AlexS Posted Thursday at 06:58 AM Posted Thursday at 06:58 AM Hey guys, I got a friend of mine to create a lisp program some time back which has been working fine up to now. Unfortunately he passed away a few years back so i cant get him to fix it. It reads the attributes from a block and draws a 3d string to those invert levels in the attributes then writes to the attributes and updates the grade and pipe length. The problem is now the block is inserted into a mleader and the only way to read and write to it is by exploding the mleader. Can this lisp be modified to work with the mleader and block within it instead of exploding it ? BTW Appreciate any help as I am not much good at lisp and only a beginner. Sorry. Quote
BIGAL Posted Friday at 04:27 AM Posted Friday at 04:27 AM We can not help unless you post a dwg. Quote
AlexS Posted Friday at 05:00 AM Author Posted Friday at 05:00 AM Thanks Bigal. It wouldn't let me yesterday but i'll try again. On 1/30/2025 at 6:58 AM, AlexS said: Hey guys, I got a friend of mine to create a lisp program some time back which has been working fine up to now. Unfortunately he passed away a few years back so i cant get him to fix it. It reads the attributes from a block and draws a 3d string to those invert levels in the attributes then writes to the attributes and updates the grade and pipe length. The problem is now the block is inserted into a mleader and the only way to read and write to it is by exploding the mleader. Can this lisp be modified to work with the mleader and block within it instead of exploding it ? BTW Appreciate any help as I am not much good at lisp and only a beginner. Sorry. Expand Quote
AlexS Posted Friday at 05:02 AM Author Posted Friday at 05:02 AM Here they are.... Sorry If you explode the info box then the lisp works though not when all together. Thanks for any help in advance Pipe3D.LSPFetching info... SAMPLE.dwgFetching info... Quote
BIGAL Posted Friday at 07:45 AM Posted Friday at 07:45 AM (edited) If you use Nentsel can read the values in the block. Struggle to understand the rest of the task. Understand grade and length use. (setq blk (nentsel "\nPick block")) (setq vals (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 302)) (entget (car blk))))) (princ vals) ("LEADER{" "9.80" "150" "xxx" "00.0" "9.21" "") Edited Friday at 07:46 AM by BIGAL Quote
AlexS Posted Friday at 08:27 AM Author Posted Friday at 08:27 AM Thanks Bigal, So can this be incorporated into the lisp routine so it reads the invert levels from the block, creates the 3d string to those levels, then rewrites the grade and pipe length to the block? in the script. Regards Alex Quote
AlexS Posted Friday at 08:47 AM Author Posted Friday at 08:47 AM INSTRUCTIONS Thought I'd write this to clarify what I mean If you open the Sample.dwg and explode the leader so the block is separated from the mleader then this lisp will work fine. Then use Appload and load the pipe3d.lsp and type pipe3d to run it. It will prompt you to select the upstream end of the pipe and please select the top of the red line. It will then prompt to select the pipe info block. it will then read the upstream invert level from the pipe info block and the downstream invert level and draw a 3d line over the top of the red line (to these invert levels). then it will update the block and add the pipe length and pipe grade and done The lisp routine works fine though the only problem i have is i have to explode the mleader from the block to do this. Can this routing be amended to do this without exploding the mleader from the block ? Appreciate any help i can get. Regards Alex Quote
BIGAL Posted Sunday at 01:49 AM Posted Sunday at 01:49 AM Give this a try. The get property was the secret. ; https://www.cadtutor.net/forum/topic/96175-mleader-with-block-and-attributes/#comment-662196 ; read and update a mleader block attributes ; By AlanH Feb 2025 (defun c:blkgr ( / 10s blkent end grade il1 il2 len oldsnap start z) (setq oldsnap (getvar 'osmode)) (setvar 'osmode 0) (setq blkent (car (entsel "\nPick leader "))) (setq il1 (atof (getpropertyvalue blkent "USIL~BlockAttribute"))) (setq il2 (atof (getpropertyvalue blkent "DSIL~BlockAttribute"))) (setq 10s (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10))(entget blkent)))) (setq pt (nth 2 10s)) (setq obj (vlax-ename->vla-object (ssname (ssget pt '((0 . "LINE"))) 0))) (setq start (vlax-curve-getstartPoint obj)) (setq end (vlax-curve-getEndPoint obj)) (setq len (vlax-get obj 'length)) (setq start (list (car start)(cadr start) il1)) (setq end (list (car end)(cadr end) il2)) (command "3dline" start end "") (setq z (- il2 il1)) (setq grade (strcat (rtos (* 100. (/ z len)) 2 1) " %")) (setpropertyvalue blkent "GR~BlockAttribute" grade) (setpropertyvalue blkent "LENGTH~BlockAttribute" (rtos len 2 2)) (setvar 'osmode oldsnap) (princ) ) (c:blkgr) Quote
AlexS Posted yesterday at 01:01 AM Author Posted yesterday at 01:01 AM Thanks Bigal, I run it and get this error. I was hoping for a change to the original list for it to now work ? As mentioned i'm a noob and not sure if this script was suppose to be pasted into the LSP or what. Thanks for your help. Quote
BIGAL Posted 8 hours ago Posted 8 hours ago Did you save the code as a .lsp file ? Then use appload or drag & drop using explorer. The message is odd as it looks like it does not get past the first user request. Quote
AlexS Posted 5 hours ago Author Posted 5 hours ago Thanks Bigal, I saved it as a LSP file and used Appload to load and run it. It didn't do much ? Prompted to select the leader then came up with the error. Sorry. Quote
BIGAL Posted 3 hours ago Posted 3 hours ago I am a bit stuck works for me testing on your Sample.dwg. Did you test with that dwg ? If it works then post other dwg. Quote
