aaron.parr1 Posted January 29 Posted January 29 Title basically sums it up. I've tried by adding attribute to the block then inserting field but when i choose either "count" or "countinarea" from the list under the "Objects" category and click ok; i get "invalid field code" error. the "Expression" window is blank so i copy the code from "Field Expression" and insert it. that allows me to use insert the attribute but this count doesn't update. i know i can use the the count function but i'd like this number displayed and linked to the blocks. Quote
SLW210 Posted January 30 Posted January 30 I moved your thread to the AutoCAD Bugs, Error Messages & Quirks Forum. Please post in the correct forum. This is a common problem Insert > Field > Object, does not display choices - Autodesk Community If you search you'll see more, not sure if this is fixed in newer versions. I have this issue, I can get it to work most times by selecting Objects in the first column then Okay, new Profile may help, try opening a drawing that the field selection you need is working. If I run into this I'm planning on getting our IT to get it sorted. I plan on moving to the newer version when it comes out. Quote
