thekiki Posted January 29, 2025 Posted January 29, 2025 Hi, "Special_selection" of Gilles is very useful. Typing "ssc" for color selecting. But when i select the color of layer, the others layers are selected. That's not what i want to have. Autocad file and "special_selection" lisp are attach for better explanation. Thanks for your help. Test-selection.dwg Special_selections.lsp Quote
GLAVCVS Posted January 29, 2025 Posted January 29, 2025 You forgot to set the layer filter for 'ssget' Replace '(sssetfirst nil (ssget "_X" (list col)))' with '(sssetfirst nil (ssget "_X" (list (assoc 8 elst) col)))' Quote
pkenewell Posted January 29, 2025 Posted January 29, 2025 @thekiki That is because if the Entity you select is set to "Bylayer" (meaning the color is controlled by the Layer), the routine will select everything else that is also "bylayer." use the "SSL" command instead to select everything on a layer. Quote
thekiki Posted January 29, 2025 Author Posted January 29, 2025 Pkenewell, in my case, if i use "ssl", all the entity by layer ( a lot of layers) are selected and that's not what i want. That's perfect GLAVCVS! Thanks a lot! Quote
pkenewell Posted January 29, 2025 Posted January 29, 2025 47 minutes ago, thekiki said: Pkenewell, in my case, if i use "ssl", all the entity by layer ( a lot of layers) are selected and that's not what i want. That's perfect GLAVCVS! Thanks a lot! @thekiki I don't completely understand maybe, but it seems to work for me. "SSL" selects everything on "Layer1" regardless of color: "SSC" selects everything explicitly set to a COLOR override (not "Bylayer"): If you mean that you want to select everything that is "Red", whether it is actually Bylayer or not. Than you need something a little more complex; that iterates though the layers and finds the layer that matches the color. Then select all on that layer, EXCEPT anything explicitly color overridden to something other than "Red", then get everything else with the "Red" color override. Quote
pkenewell Posted January 29, 2025 Posted January 29, 2025 (edited) @thekiki Try this. It gets everything that is a specific color, regardless of whether it is explicitly set or is colored by the layer. Thanks to Gilles for inspiring the code structure. Tested and works in your drawing. (defun c:sscl (/ col elst ent lcol lel ss) (and (or (and (setq ss (cadr (ssgetfirst))) (= 1 (sslength ss)) (setq ent (ssname ss 0)) ) (and (sssetfirst nil nil) (setq ent (car (entsel "\nSelect Object: "))) ) ) (setq elst (entget ent) lel (tblsearch "LAYER" (cdr (assoc 8 elst))) col (cond ((assoc 430 elst)) ((assoc 420 elst)) ((assoc 62 elst)) (T (cons 62 256)) ) lcol (cond ((assoc 430 lel)) ((assoc 420 lel)) ((assoc 62 lel)) (T (cons 62 256)) ) ) (if (= (cdr col) 256) (sssetfirst nil (ssget "_X" (list '(-4 . "<OR") lcol '(-4 . "<AND") (assoc 8 elst) '( 62 . 256) '(-4 . "AND>") '(-4 . "OR>") ) ) ) (sssetfirst nil (ssget "_X" (list col))) ) ) (princ) ) Edited January 29, 2025 by pkenewell Quote
thekiki Posted January 30, 2025 Author Posted January 30, 2025 Pkenewell, thanks for your answer. What i want that when I select entity (by layer) by layer1, only entity by layer1 is selected, whereas "ssl" select every thing on layer1. The modification of "GLAVCVS" is perfect. Thanks again for your reply. Quote
pkenewell Posted January 30, 2025 Posted January 30, 2025 (edited) 6 hours ago, thekiki said: Pkenewell, thanks for your answer. What i want that when I select entity (by layer) by layer1, only entity by layer1 is selected, whereas "ssl" select every thing on layer1. The modification of "GLAVCVS" is perfect. Thanks again for your reply. @thekiki OK. seems i misunderstood what you wanted in your original post. I'm glad that @GLAVCVS gave you what you needed. FWIW - I recommend adding the "SSCL" command I created to the "special Selections,lsp", it might come in handy to you in the future. I'm definitely adding it to my arsenal. Edited January 30, 2025 by pkenewell Quote
thekiki Posted January 30, 2025 Author Posted January 30, 2025 Sure, "SSCL" is already added to "Special_selections" lisp. Thanks again. 1 Quote
