Nikon Posted January 23 Author Posted January 23 On 1/23/2025 at 4:13 PM, GLAVCVS said: What is the problem? Expand I probably have problems with AutoCAD 2015, but the code works well in AutoCAD 2020. Thank. Quote
GLAVCVS Posted January 24 Posted January 24 On 1/23/2025 at 6:37 PM, Nikon said: Probablemente tengo problemas con AutoCAD 2015, pero el código funciona bien en AutoCAD 2020. Gracias. Expand I find it hard to believe that the code doesn't work correctly in AutoCAD 2015. I have that version installed on another PC and it works perfectly. I think this is a good time for you to learn how to use the Visual Lisp debugger. With it you will be able to locate where the problem is and if, indeed, there is any inconsistency. 1 Quote
