi this one work so great,,, i like it so much... am seeking for one modification in this...
Block entities are perfectly changing to "0" layer, but Block remain in same layer i wanted block also to change in "Desired Layer" or "0" Layer...
And if possible Nested block and Nested Entities to "0" Layer or to "Desired Layer"
thanks
Ah, that's my mistake... Changed code is:
(defun c:norm (/ *error* adoc lst_layer func_restore-layers)
 (defun *error* (msg)
   (func_restore-layers)
   (vla-endundomark adoc)
   (princ msg)
   ) ;_ end of defun
 (defun func_restore-layers ()
   (foreach item lst_layer
     (vla-put-lock (car item) (cdr (assoc "lock" (cdr item))))
     (vl-catch-all-apply
       '(lambda ()
          (vla-put-freeze
            (car item)
            (cdr (assoc "freeze" (cdr item)))
            ) ;_ end of vla-put-freeze
          ) ;_ end of lambda
       ) ;_ end of vl-catch-all-apply
     ) ;_ end of foreach
   ) ;_ end of defun
 (vl-load-com)
 (vla-startundomark
   (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
   ) ;_ end of vla-startundomark
 (if (and (not (vl-catch-all-error-p
                 (setq selset
                        (vl-catch-all-apply
                          (function
                            (lambda ()
                              (ssget '((0 . "INSERT")))
                              ) ;_ end of lambda
                            ) ;_ end of function
                       ) ;_ end of setq
                 ) ;_ end of vl-catch-all-error-p
               ) ;_ end of not
          selset
          ) ;_ end of and
     (vlax-for item (vla-get-layers adoc)
       (setq
         lst_layer (cons (list item
                               (cons "lock" (vla-get-lock item))
                               (cons "freeze" (vla-get-freeze item))
                               ) ;_ end of list
                         lst_layer
                         ) ;_ end of cons
         ) ;_ end of setq
       (vla-put-lock item :vlax-false)
       (vl-catch-all-apply
         '(lambda () (vla-put-freeze item :vlax-false))
       ) ;_ end of vlax-for
     (foreach blk_def
              (mapcar
                (function
                  (lambda (x)
                    (vla-item (vla-get-blocks adoc) x)
                    ) ;_ end of lambda
                ((lambda (/ res)
                   (foreach item (mapcar
                                   (function
                                     (lambda (x)
                                       (vla-get-name
                                         (vlax-ename->vla-object x)
                                         ) ;_ end of vla-get-name
                                       ) ;_ end of lambda
                                   ((lambda (/ tab item)
                                      (repeat (setq tab  nil
                                                    item (sslength selset)
                                                    ) ;_ end setq
                                        (setq
                                          tab
                                           (cons
                                             (ssname selset
                                                     (setq item (1- item))
                                                     ) ;_ end of ssname
                                             tab
                                             ) ;_ end of cons
                                          ) ;_ end of setq
                                        ) ;_ end of repeat
                                      tab
                                      ) ;_ end of lambda
                                   ) ;_ end of mapcar
                     (if (not (member item res))
                       (setq res (cons item res))
                       ) ;_ end of if
                     ) ;_ end of foreach
                   (reverse res)
                   ) ;_ end of lambda
                ) ;_ end of mapcar
       (vlax-for ent blk_def
         (vla-put-layer ent "0")
         (vla-put-color ent 0)
         (vla-put-lineweight ent aclnwtbyblock)
         (vla-put-linetype ent "byblock")
       ) ;_ end of foreach
     (vla-regen adoc acallviewports)
     ) ;_ end of progn
   ) ;_ end of if
 ) ;_ end of defun
  • 4 weeks later...
  • Replies 27
  • kpblc
    6
  • chulse
    5
  • gilsoto13
    4
  • fuccaro
    3
   (princ msg)
   ) ;_ end of defun
     (vl-catch-all-apply
       '(lambda ()
          (vla-put-freeze
            (car item)
          ) ;_ end of lambda
     ) ;_ end of foreach
   ) ;_ end of defun
 (vl-load-com)
 (vla-startundomark
                 (setq selset
                        (vl-catch-all-apply
                          (function
                            (lambda ()
                              ) ;_ end of lambda
                       ) ;_ end of setq
               ) ;_ end of not
          selset
          ) ;_ end of and
       (setq
                               ) ;_ end of list
                         lst_layer
                         ) ;_ end of cons
         ) ;_ end of setq
       (vl-catch-all-apply
     (foreach blk_def
              (mapcar
                (function
                  (lambda (x)
                    ) ;_ end of lambda
                ((lambda (/ res)
                                   (function
                                     (lambda (x)
                                       (vla-get-name
                                       ) ;_ end of lambda
                                                    ) ;_ end setq
                                        (setq
                                          tab
                                           (cons
                                             (ssname selset
                                                     ) ;_ end of ssname
                                             tab
                                             ) ;_ end of cons
                                          ) ;_ end of setq
                                        ) ;_ end of repeat
                                      tab
                                      ) ;_ end of lambda
                                   ) ;_ end of mapcar
                       ) ;_ end of if
                     ) ;_ end of foreach
                   (reverse res)
                   ) ;_ end of lambda
                ) ;_ end of mapcar
       ) ;_ end of foreach
     ) ;_ end of progn
   ) ;_ end of if
 ) ;_ end of defun
Does not support Mosaic block?
Drawing155.dwg
version:A2010
No. I you want to proceed blocks in blocks, try this code:
(defun c:norm2 (/ *error* adoc lst_layer func_restore-layers  fun_get-block-subref-by-block)
   (princ msg)
   ) ;_ end of defun
 (defun fun_get-block-subref-by-block (blk-name)
   (setq res (list blk-name))
   (vlax-for subent (vla-item (vla-get-blocks adoc) blk-name)
     (if (wcmatch (strcase (vla-get-objectname subent)) "*BLOCK*")
       (setq res (append res (fun_get-block-subref-by-block (vla-get-name subent))))
       ) ;_ end of if
   res
   ) ;_ end of defun
     (vl-catch-all-apply
       '(lambda ()
          (vla-put-freeze
            (car item)
          ) ;_ end of lambda
     ) ;_ end of foreach
   ) ;_ end of defun
 (vl-load-com)
 (vla-startundomark
                 (setq selset
                        (vl-catch-all-apply
                          (function
                            (lambda ()
                              ) ;_ end of lambda
                       ) ;_ end of setq
               ) ;_ end of not
          selset
          ) ;_ end of and
       (setq
                               ) ;_ end of list
                         lst_layer
                         ) ;_ end of cons
         ) ;_ end of setq
       (vl-catch-all-apply
     (foreach blk_def (mapcar
                        (function
                          (lambda (x)
                            ) ;_ end of lambda
                        ((lambda (/ res)
                           (foreach item (apply (function append)
                                                (mapcar
                                                  (function
                                                    (lambda (x)
                                                        (vla-get-name
                                                      ) ;_ end of lambda
        ) ;_ end setq
                                                       (setq
                                                         tab
                                                          (cons
                                                            (ssname selset
        ) ;_ end of ssname
                                                            tab
                                                            ) ;_ end of cons
                                                         ) ;_ end of setq
                                                       ) ;_ end of repeat
                                                     tab
                                                     ) ;_ end of lambda
                                                  ) ;_ end of mapcar
                                                ) ;_ end of apply
                               ) ;_ end of if
                             ) ;_ end of foreach
                           (reverse res)
                           ) ;_ end of lambda
                        ) ;_ end of mapcar
       ) ;_ end of foreach
     ) ;_ end of progn
   ) ;_ end of if
 ) ;_ end of defun
   (princ msg)
   ) ;_ end of defun
       ) ;_ end of if
   res
   ) ;_ end of defun
     (vl-catch-all-apply
       '(lambda ()
          (vla-put-freeze
            (car item)
          ) ;_ end of lambda
     ) ;_ end of foreach
   ) ;_ end of defun
 (vl-load-com)
 (vla-startundomark
                 (setq selset
                        (vl-catch-all-apply
                          (function
                            (lambda ()
                              ) ;_ end of lambda
                       ) ;_ end of setq
               ) ;_ end of not
          selset
          ) ;_ end of and
       (setq
                               ) ;_ end of list
                         lst_layer
                         ) ;_ end of cons
         ) ;_ end of setq
       (vl-catch-all-apply
                        (function
                          (lambda (x)
                            ) ;_ end of lambda
                        ((lambda (/ res)
                                                (mapcar
                                                  (function
                                                    (lambda (x)
                                                        (vla-get-name
                                                      ) ;_ end of lambda
        ) ;_ end setq
                                                       (setq
                                                         tab
                                                          (cons
                                                            (ssname selset
        ) ;_ end of ssname
                                                            tab
                                                            ) ;_ end of cons
                                                         ) ;_ end of setq
                                                       ) ;_ end of repeat
                                                     tab
                                                     ) ;_ end of lambda
                                                  ) ;_ end of mapcar
                                                ) ;_ end of apply
                               ) ;_ end of if
                             ) ;_ end of foreach
                           (reverse res)
                           ) ;_ end of lambda
                        ) ;_ end of mapcar
       ) ;_ end of foreach
     ) ;_ end of progn
   ) ;_ end of if
 ) ;_ end of defun
Thanks kpblc ,very nice! but I find that,color attribute change from bylayer to byblock,
  • 8 months later...
Can anybody help in excluding the defpoints layer from the selection change?
  • 1 year later...
This thread is a good example of the point I'll make ...
Is there a way to highlight the post with the best working code?
I copy/pasted this code, I forgot which version of the code. And I added some code (xref layers were still being processed ...).
It's hard to add code, and let everybody know what I did, because in the mean time other changes have been made.
I understand this is a forum (it's not Github or so) ... but still
  • 1 month later...
Thank you for this :) Was helpful for me as well in 2016 June :P
  • 4 years later...
Someone commented that the lisp that KPBLC created was the best thing since flushing toilets.  I'd go further, I think it's the best thing since sliced bacon, and I really cannot believe that it's taken me so long to find this routine.
Dealing with dwg exports from Archicad, this will save me a massive amount of time.  Thank you very much indeed ... 😀🍻
