Mystogan Posted January 30, 2025 Posted January 30, 2025 Hello Everyone, Hoping somebody could help me out. I have ask an AI(free version chatgpt) to create an LSP code to change specific block name and attribute tag. It has choices as shown the code below. (defun c:EditBlockAttribute () (setq blkName (getstring T "\nEnter block name: ") attrTag (strcase (getstring T "\nEnter attribute tag: ")) choice (getint "\nSelect option: 1-Change Text Height, 2-Change Layer, 3-Change Position: "))) (setq filter (list (cons 0 "INSERT") (cons 2 blkName))) (setq ss (ssget "X" filter)) ;; Select all instances of the specified block (if ss (progn (setq i 0) (while (< i (sslength ss)) (setq ent (ssname ss i)) (setq blkObj (vlax-ename->vla-object ent)) (setq blkEnts (vlax-invoke blkObj 'GetAttributes)) ;; Get block attributes (foreach obj blkEnts (if (equal (strcase (vlax-get obj 'TagString)) attrTag) (EditAttribute obj choice) ) ) (vlax-release-object blkObj) (setq i (1+ i)) ) (princ "\nAttribute updated successfully.") ) (princ "\nNo matching blocks found.")) (princ) ) (defun EditAttribute (obj choice) (cond ((= choice 1) (setq newHeight (getreal "\nEnter new text height: ")) (vlax-put obj 'Height newHeight) ) ((= choice 2) (setq newLayer (getstring T "\nEnter new layer name: ")) (vlax-put obj 'Layer newLayer) ) ((= choice 3) (setq moveDist (getreal "\nEnter move distance (use positive for right, negative for left): "))) (if (vlax-property-available-p obj 'InsertionPoint) (progn (setq insPt (vlax-get obj 'InsertionPoint)) (setq newPt (list (+ (car insPt) moveDist) (cadr insPt) (caddr insPt))) (vlax-put obj 'InsertionPoint newPt) ) (princ "\nError: Attribute does not have an insertion point.") ) ) (t (princ "\nInvalid option selected.")) ) ) Unfortunately, it didn't push through. I don't know what happen or how to fix this code. Need help Quote
GLAVCVS Posted January 30, 2025 Posted January 30, 2025 I've just skimmed through your code. But there's one thing you need to know: when you specify the name of the target layer for the block, it must exist. If it doesn't, your code won't work. Quote
Mystogan Posted January 30, 2025 Author Posted January 30, 2025 1 minute ago, GLAVCVS said: I've just skimmed through your code. But there's one thing you need to know: when you specify the name of the target layer for the block, it must exist. If it doesn't, your code won't work. Hi GLAVCVS thank you for noticing my post. yes it is existing in the drawing, but it didn't push through. even I input the value for the option 3. Quote
Mystogan Posted January 30, 2025 Author Posted January 30, 2025 Hi here's the cad file i guess, i got a little bit of dizzy. It is now moving but it ask me twice when I choose the option 3. Supposed to be only once and the command terminated after I enter the desired movement. SAMPLEFILE.dwg Quote
GLAVCVS Posted January 30, 2025 Posted January 30, 2025 Your code had several badly placed parentheses. You should check your code with the debugger. More things: your code makes a selection of all the blocks that match the specified filters. And it requests parameters for each block to be modified, but without displaying it on the screen. I think it is necessary to add a call to the 'zoom' command to move the graphic window to the position of the next block to be modified. So I have added that code. But I am not sure if your version of AutoCAD will correctly understand my calls to the 'zoom' command. You should check it yourself (defun c:EditBlockAttribute () (setq blkName (getstring T "\nEnter block name: ") attrTag (strcase (getstring T "\nEnter attribute tag: ")) choice (getint "\nSelect option: 1-Change Text Height, 2-Change Layer, 3-Change Position: " ) ) (setq filter (list (cons 0 "INSERT") (cons 2 blkName))) (setq ss (ssget "X" filter)) ;; Select all instances of the specified block (if ss (progn (setq i 0) (while (< i (sslength ss)) (setq ent (ssname ss i)) (setq blkObj (vlax-ename->vla-object ent)) (setq blkEnts (vlax-invoke blkObj 'GetAttributes)) ;; Get block attributes (VL-CMDF "_zoom" "c" (cdr (assoc 10 (entget ent))) "30") (foreach obj blkEnts (if (equal (strcase (vlax-get obj 'TagString)) attrTag) (EditAttribute obj choice) ) ) (vlax-release-object blkObj) (setq i (1+ i)) ) (princ "\nAttribute updated successfully.") ) (princ "\nNo matching blocks found.") ) (princ) ) (defun EditAttribute (obj choice) (cond ((= choice 1) (setq newHeight (getreal "\nEnter new text height: ")) (vlax-put obj 'Height newHeight) ) ((= choice 2) (setq newLayer (getstring T "\nEnter new layer name: ")) (vlax-put obj 'Layer newLayer) ) ((= choice 3) (setq moveDist (getreal "\nEnter move distance (use positive for right, negative for left): " ) ) ;;; ) (if (vlax-property-available-p obj 'InsertionPoint) (progn (setq insPt (vlax-get obj 'InsertionPoint)) (setq newPt (list (+ (car insPt) moveDist) (cadr insPt) (caddr insPt) ) ) (vlax-put obj 'InsertionPoint newPt) ) (princ "\nError: Attribute does not have an insertion point." ) ) ) (t (princ "\nInvalid option selected.")) ) ) Quote
Mystogan Posted January 31, 2025 Author Posted January 31, 2025 @GLAVCVS It work, this is what i'm looking for. Thank you very much sir. I will take note the comments above, It really help me once again thank you. Quote
BIGAL Posted February 1, 2025 Posted February 1, 2025 As mentioned above, "Your code had several badly placed parentheses." if you use Notepad++ to write code it has a parentheses checker built in and its free. It also has a addon ActiveX that allows you run the code in you are writing. Quote
