smothish Posted January 27 Posted January 27 I'm sorry for what is a basic question but I cant seem to remember the best way to have a floor plan sit on top of a solid colour? Quote
SLW210 Posted January 27 Posted January 27 Draworder AutoCAD 2022 Help | DRAWORDER (Command) | Autodesk Quote
smothish Posted January 27 Author Posted January 27 thank you for this, I've tried but to no luck https://autode.sk/3Ec5Pas Quote
SLW210 Posted January 27 Posted January 27 Your Hatch is in Paperspace in a Layout tab with the objects in Modelspace. You need the Hatches to be in Modelspace then use HPDRAWORDER or DRAWORDER to send the Hatch to the back or below the objects. One workaround would be to add Transparency to the Hatches so the Modelspace objects can be seen. Quote
