Join several lines or polylines lying on the same straight line in pairs.
It is necessary to join several segments or polylines lying on the same straight line in pairs.
But this code only works with lines. Is it possible for this to work with polylines as well?
LINE, LWPOLYLINE, POLYLINE
(defun c:JoinPairs ( / ent1 ent2 )
  (princ "\nSelect the first line or press Enter/ESC to finish.")
  (while (setq ent1 (car (entsel "\nFirst line for JOIN: ")))
    (setq ent2 (car (entsel "\nSecond line for JOIN: ")))
    (if ent2
      (command "_.JOIN" ent1 ent2 "")
        (prompt "\nThe second line is not selected. Exit.")
        (exit)
  (princ "\nJoin Pairs command is completed.")
Edited by Nikon
  • Nikon changed the title to Join several lines or polylines lying on the same straight line in pairs.
Hi Nikon
If you explode a lwpolyline you will have a line. So you just have to break it up and delete the original.
Simply replace '(command "_.JOIN" ent1 ent2 "")' with the code I have attached
	(if (= (cdr (assoc 0 (entget ent1))) "LWPOLYLINE")
	  (setq ent (vlax-vla-object->ename (car (vlax-safearray->list (vlax-variant-value (vla-explode (vlax-ename->vla-object ent1))))))
		x (vla-delete (vlax-ename->vla-object ent1))
		ent1 ent
	(if (= (cdr (assoc 0 (entget ent2))) "LWPOLYLINE")
	  (setq ent (vlax-vla-object->ename (car (vlax-safearray->list (vlax-variant-value (vla-explode (vlax-ename->vla-object ent2))))))
		x (vla-delete (vlax-ename->vla-object ent2))
		ent2 ent
Edited by GLAVCVS
Yes, this is a great option! Thank you very much!
(defun c:JoinPairsGL ( / ent1 ent2 )
    (if ent2
    ;  (command "_.JOIN" ent1 ent2 "")
		ent1 ent
		ent2 ent
        (exit)
Edited by Nikon
I think this was asked recently else where, I used JOIN which works for lines.
  • Thanks 1
